Rudder cable - was The Little Wheel in Back
Old September 9th 03, 06:36 PM
BD5ER
Default Rudder cable - was The Little Wheel in Back
Asking a question and taking this thread off on a tangent:
Been thinking about using some Spectra for rudder cables. Other than the
obvious poor heat tolerance, which shouldn't be a factor in my case for rudder
cables, what other problems, ecpected or unexpected, might I encounter if I
were to experiment in this manner? Abrasion, stretch, creep, and attachment
methods have already been considered.
Anyone already using Spectra for control cables?
Now I'm really curious. Saw some stainless steel cable at the tractor
supply the other day for about $1 foot. 1/8" and looked to be about 9
cords, each with 7 wires. Is there a difference between the steel cable
found at the tractor supply and what AS&S ships?
Biggest difference is probably the per-foot marking on the price tag.
that is a dangerous complacency.
aircraft wire has more wires in each "chord" to reduce the effects on
cable strength of wear through the pulleys and guides.
7 chords by 19 strands is the usual aircraft stuff.
Actually, aviation cables come in a variety of layouts, depending upon the
usage of the cable. First number is the number of strands, second number
is the number of wires in each strand. You can multiply the numbers to
determine the number of individual wires in a given cable... so 1/8" 7x19
cable has 133 tiny wires, and 1/8" 1x19 has nineteen rather thick wires.
Obviously, tiny wires are going to bend easier than thick wires. So the
7x19 cable is going to be more flexible than the 1x19. But it's going to
be more sensitive to friction; those little wires are going to wear through
faster than the thicker ones. But that stiff 1x19 is going to present more
problems when trying to form it around a thimble.
Fly Babies use both types... 7x19 cables for the rudder, and 1x19 cables
for the bracing wires.
Old September 10th 03, 04:33 AM
BD5ER
Yes. The Sparrowhawk ultralight sailplane.
http://www.windward-performance.com/
Thanks for the info. Sometimes it's nice not to have to invent the wheel.
Guess I'll have to look into it.
Old September 10th 03, 03:08 PM
Ernest Christley
Tim Ward wrote:
"BD5ER" wrote in message
rudder
I
Tim Ward
What is Spectra, and what advantage does it have over steel cable?
----Because I can----
http://www.ernest.isa-geek.org/
Old September 10th 03, 04:28 PM
Tim Ward
"Ernest Christley" wrote in message
. com...
rudder
if
I
Tim Ward
It's ultra high molecular weight polyethylene (UHMWPE).
For a given diameter, it's stronger than steel, and much, much lighter.
Tim Ward
Old September 10th 03, 04:48 PM
Barnyard BOb --
Tim Ward
My first experience years ago with Spectra...
was with fishing line. Not cheap.
Genuine modern miracle space age stuff.
Barnyard BOb --
Old September 10th 03, 08:55 PM
BD5ER
Sounds like a solution to a non-existent problem.
Rich "To save an ounce, lose a hamburger" S.
That weight reduction program is well underway. Hamburgers are in, just no
carbs.......and the weight savings is already many times greater than all of
the carbon and Spectra combined will save.
I agree there isn't much of a "problem" to be solved. Still, I like the idea
of something a bit different, otherwise I'd have just bought a 172.
Old September 10th 03, 09:33 PM
Dave
We use it in the skydiving industry for canopy lines. It appears to be
very strong and abrasion resistant. The lines aren't much different in
size than tooth picks. 500 or 800 pound test.
The only problem is, it shrinks when heated. The line sets on our
parachutes need to be replaced every so often because of abrasion heat.
Usually around 500 jumps or so.
Should not be a problem in most aircraft.
Also, UV can hurt the strength of the line.
Dave
Old September 11th 03, 12:20 AM
Rich S.
no
of
idea
You need some of that stuff that was featured in "Fountains of Paradise" by
Arthur C. Clarke.
Rich S.
Old September 11th 03, 09:51 AM
Corrie
"Rich S." wrote in message ...
idea
Arthur C. Clarke.
The space-elevator cable stuff? Welcome to the 21st century - it's
not quite unobtanium anymore. It's available (or soon will be) at
your local Nano Depot in the Buckytubes aisle. Carbon filaments made
of stacks of rings of carbon atoms. Tensile strength that makes steel
look like wet tissue. Now if you could only get it in lengths greater
than .01 mm ...
Corrie
Old September 11th 03, 05:14 PM
Rich S.
"Corrie" wrote in message
om...
than .01 mm ...
Yeah - that's it. I'd like it at least 3-4" long for a cheese slicer.
Rich S.
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
The Little Wheel in Back Veeduber Home Built 6 September 8th 03 11:29 AM
