#41
Eric Greenwell wrote:
Bill Daniels wrote: A "glide footprint" shows clearly how to cross a mountain range since it computes glide distance in all directions. The courseline may happen to cross the range at a high peak so a list type display will show the goal as unreachable but the "glide footprint" will show that a slight change in course will easily clear the terrain. I can use that feature! Use GPS_LOG WinCE. It has it. Henryk Birecki |
#42
![]() "Stefan" wrote in message . .. Eric Greenwell schrieb: landable terrain that isn't in the airport database. Just knowing that good landout options are reachable reduces stress I reduce my stress by carrying an "iron thermal"! Dangerous tactic. Your personal thermal may or may not work. Actually, Eric flies an ASH26E, so his "iron thermal" is the indescribably smooth and reliable Wankel rotary engine. It always works :c) bumper ASH26E Minden |
#43
Stefan wrote:
Eric Greenwell schrieb: landable terrain that isn't in the airport database. Just knowing that good landout options are reachable reduces stress I reduce my stress by carrying an "iron thermal"! Dangerous tactic. Your personal thermal may or may not work. It doesn't have to be perfect to be a stress reducer! I always have a good field in easy reach before I attempt to start; so far, only one failure to start out of 165 in-flight restart attempts. That's a lot less stress than 164 retrieves. For a detailed look at how I use the "iron thermal" it's advantages for the pursuit of soaring, read my "Guide" - see below for the download link. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#44
Hi,
Use GPS_LOG WinCE. I do. It has it. Can you enlighten me on on how the footprint is computed? Just by looking in a few directions, determining the "points of impact" in those directions and connecting them? Or is it more complicated? Would a single mountain on a vast plane look like an island in the glide footprint? Ciao, MM -- Marian Aldenhövel, Rosenhain 23, 53123 Bonn http://www.marian-aldenhoevel.de "Success is the happy feeling you get between the time you do something and the time you tell a woman what you did." |
#45
![]() "Richard" wrote The question is have you compared the free programs with SeeYou or WinPilot. We would all like to hear your comparison. I have compared GPS-LOG to SeeYou Mobile, and I am flying with GPS-LOG. It gives me everything I need (X-country flying, no competitions) in a way I like. It automatically switches between climb and cruise mode and displays the relevant data for each mode without any need to touch the PDA. It gives me the glide footprint on the map like discussed in another part of this thread and AFAIK it was also the first PDA software to implement FLARM voice warnings. The only advantage I see in the commercial packages is the very easy transfer of map and airspace from the desktop software (SeeYou - SeeYouMobile, .....). Michael |
#46
![]() "Marian Aldenhövel" wrote in message ... Hi, Use GPS_LOG WinCE. I do. It has it. Can you enlighten me on on how the footprint is computed? Just by looking in a few directions, determining the "points of impact" in those directions and connecting them? Or is it more complicated? It simply looks in 48 directions around the compass and computes the maximum glide in each direction considering wind, polar, McCready, balast and bugs. It terminates each glide at the 'safety altitude' you have selected. It then connects these glide termination points with a line that forms a 48 sided polygon. It does this about once a minute. Would a single mountain on a vast plane look like an island in the glide footprint? A single isolated mountain on a plain would be a "notch" in the polygon, not an island. If you know the terrain, it's obvious that you can glide around the mountain and land in the notch on the other side. Bill Daniels |
#47
On Mar 12, 5:08 am, "Bill Daniels" bildan@comcast-dot-net wrote:
It simply looks in 48 directions around the compass and computes the maximum glide in each direction considering wind, polar, McCready, balast and bugs. Plase confirm this function uses current MC. I browsed the on-line manual and I thought it said ZERO MC which is not the implementation I would want. Is anyone using the terrain functions on an Aero 1550? If so is performance adequate? thanks Andy |
#48
I would also want a user-definable reserve height of maybe 500ft when I
got there.=20 especially as this is different from a final glide to a known landing spot =20 ie consider wind, polar, mcready, balast, bugs and reserve height. =20 For those in the mountains, a computation that can cope with corners round ridges would be nice, but that is probably step 2. =20 ps: I would not plan to use my own "iron thermal" unless over landable terrain =20 =20 Rory =20 Subject: Using a "GLIDE footprint" Author: Andy mailto:Andy Date/Time: 14:40 12 March 2007 ________________________________ On Mar 12, 5:08 am, "Bill Daniels" wrote: It simply looks in 48 directions around the compass and computes the maximum glide in each direction considering wind, polar, McCready, balast and bugs. |
#49
"Andy" wrote:
On Mar 12, 5:08 am, "Bill Daniels" bildan@comcast-dot-net wrote: It simply looks in 48 directions around the compass and computes the maximum glide in each direction considering wind, polar, McCready, balast and bugs. Yes it does. 48 seemed like a good compromise between computation time and "precision". This could be made a user input parameter in future editions if there is a general concensus that it would be useful. Plase confirm this function uses current MC. I browsed the on-line manual and I thought it said ZERO MC which is not the implementation I would want. You are right about documentation. I will need to check in the code. It may well be ZERO MC as it is a "safety" feature. If you are looking for a safe place to land you want to fly at best glide angle, not best time. Anyone would like to comment? Is anyone using the terrain functions on an Aero 1550? If so is performance adequate? I am. I have not seen any problems so far, and I usually do fly in the mountains. Henryk Birecki |
#50
"Andy" wrote:
On Mar 12, 5:08 am, "Bill Daniels" bildan@comcast-dot-net wrote: Plase confirm this function uses current MC. I browsed the on-line manual and I thought it said ZERO MC which is not the implementation I would want. I forgot to add in my previous post: If you really want to have "real time" feedback in GPS_LOG for whether you can clear a mountain range on course, you would not be looking at the GLIDE footprint, but at forward looking terrain plot. This gives you glide path at your current speed, wind... plotted with the ground profile. Got me through several passes that I would have never attempted without that information. Henryk Birecki |
Cambridge computers | Solo | Soaring | 5 | January 7th 07 04:37 AM |
SeeYou and Mac computers | Nyal Williams | Soaring | 8 | July 14th 06 02:09 PM |
Website for Aero\PC computers? | JJ | General Aviation | 0 | January 31st 05 05:50 PM |
FS slide rule flight computers | Aviation Marketplace | 0 | April 19th 04 03:35 PM | |
FS slide rule flight computers | Military Aviation | 0 | April 19th 04 03:29 PM |
