Boarding with engines running
Old March 20th 07, 11:30 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Boarding with engines running
Mxsmanic wrote in
TheSmokingGnu writes:
There are 14 airports alone in the Paris metropolitan area ...
Yes, but they are all in the suburbs.
... and Orly is like a hop, skip, and a bus ride away.
It's more than an hour away, and I don't think it welcomes general
aviation.
Ha, I'm just trying to imagine the (very colorful) language the LAX
controllers would use to tell me that my landing clearance was
denied; they get mad enough when you encroach on their outlying
space, much less trying to use it whilst the 744's fly past.
Why would they deny you landing clearance?
And, Van Nuys isn't all that great for GA training.
It's a lot better than Orly.
So why worry about it?
That's what I ask. The FAA worries excessively about the wrong
things.
Besides, medicals aren't excuses to skip regular checkups with your
normal physician, which *DOES* pick up this sort of thing.
No, regular check-ups won't pick it up, either. It's often the sort
of thing you must be looking for.
If you're red/green colorblind, how can you tell which navigation
light is on which wing, and what direction and heading is that
aircraft off the left wing going?
By the way the lights move in relation to each other.
However, most people with red-green color blindness have deuteranomaly
or protanomaly, which means that they can still see red and green, but
it is more difficult for them than it is for normal people (and they
see them slightly differently, although they may still be distinct).
Ok, different situation. You go NORDO because some very key widget in
the radio bus decides to burn out. What light signal did the tower
just give you? Was it "clear to land" or "hold and circle"? What do
you mean you can't tell the difference between the lights?
Just make sure you carry a handheld.
And the list goes on and on. Color is key to flight.
Hardly. There are a handful of situations in which it matters.
Usually it doesn't.
It's the danger of living that attracts people to flying. The
knowledge that at some random moment, they may break down and
actually experience something worth remembering instead of sitting
indoors and pounding away endlessly at the keyboard.
That may be true for _some_ pilots, but certainly not all. There are
many potential attractions to flying, and not everyone is looking for
adventure.
The danger of death comes with every activity in our lives, from
flying to breathing.
In which case there's nothing special about flying. You undermine
your own argument.
I can. Can you?
Nobody can.
It's part and parcel of unusual attitude training.
It's not part of flight.
If you don't feel it, it's because you're not sensitive to it; the
airline pilot's thus being so (rather, MORE sensitive) are able to
maintain aircraft positioning without disturbing or alerting the
paying curmudgeons in the back to their maneuvering. QED.
No, they don't feel it either, or I should say, they don't feel it any
more than the passengers do. Everyone is in the same aircraft.
Thus proving the worth (or lack thereof) of simulation as applicable
to real world operation.
You watch the waypoints click by both in simulation and in real life.
I'm sorry, I thought all of flight was formula, and hard fact.
It is, in theory, but that doesn't mean that everyone does the
calculations.
I thought, you being such an expert in the operation of the 737-800
(as you profess), that you could give me precise performance figures
given a complete scenario. I guess YOU AREN'T UP TO THE TASK.
No, I just know that the 737-800 does this for me, thanks to being
familiar with the aircraft. The AFDS turns the aircraft, not I.
And the answer is: it's a trick question. You don't know your current
heading, and so you don't know how far away you are from your
intended course. Even if you did know that, the answer is variable
(do you start the rollout immediately from your current heading? Do
you start when 30 degrees abeam? Do you start as you pass it?). The
real answer is: enough. Enough so that the aircraft is operated in a
smooth manner, with a minimum of surface deflection, in an
expeditious manner, with as little error as possible. That is flying,
and it's VISCERAL, not calculable.
Clearly, tin-can pilots predominate here. I'm reminded of a rower in
crew who claims that a cruise-ship captain steers the ship by the feel
of the oars in his hands.
That's the way YOU choose to fly the aircraft. The plane is, first
and foremost, flown by hand, by pilots, with training and experience.
No, it is not. Almost all of the average commercial flight is flown
by the FMC. The pilots typically only fly take-off and landing; and
in low visibility, they may use the autoland feature to have the
aircraft land itself as well.
Heaven forbid he should find out the lateral-G load of the unexpected
maneuver prevents him from reaching that critical switch which
completes the sequence, eh?
