I'm making an eight-foot study model of a personal lifting body
dirigible design of mine. I believe the ribs will be made of fiberglass and widely-spaced for lightness. I want the skin to be aluminum sheet. It would be desirable to avoid installing a rib for every seam between sheets of aluminum. So, I would like some advice on what is the state of the art with infallible glue joints between hard aluminum sheets. I imagine there is no alternative to crimping the meeting edges as is done when sewing two sheets of cloth together. No way am I interested in rivets. |
"dirigible designer" wrote in message
oups.com... I'm making an eight-foot study model of a personal lifting body dirigible design of mine. I believe the ribs will be made of fiberglass and widely-spaced for lightness. I want the skin to be aluminum sheet. It would be desirable to avoid installing a rib for every seam between sheets of aluminum. So, I would like some advice on what is the state of the art with infallible glue joints between hard aluminum sheets. I imagine there is no alternative to crimping the meeting edges as is done when sewing two sheets of cloth together. No way am I interested in rivets. How about using sheets that are half as thick as you need and then glue them on top of eachother with full overlap? I've used some 3M aluminum glue that is stronger than the metal itself.. Rob |
![]() "dirigible designer" wrote in message oups.com... I'm making an eight-foot study model of a personal lifting body dirigible design of mine. I believe the ribs will be made of fiberglass and widely-spaced for lightness. I want the skin to be aluminum sheet. It would be desirable to avoid installing a rib for every seam between sheets of aluminum. So, I would like some advice on what is the state of the art with infallible glue joints between hard aluminum sheets. I imagine there is no alternative to crimping the meeting edges as is done when sewing two sheets of cloth together. No way am I interested in rivets. Wow, where to start. First, I would think you need to do a reality check, here. How big will your full sized lifting body be? Figure the surface area of the full sized design, and then figure how much weight the aluminum to cover that area would weigh. Next, figure what the volume of the full sized model is, and how much buoyancy the helium in that volume would provide. I think you will find that the volume of helium in the full size model would not come close to lifting even half of the weight of the aluminum sheeting. Once you do this, and run the numbers, I think you will not even need to mess with the study model. The numbers will not work. There is a reason that balloons and dirigibles are not covered with aluminum. The areas and volumes are huge, and the only way to make it work is with ultra lightweight and strong "fabrics." As for not even considering rivets, I doubt you have any idea of the costs and technology of what it takes to join aluminum without rivets. You have friction stir welding, or glues. Friction stir is high tec and expensive to set up. Glues are temperamental, and takes many complex steps and chemicals to prep and bond the surface, and is also expensive, if you can even reach the reliability needed for such an application. I won't go into the idea of having ribs so far apart that there is not even a rib for the length of an aluminum panel. It will not have enough support to hold its shape under flight conditions. I don't want to rain on your parade, but it looks to me (from how you described your concept) that the whole idea is unworkable. If you have further explanations that could convince me (and others) differently, go ahead. -- Jim in NC |
![]() "Rob Turk" wrote in message .. . snip I've used some 3M aluminum glue that : is stronger than the metal itself.. : : Rob : : I would like to see what 3M product you are talking about... Dan D. |
Reminds me of the time when I was working on a ship, and somebody
started a kitebuilding contest. One of the engineers built one like the proverbial brick s##thouse - then put a long tail of rags on it (which got wet in a puddle on the deck), No, it didn't fly, even in a stiff breeze. He didn't have a clue - and soon got frustrated and threw the kite over the side. |
On 13 Mar 2007 14:47:13 -0700, "dirigible designer"
wrote: I'm making an eight-foot study model of a personal lifting body dirigible design of mine. I believe the ribs will be made of fiberglass and widely-spaced for lightness. I want the skin to be aluminum sheet. It would be desirable to avoid installing a rib for every seam between sheets of aluminum. So, I would like some advice on what is the state of the art with infallible glue joints between hard aluminum sheets. I imagine there is no alternative to crimping the meeting edges as is done when sewing two sheets of cloth together. No way am I interested in rivets. Marine sealants like sikaflex or 3M 5200. would probably work but you would have to come up with some very fancy clamping fixtures to let it cure. blind rivets would be way easier. But like Jim said it will be too heavy to fly. |
