#51
Peter R. wrote:
On 2/28/2007 4:39:47 PM, "Jim B" wrote: Right now I'm confident that I'm proficient in all areas of departure, climb, cruise, decent, and arrival procedures and also proficient to shoot most precision and non precision approaches down to minimums in non mountainous terrain, both in radar and non radar environments. Wait a minute... you know Jay, too, so you are the second of the two instrument-rated pilots he knows. That means there are no pilots in Iowa City who are proficient and current. ![]() With their weather and flat land, there is no need to be current and proficient! :-) Matt |
#52
Thomas Borchert wrote:
Robert, I've only had to cancel a very small number of trips because the IFR was not duable (usually ice). However, I've had lots of trips that would have been canceled VFR but 0.1 hours of IFR made the trip work. Exactly. Plus, you just don't have to fret weather decisions as much. All this doesn't mean at all you're flying in clouds for hours or approaches to the minimums. Then again, it may! I flew my niece back to college one day (from ELM to SGH) when the entire east coast was socked in. The ceilings were 300-600 feet the entire trip which took nearly 4 hours on the way out and 2.5 on the way back. And the clouds were solid to 20,000 feet. I flew out at 8,000 if memory serves and back at 7,000 and I could barely see the wingtips the entire flight. It was smooth as silk however. An easy IFR flight that would have not been possible VFR. The alternative was 9 hours of driving... Matt |
#53
Peter R. wrote:
On 2/28/2007 12:08:47 PM, "Jay Honeck" wrote: However, I no long harbor the notion that an IR is going to help us fly more, or longer, or more regularly -- at least not until we can afford something like a Pilatus. Now that I have several hundred hours since my instrument rating, I would never trade it in for a VFR-only rating. As someone who uses my Bonanza to commute weekly to work and to carry Angel Flight patients at least monthly, I can attest to the power of an instrument rating, at least when speaking of flying in the Northeast US. In the end, it all boils down to where you are based, where you fly often, and if you have a reason to be at your destination. From the weather I have seen there, I agree that an IFR rating for those based out of an Arizona airport would be difficult to maintain without a lot of safety pilot/under-the-hood type flights. I agree, Peter, you and I aren't in Kansas ... er, Iowa, anymore! :-) Matt |
#54
After having lived and flown in both regions, I'd say the weather is much
worse in the Midwest. The extremes of temperature are much greater in the Midwest, and the winds tend to be a lot stronger. Icing- ever fly over Lake Michigan? Much worse than the lift over the Adirondacks and Green Mountains. Thunderstorms?- When was the last time New Hampshire had a tornado? Subjectively, I'd say the weather in the Midwest is a lot more challenging than in the Northeast. On the original thread, having the IFR rating just provides the extra comfort level- why scud run when you can pop through a few thousand feet of clouds to CAVU on top? Besides, doing all of the approaches, especially with the VNAV and LDP approaches, is fun. Tracking an NDB course outbound with a howling quartering tail wind can be real fun- then do it at night in IMC with some turbulence. It's all fun. |
#55
![]() "Bob Noel" wrote I guess the northeast gets more IMC days than Iowa. WithOUT a DOUbt! g I _"think"_ it might have something to do with that big cold pond just to the east of you! ;-) -- Jim in NC |
#56
Jose wrote:
That's at one airport. To complete a =flight= VFR, both airports have to be VFR, and so does the intervening space. And so does the forecast, from departure through scheduled return. What conditions are those? Sounds like you would be comfortable making up your own rules. Would you be comfortable letting everyone make up their own rules? Well, this isn't what you were asking (and Jay's response clarified his intent), but, yes, well all make up our own rules. They're called "personal minimums", and we all have them. They do have to be at or above the FAA's minima, of course ... .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
#57
Jay,
That's really the reason for the IR, in my opinion. It's not that you'll actually fly a whole lot more, but you'll not worry about those clouds building "over there" as much. In the end, that is why Mary and I will eventually get the rating. I agree fully! Especially in the less capable planes we fly, that's the way to look at IFR, IMHO. Of course, your confidence level should be directly related to your currency and proficiency. If my observations prove anything, it's that most instrument-rated private pilots don't use the rating enough to be proficient. There's truth to that. OTOH, punching through 1000 feet of not-too-low stratus doesn't require that much proficiency. It's really a matter of adequate personal minimums. FWIW, flight planning becomes much easier with IFR. You just don't worry about airspace anymore. -- Thomas Borchert (EDDH) |
#58
Jay,
Doesn't matter of your the Ace of the Base -- if you're flying a Cherokee in February, you're gonna be sitting on the ground a lot. Well, I'm not sure I agree. More often than not, you will have the required "out" even with a danger of ice present. The other day I made a 1.5 hour flight in the Tobago that would not have been possible VFR - or not really well. The forecast for the departure area with an ILS-equipped airport near was stratus from 700 feet with tops at 2500 to 3500, visibility 4000 meters below the clouds. Serious scud running would have been required VFR, something I would want to do, even though it would have been legal in Germany. Freezing level at 3500 to 4000. Minimum enroute altitude 4000, MRVA 2000. Icing forecast in clouds above freezing level. So with bad luck, we might just have ended up in icy clouds for a very short time during climb-out. But we could have returned on the ILS below the freezing level, so we had an out. In reality, we came out of clouds at 1800 and flew the first hour in the sunshine. After that some cumulus clouds popped up to 8000. So we climbed on top. We entered some cloud briefly in the climb and picked up very light trace ice. So flying in the clouds at our previous altitude of 5000 definitely wouldn't have worked. At the destination, the cloud cover became scattered to few at 1000 AGL, so we could make the landing at the VFR airfield as planned, picking our way around those. Had that not worked, there was an ILS- and rental-car-equipped airport 20 nm away reporting CAVOK. Winter IFR is often quite doable. -- Thomas Borchert (EDDH) |
#59
Matt,
I flew out at 8,000 if memory serves and back at 7,000 and I could barely see the wingtips the entire flight. It was smooth as silk however. An easy IFR flight that would have not been possible VFR. Nice! -- Thomas Borchert (EDDH) |
#60
Matt Whiting wrote:
Then again, it may! I flew my niece back to college one day (from ELM to SGH) when the entire east coast was socked in. The ceilings were 300-600 feet the entire trip which took nearly 4 hours on the way out and 2.5 on the way back. And the clouds were solid to 20,000 feet. I flew out at 8,000 if memory serves and back at 7,000 and I could barely see the wingtips the entire flight. It was smooth as silk however. An easy IFR flight that would have not been possible VFR. The alternative was 9 hours of driving... Back when I was flying cancelled checks, I used to take off every morning into a low overcast from CLT (Monday through Friday), then cruise through a broken layer to RDU, followed by an ILS to minimums. The crud would burn off later in the morning/ This went on for several days at a time through the late summer and early fall. Couldn't have done it VFR. It was more exciting in the winter but I only left an airplane in place twice. And this was flying either a Lance or a Geronimo converted Apache. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
Do you log airborne time, or aircraft moving time? | Ron Rosenfeld | Owning | 14 | October 24th 04 01:13 AM |
typical total time and PIC time question | AJW | Piloting | 12 | October 15th 04 03:52 AM |
First Time Buyer - High Time Turbo Arrow | [email protected] | Owning | 21 | July 6th 04 07:30 PM |
First time airplane buyer, First time posting | Jessewright8 | Owning | 3 | June 3rd 04 02:08 PM |
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 12:18 AM |
