Handheld Transcievers
Old March 5th 07, 08:51 PM posted to rec.aviation.piloting
Ken Spencer
Default Handheld Transcievers
Not sure if this is the best group to post this in, but I am trying to
decide between the Vertex 710 and the ICOM A-24 LilIon handheld
transcievers. Sporty's specs show the Verte as having a 15 hour
battery life, and the ICOM NiMh as 6 hours or so.
Do any of you have experience with either of these units?
thanks,
Ken
for email response remove "ECM" from my email address:
Old March 5th 07, 10:16 PM posted to rec.aviation.piloting
tjd
I recently had the same question (also considered the Vertex Pilot
III) and for all the research I did, it seems like pretty much a toss-
up. In the end I got an A24, and I've been happy with it. BTW, you
can get the A24 with Li-Ion as well though it costs more. Battery
life hasn't been an issue but I've only used it for checking ATIS on
the ramp and listening to the planes flying over my house - its
primary purpose is just as a backup but I haven't yet tried it in-
flight. I also bought the battery pack that you put standard AAs in
(of which I have plenty in my flight bag) in case I ever need it but
forgot to charge it.
If you can find a shop where you can play with both of them, I'd do it
and see which one you like better. I still have never seen a 710 in
person. I think the A24 is reasonably easy to use - I'd change a few
things if I could but no major complaints. But, in general I don't
think you can go wrong either way; if they were the same price I'd
have flipped a coin but the A24 was a bit cheaper so it won out.
todd.
Old March 6th 07, 12:53 AM posted to rec.aviation.piloting
Kyle Boatright
"tjd" wrote in message
todd.
One thing to be aware of if you plan on using it in flight in conjunction
with your headsets. You need a $10 push to talk switch if you want to use
your headset's microphone.
KB
Old March 6th 07, 02:04 AM posted to rec.aviation.piloting
BT
we use the A-24s for glider ground operations.. last well beyond the 6 hours
on a regular charge
our "special" when we bought included both the NiMH and the LiION batteries.
I've owned an older A-22 for over 8 years, sued every weekend for periods of
greater than 6 hours, the original NiCD battery had to be replaced after 2
years. The NiMH replacement has lasted ever since.
Another member had one of the older (early model) Vertex radios and sent it
back within a few months.
BT
"Ken Spencer" wrote in message
thanks,
Ken
Old March 6th 07, 06:22 AM posted to rec.aviation.piloting
tjd
At least on the A24 that is not true; I just tested to make sure.
With a headset (and its mic) connected via the adapter, the behaviour
is the same as it is without a headset attached - you push the PTT key
on the unit to transmit. I don't own the external PTT switch but it
would appear to just be in parallel with the builtin one - possibly
more convenient but not required.
todd.
Old March 6th 07, 07:10 AM posted to rec.aviation.piloting
Hmmmm. I was fiddling with an ICOM IC-A5 a while back. I found that when you
used the radio-mounted PTT switch, *both* microphones were live...the one in the
headset, and the one on the radio itself. With the external PTT switch, only
the headset microphone was live.
Don't know if the A24 is the same, but it would be worth testing out. The
radio-mounted microphone won't be noise-canceling like the headset mike.
Old March 6th 07, 05:59 PM posted to rec.aviation.piloting
Brian[_1_]
on a regular charge
BT
thanks,
Ken
- Hide quoted text -
- Show quoted text -
That was my exprience as well I have an ICOM A-3 and the glider
operation where I was instructing was using the Vertex Radios. It
seemed to me that the Icom was more reliable and had better sound
quality.
Brian
CFIIG/ASEL
Old March 6th 07, 08:02 PM posted to rec.aviation.piloting
tjd
that's an interesting point, I didn't check that in my test, but
opening both mics would make it a lot harder to xmit cleanly. I will
give it a try when I get home, plus it looks trivial to make your own
external PTT switch so I'll try that too.
Old March 7th 07, 01:44 AM posted to rec.aviation.piloting
Blueskies
My Vertex Pilot 210 is wonderful, 5x5 every time, rugged and water proof. The batteries last (NiMH) a long time also.
Just another data point.
which handheld gps? houstondan Piloting 28 January 28th 05 10:38 AM
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Handheld PC Toks Desalu Piloting 19 May 15th 04 01:52 PM
Q:VXA-210 Handheld Frank Ivo Streckebein Owning 8 February 20th 04 08:54 PM
Q:VXA-210 Handheld Frank Ivo Streckebein Products 8 February 20th 04 08:54 PM