Thanks for the suggestions to my question of how to join aluminum
sheets [without rivets] for making a dirigible. The advice that an aluminum dirigible won't fly is not borne out by reality. Do a websearch for Schwarz airship. It was aluminum and flew in 1897. That's right, eighteen ninety seven. Then there was the Navy ZMC airship which flew for ten years back in the forties. One "advantage" of an aluminum skin is that the skin holds the lift gas, saving the weight of internal separate bags. Also, aluminum, being stiff, can add some monocoque strength to the frame. I'm thinking of employing some corrugated alum. for added stiffness and reduced drumming. It doesn't look nice but might work well. Any ideas? [negatives not needed ;-] |
dirigible designer wrote:
Thanks for the suggestions to my question of how to join aluminum sheets [without rivets] for making a dirigible. The advice that an aluminum dirigible won't fly is not borne out by reality. Do a websearch for Schwarz airship. It was aluminum and flew in 1897. That's right, eighteen ninety seven. Then there was the Navy ZMC airship which flew for ten years back in the forties. One "advantage" of an aluminum skin is that the skin holds the lift gas, saving the weight of internal separate bags. Also, aluminum, being stiff, can add some monocoque strength to the frame. I'm thinking of employing some corrugated alum. for added stiffness and reduced drumming. It doesn't look nice but might work well. Any ideas? [negatives not needed ;-] He didn't say it wouldn't work. Just that at this scale it would ne too heavy to fly. double - square - cube relationship... Richard |
"dirigible designer" wrote:
Thanks for the suggestions to my question of how to join aluminum sheets [without rivets] for making a dirigible. Hi "dd" (Allen?). I am familiar with the history of aluminum airships. One remote possibility it to look into/experiment with aluminum soldering. Once upon a time I did not think it was possible to solder aluminum, but if you do a Google search on the subject you should find some information on the subject. It's not impossible, merely difficult. As to glues, I would suggest going to McMaster-Carr's website (http://www.mcmaster.com/) and browse some of the categories under "Fastening and Sealing". Perhaps a mix of some blind or solid rivets (to provide structural strength) combined with a construction adhesive (to provide a seal and some shear strength) might work? Anyway, I'd suggest you try buying some likely candidates and try some small-scale experiments. Also, I believe there is a patent for the rivet machine that was invented in order to build the ZMC airships, but I don't have the patent number handy. But check patent 1,706,830. It is the main patent related to the ZMC airship design. It should also hopefully provide a starting point for finding the other patents related to the work done on the ZMC airships. I'm thinking of employing some corrugated alum. for added stiffness and reduced drumming. It doesn't look nice but might work well. Well, the ZMC-2 used something like 0.006 inch thick aluminum. You can now get hard-temper aluminum foil from MacMaster-Carr that is 0.002 inch thick. But wider rolls (less joining needed for the same surface area) are available down to 0.003 inch thick. Soft-temper of course can be had down to 0.0007 inch thick. About the temper of house-hold aluminum foil, though. Corrugated is going to drive your raw material cost up (unless you build equipment to corrugate the raw sheets or foil yourself). And I would expect it would impose a large drag penalty, too. Lastly, it is really hard to build working reduced-scale prototype airship designs. They don't scale down well. Good luck! |
Jim Logajan wrote:
"dirigible designer" wrote: Thanks for the suggestions to my question of how to join aluminum sheets [without rivets] for making a dirigible. Hi "dd" (Allen?). I am familiar with the history of aluminum airships. One remote possibility it to look into/experiment with aluminum soldering. Once upon a time I did not think it was possible to solder aluminum, but if you do a Google search on the subject you should find some information on the subject. It's not impossible, merely difficult. What about welding it? |
aluminum rib, aluminum spar, holes drilled but screws broken off | jls | Home Built | 13 | January 3rd 07 08:06 AM |
joining the traffic pattern quandary | [email protected] | Instrument Flight Rules | 77 | January 17th 05 05:07 PM |
Considerations for joining flying club | Marty Ross | Instrument Flight Rules | 20 | September 30th 04 05:55 AM |
Considerations for joining flying club | Marty Ross | General Aviation | 17 | September 16th 04 10:54 AM |
Joining the USAF | jshmoe | Military Aviation | 25 | November 13th 03 05:18 AM |
