#31
Viperdoc wrote
... a single bone screw can cost close to $100. I was going to ask if that was hospital cost or patient cost, but thought better of it. |
#32
Hospital cost is less, patient charge is around 3X.
#33
Viperdoc wrote:
We're still in the throes of winter here in Wisconsin- low ceilings, ice, snow encrusted taxiways and ramps. One plane is gone for a month for an avionics upgrade, while the other sits waiting for the return of the prop. No flying for a while. Perhaps I'll organize my tools. So, how about a new poll- how many screwdrivers does the average airplane owner own? Who makes the best screwdrivers? What's your personal favorite tool? (Mine is the Snap on ratchet screw driver. It has a great action and feel, and in fact we use their same mechanism in the operating room for placing bone screws) So, back to aviation- let's hear your responses! I have about 15 screwdrivers. Most are snap-on. Michelle |
#34
Had to go to expensive stainless surgical instruments instead. I went to
all stainless screws on my planes, but it seems like the heads are easier to chew up. That's no surprise, as there are many kinds of stainless--and I don't know enough about metalurgy to offer advice on which to use. Try mentioning the problem to your supplier, if you have not done so already, as they may have similar hardware in a harder or tougher grade. Peter |
#35
Viperdoc wrote:
So, how about a new poll- how many screwdrivers does the average airplane owner own? All of the screwdrivers one owns can be classified into M sets of head types and sizes (1/4" slotted, #2 Phillips, etc.) All of the screws that need turning on all of the aircraft, cars, buildings, power equipment, etc that one owns can be classified into N sets of head types and sizes. It is an immutable law of the Universe that M = N - 1. The only known way around this is to have a very small set of screwdrivers and a large budget for replacement screws: With a Dremel tool and a cut-off wheel, _everything_ takes a flat-blade screwdriver. Matt Roberds |
#36
"Viperdoc" wrote: I have concerns about using an electric screwdriver on my plane- don't they chew up the heads? Part of the trick is to use new screwdrivers. Part of the trick is to be patient Part of the trick is to realize that the heads of the screws will wear out, and have a ready supply of the correct screws to replace the cruddy ones. Have you ever skated across the paint with an electric? Not me. -- Bob Noel Looking for a sig the lawyers will hate |
#37
On Mar 3, 2:16 pm, (Paul Tomblin) wrote:
In a previous article, "Private" said: Being a Canadian, I am also a big fan of the Roberson square screw and think they are superior to the Phillips in every way. IIRC there is some real historical chauvinism that resulted in the use of the Phillips design in the USA and the rejection of the superior Robertson. Look at the Wikipedia articlehttp://en.wikipedia.org/wiki/Robertson_screwdriver According to it, Henry Ford wanted to use Robertson screws on Fords, but Robertson had been screwed (sorry) by a previous licensee and refused to license any other screw manufacturer to make them. Ford decided that he wouldn't trust a single sourced screw, so went to something else. And thus, Robertson missed his chance to have Robertson screws become very common in the US. I heard it a bit differently. Ford was used to getting his way and when he ran into Robertson's stubbornness he actively blocked the sale of those screws in the U.S. I can't see furniture manufacturers, for one, not wanting to use them. Even antique Canadian furniture is full of them. I've driven thousands of them into wooden boats I've built, and we get Robertson "decking" screws here that are good for a thousand uses and are sold by the pound. I imagine they're available in the US by now. Softer screws still get the Roberson socket torn out of them. They're not perfect. Torx screws have the best driving system but they don't sit on the driver so well, not having any sort of taper to wedge them on so you can poke them into some inaccessible spot. Robertsons do that very well. Dan |
#38
I will second the vote for the Swiss Army Knife as a favorite tool.
Mine is the Victorinox "Electrician" model. It's simpler than most S.A. knives and has aluminum handles - but goes with me everywhere and gets used multiple times every day. David Johnson |
#39
they chew up the heads? Part of the trick is to use new screwdrivers. Part of the trick is to be patient Part of the trick is to realize that the heads of the screws will wear out, and have a ready supply of the correct screws to replace the cruddy ones. All very true. I can only add that a surprisingly small amount of wear can cause a lot of problems. Peter |
#40
I'm being extra carefull not to break anything! Peter ;-) |
Another aviation related post: eFlyBook pirep | Viperdoc | Piloting | 8 | October 27th 06 02:05 PM |
An actualy flying related post: eFlyBook | Viperdoc | Piloting | 8 | October 18th 06 12:41 PM |
RSS feed for glider flying related news and features? | Matthieu | Soaring | 0 | November 16th 05 06:05 PM |
First approach in actual | Wizard of Draws | Instrument Flight Rules | 28 | October 19th 04 06:42 PM |
IR without actual IMC | Iain Wilson | Instrument Flight Rules | 26 | October 13th 03 11:26 PM |
