XM weather - anyone using it?
Old March 10th 07, 06:11 AM posted to rec.aviation.soaring
Eric Greenwell
Default XM weather - anyone using it?
Is anyone using XM weather in a glider? If so, what system are you using
to get it, and how is it working out? What features are useful?
Or, is there anyone using it in an airplane, and thinks it would be
great to have in a glider?
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old March 10th 07, 07:17 AM posted to rec.aviation.soaring
bumper
Eric,
I started out using the XM weather "lite" package on my Garmin 396 in the
Mooney. The lite package costs $29 a month, but does not include lightning,
winds aloft, storm cells, cloud tops and more. After upgrading to the $50
full weather package for a trip (you can enable for a month and then cancel
again for no start-up fee), I was so impressed I just kept the full weather.
At first, I figured I'd continue to use the 196 in the glider, due to its
lower current drain and easy to see mono screen. But after getting used to
having the weather data, I started using the 396 in the glider. Love it.
Going cross country, you can see bands of lightning strikes and precip and
route accordingly. Winds aloft is great, and you can scroll to different
altitudes. TFR, METARS, TAFs, current altimeter from nearest weather source,
and lots more.
The 496, came out after I bought the 396, even has the complete AOPA
database with airport diagrams on board.
bumper
news:WZrIh.44$Hb6.21@trndny03...
Or, is there anyone using it in an airplane, and thinks it would be great
Old March 10th 07, 01:58 PM posted to rec.aviation.soaring
Andy[_1_]
I have a Garmin 396. I also had the lite weather, upgraded to full
for Oshkosh last year and have not reverted to Lite. The winds aloft,
cloud cover, and storm cell depictions were very nice to have on the
return from Oshkosh to Phoenix.
I have not used it in the glider mostly because I didn't do much
soaring last year. I think its use in contests is prohibited, but I
think it would be very helpful for non contest XC.
The Garmin XM antenna is a power hog though. You can run the 396 all
day on batteries without it but you need external power if the XM
antenna is connected. I have found no way to turn off the antenna and
leave it connected.
Andy
Old March 10th 07, 04:42 PM posted to rec.aviation.soaring
I've heard of the GMX30(A) being a power hog from a few owners. Has
anybody measured how much power it (or the GPS+GMX30A combination)
consumes? Numbers for 12 volt external power draw with a fully charged
GPS battery and a flat GPS battery would be great ...
Thanks
Darryl
leave it connected.
Andy
Old March 10th 07, 05:16 PM posted to rec.aviation.soaring
Eric Greenwell
leave it connected.
One can also get XM weather using a PDA and Anywhere Weather. It's much
cheaper solution than a 396, and could serve as a backup soaring
computer. Possibly, one could switch between the two programs and get by
with only one PDA in the cockpit. I don't know what draws for power. Can
anyone comment on Anywhere Weather?
Old March 11th 07, 02:38 AM posted to rec.aviation.soaring
RL
For slightly different approach I use Pilot My-Cast on my mobile phone
(not a cell phone as mentioned in previous discussions).
https://secure.my-cast.com/pilot.jsp
It works very well in both the glider and the C-172 and I've found it
routinely useful in keeping up to speed on changing weather, dodging
scattered precip, etc. The Sat images are particulary good for an in-
flight snapshot of conditions.
Bob
Old March 12th 07, 08:39 PM posted to rec.aviation.soaring
Eric
WX Worx spec the receiver as 1 amp at 9 volts. Ouch. The Manual for
Anywhere Map XP warns the same XM antenna draws over 1 amp.This seems
to be the most popular (only other portable?) non-Garmin XM Weather
receiver.
The other problem is visibility of the map displays. On my iPAQ 4700
running SeeYou Mobile my 40+ year old eyes can barely see anything at
maximum backlight unless I turn off terrain so the background is
white. I can't think how bad trying to look at XM weather cloud tops
or Nexerad might be. And I've go a very good PDA mount position with
the PDA close to me, angled to minimise sky reflections and using a
cleartouch screen protectors (which improve thigns slightly). I know
peoples contrast tollerance with transflective displays varies a lot
but still I coudl not imagine trying to look at this stuff on my PDA
display.
Again, it would be geat if anybody has power consumption numbers for a
Garmin 396 or 496 with and without the XM weather antenna operating.
Ideally also with internal battery charging and internal barttery
fully charged. I've asked Garmin for this information as well. As far
as I know there is also no way to set the backlight to timeout on the
396 or 496 while it has external power. So these numbers should
ideally be at whatever backlight setting makes the display reasonably
daylight readable.
BTW the WX Worx bluetooth antenna would be really nice, having to run
another cable for the Garmin antenna is a pain.
Darryl
leave it connected.
* "Transponders in Sailplanes"http://tinyurl.com/y739x4
* "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org
Old March 12th 07, 09:05 PM posted to rec.aviation.soaring
I clicked send to fast, I also had meant to add that Garmin's specs
for the GXM-30 and GXM 30/A XM antennas state that the antenna alone
consumes 4.5 Watts at 4.5 to 5.5 VDC (i.e. about 0.4 amp equivalent at
12 volts). Not insignificant ( a good transponder) anecdotely it
seems that the XM antennas (plus overhead on the GPS unit?) consume
more than this so some real world measurments of the total draw at 12
volts of the GPS and antenna would be great.
Thanks
Darryl
On Mar 12, 1:39 pm, "
Eric
receiver.
display.
daylight readable.
Darryl
leave it connected.
Old March 13th 07, 03:18 AM posted to rec.aviation.soaring
bumper
Darryl,
Have a look at
http://www.dvatp.com/aviation/reviews/garmin_396/
About a page or so down in the review, he gives the current draw under
various conditions. Probably not as much data as one could hope for, but
usable. Bottom line is you can expect current draw of from about 500 mills
to as much as 900 milliamps.
bumper
Thanks
Darryl
Eric
receiver.
display.
daylight readable.
Darryl
aloft,
and
leave it connected.
by
Can
Who got hit by weather? john smith Piloting 41 December 6th 06 01:30 PM
Anywhere Weather smf Instrument Flight Rules 2 March 8th 05 05:41 PM
Warm Weather Pilots, Cold Weather Ops john smith Piloting 3 December 2nd 04 04:00 PM
PDA Weather David Rind Piloting 1 July 12th 04 05:19 PM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 04:03 PM
