KAUG Notam Question
Old March 7th 07, 09:49 PM posted to rec.aviation.ifr
Dan Luke
Default KAUG Notam Question
"Jose" wrote:
One of the changes was adding an
extra heat muff (done via a logbook entry, by the way).
You can write "heat muff" in your logbook and make the airplane warmer?
Wow! Can I get more horsepower and better fuel economy that way too?
My buddy Brent got a big "Hawk XP" decal on the fin of his 160 HP Skyhawk
when he had it painted.
Claims it gives him 100 FPM better ROC.
Dan
C-172RG at BFM
Old March 8th 07, 11:41 AM posted to rec.aviation.ifr
Ron Rosenfeld
Every little bit helps!
I think it depends on how you do it g
By the way, as of last night, that errant KAUG WAAS Notam is no longer in
the system!!
Old March 8th 07, 02:43 PM posted to rec.aviation.ifr
Jon
On Mar 7, 4:06 pm, Ron Rosenfeld wrote:
On 7 Mar 2007 07:54:54 -0800, "Jon" wrote:
I just got a ahold of someone who indicated the NOTAM does indeed need
to
and shall be removed. Now that the 3rd GEO is commissioned, the
availability
in the NorthEast is good enough once again.
Personally, though, you'd have to be nuts to fly in the cold of the
last couple of days,
unless you have some way of taking the heat directly off the engine
block!
I guess between all of us bothering various Feds, someone finally got to
someone who could make the decision to remove!!
No bother at all, Ron. When a thread comes along that actually applies
to what I do for work, I want to find out what's going on and see
about resolving the issue(s) if I can.
All of this stuff doesn't mean anything if the end user can't benefit
from it. Y'all could just stay home, simulate flight, and order the
$100 burger for delivery, right?
If the OTS was "properly" issued, because of the satellite being moved, it
does not make sense that it should only apply to a single airport in ME;
especially with our generally poor coverage (even after the new satellite
deployment) and also given the guidance published in 2003.
I'll see what I can find out regarding edge-of-coverage issues. It
comes down to where the "line is drawn", so to speak, but you bring up
a good point regarding KAUG being singled out. Was it the only one? I
haven't had time to look up if there were other locations at the edge-
of-coverage which also had vertical approaches.
An "unrel" Notam would have been proper, even then.
Perhaps. My best guess here is that a) the availability was so poor,
they felt it better to be safe and disable it entirely and b) to avoid
potential confusion, they decided not to use the UNREL contraction for
this purpose.
I have spent years, by the way, to try to get sufficient heat into my a/c
to fly this time of year. I still have some drafts to seal up, but it's
better this year than it's ever been. One of the changes was adding an
Flying this time of year is amazing so far as performance is concerned! If
I can preflight in a hangar, I'm good.
Are you based up in ME or were you just flying there?
Regards,
Jon
Old March 8th 07, 09:51 PM posted to rec.aviation.ifr
Ron Rosenfeld
to
availability
block!
Well, it seems it worked. Thanks.
KAUG was the only one that I recall that had the OTS Notam. And yes, there
are other approaches that have vertical guidance that are "further out"
than KAUG. KPQI comes to mind with an LPV approach. KPSM also has LPV
approaches, but I don't know if it is "further out". And, of course, there
are several, including KEPM, with LNAV approaches with "advisory vertical
guidance".
this purpose.
I don't know -- but there were other airports further out of coverage which
did not get the OTS NOTAM, to the best of my recollection. In any event, I
don't believe OTS was ever defined for a WAAS Notam.
Primary base is KEPM -- Eastport, ME. I do a lot of flying between KASH
and KEPM as we have a second home in NH near some of our kids.
Old March 9th 07, 01:54 PM posted to rec.aviation.ifr
Brad[_1_]
On Mar 3, 11:22 am, Ron Rosenfeld wrote:
KAUG AUGUSTA STATE
04/001 - WAAS LPV WAAS LNAV/VNAV OTS WIE UNTIL UFN
This Notam has been posted, well, since April.
Sorry I haven't replied sooner but the NOTAM was canceled on the 7th.
Just a few clarifications on WAAS notams, which are actually explained
in the chapter 1 section 1 of the AIM. WAAS unavailable NOTAMs
indicate loss or malfunction of the WAAS system. In flight, Air
Traffic Control will advise pilots requesting a GPS or RNAV (GPS)
approach of WAAS unavailable NOTAMs if not contained in the ATIS
broadcast.
WAAS unreliable NOTAMs indicate an expected level of service, e.g.,
LNAV/VNAV or LPV may not be available. In flight, Air Traffic Control
will not advise pilots of WAAS unreliable NOTAMs, and they are
generally not offered by FSS unless requested.
When the approach chart is annotated with the inverse W (not inverted
W, Jon! That's an 'M' ha!), site-specific WAAS unreliable NOTAMs or
Air Traffic advisories are not provided for outages in WAAS LNAV/VNAV
and LPV vertical guidance.
Safe flights!
Brad
Old March 9th 07, 07:43 PM posted to rec.aviation.ifr
Ron Rosenfeld
KAUG AUGUSTA STATE
broadcast.
Safe flights!
Brad
Yes, thanks. I noticed the cancellation. And the information you post
from the AIM is the same as was posted in guidance back in 2003. As you
note by omission, OTS is not described with regard to a WAAS NOTAM.
Best wishes,
Old March 19th 07, 01:43 PM posted to rec.aviation.ifr
Jon
to
availability
block!
guidance".
I spoke with someone this morning, and it turns out there actually
were 5 locations which had been NOTAMed out. It's now looking like the
cancellation for KAUG should have been handled the same as the others,
but wasn't.
this purpose.
Since they were apparently canceled much sooner, they may have not
been in the system all that long. Unless you were checking often
(presumably last year as well), you might have not ever seen them.
When I get some time, I can try to get access to the archives to find
out details on the lifetime of the other NOTAMs. Depending upon how
long ago they were canceled, it may not be trivial (USNS only journals
for a few months).
In any event, I don't believe OTS was ever defined for a WAAS Notam.
I concur and will try to raise it as a discussion point.
Nice. I've done a bit of camping/hiking in NH (mostly White Mountain
area, but get up to Fryeburg on the ME border once). I imagine it's
quite scenic from the air as well, esp. around peak color time in the
fall.
Regards,
Jon
  #28
Old March 19th 07, 05:53 PM posted to rec.aviation.ifr
Ron Rosenfeld
fall.
We once landed at Fryeburg on a peak color day. It was practically a
religious experience.
OSH NOTAM question Dan Luke Piloting 1 July 23rd 05 03:48 PM
KLEW vs. KAUG Andrew Gideon Piloting 4 April 16th 05 05:56 AM
GPS PRN NOTAM Ali Ghorashi Instrument Flight Rules 7 February 4th 05 07:40 AM
AF/D's and NOTAM Andrew Sarangan Instrument Flight Rules 9 January 19th 04 09:19 PM
ILS Notam question John Clonts Instrument Flight Rules 6 August 22nd 03 11:53 PM
