Hypothetical ?? About Licensing
Old March 9th 07, 01:45 AM posted to rec.aviation.piloting
Kyle Boatright
Default Hypothetical ?? About Licensing
Several years ago, I was offered a warbird ride by one of the old timers at
the airport. So, of course, I took him up on it and had a great time riding
around in the front seat of an open cockpit biplane.
Now that the person has moved out of the area, I've been told by his friends
that A) He flunked his medical years ago and never got it back and B) His
aircraft, while probably safe, probably didn't have a valid annual.
OK, since the statute of limitations is presumably up and my flight with him
probably isn't verifiable anyway, I figure I'm free and clear of any
problems.
But, let's just say that either A) We got ramp checked on landing or B)
There was an accident with him flying the airplane (but w/o a license) and
yours truly riding along.
What would my exposure have been to enforcement action from the FAA, given
that I had every reason to believe that everything was on the up and up???
KB
Old March 9th 07, 02:16 AM posted to rec.aviation.piloting
Jim Stewart
problems.
As long as he fessed up to being PIC,
I can't imagine you could be blamed
for anything. The regs seem pretty
clear to me that it's the PIC that's
responsible for all of those issues.
Old March 9th 07, 03:39 AM posted to rec.aviation.piloting
Capt.Doug
"Kyle Boatright" wrote in message
Check out the co-pilot's statement in this NTSB factual report-
http://www.ntsb.gov/ntsb/brief2.asp?...MIA06LA108& a
key=1
"The ACM reported that when the flight was approximately 3 miles north of
KFXE, "..we began having problems with one of the engines." The pilot then
began troubleshooting procedures for the engine, and shortly thereafter, "we
began experiencing problems with both engines simultaneously." The pilot
declared an emergency, and he (ACM) glanced at the fuel gauges and they were
indicating approximately 10-15 gallons of fuel remaining. The pilot
immediately turned towards the destination airport but "...we were unable to
make the field and decided to land on the road ahead of us." The ACM further
stated that specific details from him of what occurred are not available due
to the fact that he had never before been in a Cessna 414 airplane;
therefore, he was "...very unfamiliar with this type of aircraft."
The ACM in this report would be equivilent to you in your hypothetical
situation. He was requested to submit a report. He never heard anything more
about it.
D.
Old March 10th 07, 12:09 AM posted to rec.aviation.piloting
Robert M. Gary
problems.
It depends on the certificate level you hold. If you are a private,
the FAA probably won't question you. However, if you are a CFI you
will likely be held responsible even if you were sleeping in the back.
The FARs talk a lot about PIC, but I've not seen that the FSDO holds
PIC to be as important when looking at enforcement, they tend to take
the "higher certificate".
-Robert
Old March 10th 07, 04:34 AM posted to rec.aviation.piloting
Andrew Sarangan
problems.
KB
As far as I know there is no requirement for passengers to show
identification if ramp checked. You should be able to simply walk
away even if you happen to be a pilot. A problem would arise if the
PIC denies responsibility and points the finger at you. Then the next
logical choice would be for the FAA to check the aircraft documents.
If the airplane is registered in his name, and if airport records can
verify that he is the one who regularly flies that airplane, I think
this would be an open and shut case.
Old March 14th 07, 12:59 PM posted to rec.aviation.piloting
Ron Natalie
They attack the person who can be harmed the most by the certificate
action. This includes CFI's and any other working pilots
(ATP/Commercial pilots who actually are earning a paycheck).
Gyro's and Licensing TM Rotorcraft 0 December 31st 06 01:56 AM
licensing for homebuilts Tater Schuld Home Built 24 February 27th 06 11:55 AM
B-17s in Pacific during WW2 hypothetical [email protected] Naval Aviation 19 November 10th 05 04:45 PM
BGA and licensing Mark James Boyd Soaring 6 August 24th 04 03:16 AM
Hypothetical AC-130 replacement Matt Wiser Military Aviation 30 February 26th 04 03:23 PM
