Glider computers - what's important?
Old March 8th 07, 04:29 AM posted to rec.aviation.soaring
Default Glider computers - what's important?
I have a datalogger, I have an IPAQ, and I have all the cabling etc.
I have spent considerable time at Cumulus Soaring, reading the
comparisons of glider software. What I lack is the experience to know
what is important. I've played with the features of SeeYou Mobile,
and frankly, most of the high end graphics stuff on the map just makes
it hard to read.
Many of you on this list have flown with this stuff, and done some
sorting out. I tend toward simpler and easier to use, rather than
bleeding edge, "every bit of information you could possibly want"
tools.
The only thing that is a go-nogo for me is a graphical display of
landing areas within glide under current conditions - a feature most,
if not all, seem to have.
Oh, another factor: a friend purchased WinPilot, SeeYou, and
StrePla. He's become used to WinPilot, and has offered to GIVE me
StrePla. Can it be set up so "Even a Caveman" can use it?
Thanks,
Old March 8th 07, 04:42 AM posted to rec.aviation.soaring
ContestID67
Nothing is very easy about the soaring programs which run on the
PDAs. People tend to purchase what their flying pals use. Tribal
knowledge is good but may be costly if you purchase something you
really don't like. I'm with you, all the bells and whistles look
great, an may be good for the very accomplished pilots, but for little
old me?
One thought is to get one of the free soaring programs and try those
for a while. Get your feet wet so to speak. Another idea is to go
with a minimalist program like Glide Navigator II which isn't too
expensive.
Good luck, John
Old March 8th 07, 07:41 AM posted to rec.aviation.soaring
Marian Aldenhövel
Hi,
What I lack is the experience to know what is important.
Same for me. I can only second John and suggest you try one of the free
packages (for you that may include StrePla :-)).
I spent some quality time with my PDA and XCSoar[1] yesterday. Installation
was quite straightforward and maps and datafiles for germany easily found. I
drove the software from the NMEA-Generator found at [2].
I also did the same with GPS_LOG[3]. I even had two flights with the software
last summer, but not long enough to give a really well-funded opinion.
Overall I like XCSoar a little bit better now. Out-of-the-box it seems to do
a better job at automatically selecting and displaying useful information.
Especially regarding your requirement:
In GPS_LOG you have to explicitly select "Get Landing site" to view a list
of options.
XCSoar has landing sites marked in the main map, highlighting those that are
reachable and showing at what altitude you will be arriving. You can tap
the magenta dot and be given detail information about the landing site. This
works with fat finger on IPAQ display, not only with pen and exact aiming, so
I guess it should be doable in the cockpit.
Both take current conditions into account including wind. Both can derive
wind (at least) from GPS fixes while circling.
Using a simulator (not necessarily a FLIGHT simulator), is a good and safe
way of getting acquainted. You have to fiddle with the knobs in the atlsoft
generator a lot to simulate live air, but even if you don't a lot of the
features of the programs become apparent.
makes it hard to read.
Both free programs can be fine-tuned to your liking in that regard. In XCSoar
it is quite easy to switch the display of labels, terrain and topography
in-flight
Ciao, MM
[1] http://www.xcsoar.org
[2]
http://www.atlsoft.de/index.php/GPS%.../kat/74/menu/1
[3] http://www.soaringpilotsoftware.com/GPS_LOGpage.htm
Marian Aldenhövel, Rosenhain 23, 53123 Bonn
http://www.marian-aldenhoevel.de
"Success is the happy feeling you get between the time you
do something and the time you tell a woman what you did."
Old March 8th 07, 10:08 AM posted to rec.aviation.soaring
alex8735
I have found the Condor soaring simulator to be a great way to test
PDA software. I find it far more effective than the demo modes most
software has. It comes very close to the real thing. You can simulate
all kinds of situations and actually test how the PDA reacts. It also
has the advantage of having to concentrate on flying the simulator as
well as working with the PDA - just like in real life. This shows bad
usability far more quickly than pure demo modes.
Old March 8th 07, 12:12 PM posted to rec.aviation.soaring
1SL
One of those free programs is SoarPilot. It's got a dedicated following,
is comprehensive and is well supported by its creators.
You can read all about it here...
http://www.soaringpilot.org/dokuwiki/doku.php
And you can download it here...
And you can see the "support group" here...
http://tech.groups.yahoo.com/group/soaringpilot/
old me?
expensive.
Good luck, John
Old March 8th 07, 12:30 PM posted to rec.aviation.soaring
Your friend may have inadvertently shortened your choice list, if he
kept the other 3 for himself.......
