KAUG Notam Question
Old March 3rd 07, 04:22 PM posted to rec.aviation.ifr
Ron Rosenfeld
Default KAUG Notam Question
KAUG AUGUSTA STATE
04/001 - WAAS LPV WAAS LNAV/VNAV OTS WIE UNTIL UFN
This Notam has been posted, well, since April.
No one seems to be sure of what it means.
Translating the abbreviations into English is easy enough. The Notam
basically states that the LPV and LNAV/VNAV approaches are out of service
until further notice.
BUT,
Published guidance, that I have been able to locate, with regard to GPS
WAAS Notams indicates that the terms "unreliable" or "unavailable" should
be used and says nothing about OTS. If the Notam does read UNREL or
UNAVAIL, guidance allows you to execute the approach if the signal is
adequate.
Again, there is no guidance regarding OTS.
Furthermore, the office in OK that issues GPS Notams tell me it didn't come
from them, and it is a D-Notam. They don't know what it means or who
issued it.
I've contacted (or been bounced from) a few other offices having to do with
Notams, without finding anyone who can explain this.
(When I called the Bangor FSS, they said they didn't know and advised me to
contact the "FAA" :-))
My sense is that this may be a Notam that was issued contrary to guidance,
and should have been removed long ago, but was not. But perhaps someone
has a better explanation.
And, two days ago, the signal on an LPV approach at that airport was
adequate for my CNX80 to give me an LPV annunciation.
Old March 4th 07, 02:42 AM posted to rec.aviation.ifr
Sam Spade
You need to hound the region's flight procedures office about this.
In case you have forgotten, you're dealing with the airborne equivalent
of the post office. ;-)
Old March 4th 07, 11:57 AM posted to rec.aviation.ifr
Ron Rosenfeld
Thanks for that info. The flight procedures office is not one I have
tried. I had been dealing with various Notam offices.
Old March 5th 07, 09:33 PM posted to rec.aviation.ifr
Brad[_1_]
On Mar 3, 11:22 am, Ron Rosenfeld wrote:
KAUG AUGUSTA STATE
BUT,
adequate.
issued it.
Thanks for letting me know about this Ron. I'm working with folks
associated with the NOTAM office to correct this. I'll report back
when I hear more.
Old March 6th 07, 01:54 AM posted to rec.aviation.ifr
Ron Rosenfeld
KAUG AUGUSTA STATE
BUT,
adequate.
issued it.
when I hear more.
Great. Thanks.
So far I've spoken with people who issue GPS Notams (in OK), regular Notams
(in or near DC); flight standards near Boston and flight procedures (I
think in Atlanta). No one seems to know -- several have said they are
looking into it. The most logical theory is that it was issued a long time
ago as a D-Notam, perhaps even before (or in spite of) current published
guidance.
My guess is that it should be changed from OTS to UNREL, as GPS WAAS
signals are flaky in Maine, in general.
I've seen it there for a long time, but did not feel the impetus to call
and investigate until after flying the approach (which I did VFR) and
finding the signal to be good.
Do you have a position with the FAA, Brad?
Old March 6th 07, 04:03 AM posted to rec.aviation.ifr
Brad[_1_]
KAUG AUGUSTA STATE
BUT,
adequate.
issued it.
when I hear more.
Great. Thanks.
guidance.
Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA)- Hide quoted text -
- Show quoted text -
I'm a contractor working with implementation for the WAAS program.
I've sent an email to the NOTAM specialist on the team.
With some recent system enhancements, coverage in ME is much better
now. For a real-time snapshot of WAAS coverage, check out the
following link:
http://www.nstb.tc.faa.gov/vpl.html
Brad
Old March 6th 07, 12:10 PM posted to rec.aviation.ifr
Ron Rosenfeld
following link:
Brad
I see. Thanks.
I'm aware of that web site, and find it quite useful. Unfortunately, it is
not unusual for me to lose vertical guidance on the approaches into my home
base KEPM (far eastern ME).
It is also not uncommon to see the LPV line at that site excluding most of
ME.
Any chance this will improve in the near future?
Thanks.
--ron
Old March 6th 07, 12:14 PM posted to rec.aviation.ifr
Ron Rosenfeld
following link:
Brad
Also, I just checked the web site now (6 MAR 07 12:06:17 GMT on the chart)
and the RED line excludes the eastern half of MA, almost all of VT, all of
NH and all of ME!
Old March 6th 07, 07:38 PM posted to rec.aviation.ifr
Jon
The biggie being the new 3rd GEO, I presume, Brad?
following link:
Brad
NH and all of ME!
I can go back and check, but I'm believe the time the NOTAM was issued
correlates fairly
closely with the re-positioning of the GEO performed last year.
Note that KAUG is one of the locations which has the Inverted-W on the
approach. This means
(among other things related to flight planning) that Predictive NOTAMs
for it are not issued. They
can't be since they're not run through the model.
Regards,
Jon
Old March 6th 07, 08:04 PM posted to rec.aviation.ifr
Jon
KAUG AUGUSTA STATE
BUT,
adequate.
I believe you may still shoot the approach if the receiver indicates
it's available. The NOTAM
simply prevents you from flight planning on it.
This is not surprising as you up near the edges of the current Service
Volume, where the availability
tends to be more sensitive. Once the reference stations to the Great
White North of you become
operational, you should see much better availability. Maybe even an
LPV-200 approach published up
there sometimes after that.
Regards,
Jon
OSH NOTAM question Dan Luke Piloting 1 July 23rd 05 03:48 PM
KLEW vs. KAUG Andrew Gideon Piloting 4 April 16th 05 05:56 AM
GPS PRN NOTAM Ali Ghorashi Instrument Flight Rules 7 February 4th 05 07:40 AM
AF/D's and NOTAM Andrew Sarangan Instrument Flight Rules 9 January 19th 04 09:19 PM
ILS Notam question John Clonts Instrument Flight Rules 6 August 22nd 03 11:53 PM