Simpler and easier do not exist, it's the nature of the software
richness and flexibility.
Ask the guys you fly with what they chose, they will be the ones to
help you in times of confusion.
If you already have desktop software for flight planning, get the
flight software which most easily shares the waypoints, terrain, etc.
set up on the desktop. And always spot check any transferred data for
accuracy. I learned that early with shareware solutions. In flight the
software products have equivalent functions, ease of use and their
data interface then become more important.
SeeYou Mobile lets you turn off any display feature which irritates
you, as do the others I'm sure. Keep in mind it has 2 map displays and
each is configured separately for whatever use you want to make of
that. Cruise with one map, thermal on the other.
Do you fly in various locations? Sharing the ship? Find the one that
lets you easily change sets of waypoints and airspace, terrain, etc.
The 'Profile' feature in SeeYou is quite good at managing named sets
of related files on the PDA and retaining personal display preferences
for multiple pilots.
Software locked to a hardware serial number is not as flexible in
'hardware failure recovery mode' as those which are not. A nit.
Keep ALL your data on SD or CF. And take a copy of that regularly.
Losing PDA power wipes memory, so have everything on external media.
Take regular PDA backups to both SD and desktop. I had an SD card
fail, it's ugly.
Keep your eyes out of the cockpit.
Old March 8th 07, 02:46 PM posted to rec.aviation.soaring
Bill Daniels
"alex8735" wrote in message
I second the suggestion of Condor. It also works to output NMEA data from
SeeYou in animate mode so the PDA displays just what it would have during
the real flight.
In general, people tend to like the PDA software they know best. Simulators
let you get to know them all.
Bill Daniels
Old March 8th 07, 02:48 PM posted to rec.aviation.soaring
CLewis95
Though Condor does simulate flight PDA computer software on-screen,
I'd like to point out/clarify that Condor allows you the option to
integrate a "REAL" PDA with the PC running the simulator. You are
actually manipulating your physical PDA (running "real" XC software)
on your desk the same as you would in flight. I can't imagine a
better training aid for today's PDA XC soaring software. One might
justify the cost of Condor on this alone....besides being a fantastic
racing simulator.
Curt Lewis - 95
Old March 8th 07, 03:32 PM posted to rec.aviation.soaring
Richard[_1_]
James,
I sell both WinPilot & SeeYou. I have found after 5 years of
consulting on and selling PDA programs that:
1. They are as easy to use and learn as any flight computer or logger
and offer many more functions. It does require some time to learn
and you do have to read the manuals. If you install any flight
computer or PDA system in your glider and then expect to immediately
fly with it without the required learning you will be dissapointed.
2. The PDA systems allow you to learn almost anywhere, work, home, in
the back yard, on the sofa. The simulator programs in the software
allow you to do this on your PDA. WinPilot and SeeYou are fully
functional in the SIM mode.
3. I recommend that you bring up the manual for the program on your
desktop computer and with the PDA in hand go through the manual one
time. This at least this gives you an overview of what is available
in the program. And helps you learn the program. This can be done
with either program and does not require purchase.
4. As always I am reachable on the phone, most all the time, and if
not will return your call. Days, evenings and weekends. Usually it
is a simple thing to get you out of a jam. So a call will with PDA in
hand will save much time and frustration.
5. The hardest thing for most people is learning the file structure in
your desktop Windows PC, this is required with any flight computer,
logger or PDA system. It is not specific to PDA Systems. I spend
more time with people on this that the actual programs.
6. Free is a very good price, but generally you get what you pay for,
if anyone finds this not true please let us all know so we all can all
get this free stuff. The best free thing I have found is the SeeYou
Connect Me program.
Richard
www.craggyaero.com
it hard to read.
tools.
Thanks,
Old March 8th 07, 03:54 PM posted to rec.aviation.soaring
Tuno
The problem with this is that Condor terrain data sets don't exist
anywhere near the places I fly, and my PDA doesn't have any data for
the places Condor does have. (You can, of course, load up the PDA
data.)
If you're lucky and the terrains overlap, it's a great tool!
~ted/2NO
Cambridge computers Solo Soaring 5 January 7th 07 04:37 AM
SeeYou and Mac computers Nyal Williams Soaring 8 July 14th 06 02:09 PM
Website for Aero\PC computers? JJ General Aviation 0 January 31st 05 05:50 PM
FS slide rule flight computers Aviation Marketplace 0 April 19th 04 03:35 PM
FS slide rule flight computers Military Aviation 0 April 19th 04 03:29 PM