There are very few emergencies that involve such forces. Large
airliners are only sound to about 2.5 Gs or so. A G force great
enough to prevent him from reaching a switch may well be enough to
snap the wings off also, so there's not much point in worrying about
it.
Heaven forbid he should feel the buffet in the controls of the
oncoming stall, which his instrument cluster failed to report to him
due to a blocked static port, eh?
His instruments warn him of critical angle of attack long before he
comes anywhere near it. It is unlikely to ever reach the buffer or
even stick-shaker stage if he is watching his instruments.
Like, say, a high-G turn. QED.
He won't (read: can't) be making any turns of more than 2.5 Gs or so.
Airliners are not fighter planes.
Your left engine falls off (wasn't properly reattached by the
groundcrew). You're now 2000+ lbs. out of list, have heavy yaw from
the operating engine, losing all sorts of other systems (like the
hydraulics that move your ailerons and flaps), generally getting a
wicked shimmy, AND you have no idea what just happened.
Guess it was your fault for letting it go that far, eh?
You can train for that in the sim.
Your failure to spot the satire is very telling.
Your conversion of a mistake to "satire" is noted.
That seems to be a recurring theme with you.
Not really; but if I don't know, I'm not afraid to say so.
I thought you were experienced enough to make edicts on procedure and
operation?
I'm experienced enough to make some statements with a high level of
certainty, but not others.
What happened to your burst of confidence?
Confidence is what allows me to admit when I don't know. People who
never say that they don't know are insecure liars.
Emergency procedures are some of the FIRST things you should learn,
and THE FIRST thing you should have memorized before stepping into
the cockpit.
Normal procedures first; then emergencies.
Engine out is a big one, because you can loose a compressor to
AOA on takeoff, or if you get a bird, or if your fuel system isn't
configured properly (or not functioning properly in the first place).
If you haven't learned to fly an aircraft normally, you won't be able
to learn how to fly it abnormally.
Losing an engine means lots of complicated, sometimes
counter-intuitive (and hand-flown) procedures. And you don't ****ing
know.
I know part of it, but I don't practice it much. I don't have to deal
with failures in simulation, and I don't plan to fly for real, so such
exercises are academic, and I undertake them only out of curiosity.
What a marooon!
Bertie
  #132
Old March 20th 07, 11:37 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Capt.Doug writes:
Typically alternate pucks in the calipers will be powered by
different hydraulic systems. The parking brake will use one set of
pucks.
So setting the parking brake in a large aircraft has some of the same
disadvantages as in a small aircraft, if hydraulic pressure is being
maintained.
Did you retrack the gear into the wheel-wells with elevated
temperatures? That could be a major fire hazard.
Unfortunately, yes. I only found out that the brakes were very hot by
accident, and I was well into my departure by then.
into your departure?
Bwawhahhwhahwhahwhahwhhahwhahwhahhwhahwhahwhahhwha hwhahhwhahwhahwhahhwha
hwhahwhhahwhahwhahwhhahwhahwhahwhhahwhahwhahwhhahw hahwhhahwhahwhahhwhahw
hhahwhahwhhawhhahwhahwh!
bertie
  #133
Old March 20th 07, 11:38 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Gary writes:
And don't think for a moment that the pretend controllers give a rats
ass about how long you leave the simulated plane on the pretend ramp
while boarding imaginary passengers.
Actually they do, although it depends somewhat on the controller.
keyboard!
Bertie
  #134
Old March 20th 07, 11:39 PM posted to rec.aviation.piloting
Mxsmanic wrote in
news
Little Endian writes:
Then I think your simulator does not really simulate flying of an
airplane properly.
It does, but sometimes minor differences throw people off, especially
if they've come to depend on them. A good pilot, however, can adapt
very quickly. The most obvious differences in this respect are
somewhat different control mechanisms and a slightly different visual
experience.
I cannot consider a simulator to be worth anything
if a real life pilot cannot fly it without any problems.
If real-life pilots could fly simulators without any problems, you
wouldn't need simulators.
What is a tin-can pilot?
A pilot who has experience only with small general-aviation aircraft.
Yes, but what you are talking about is not simulation of flying
because according to you, real life pilots cannot takeoff or land in
your simulator.
Some can, some can't. On a good machine with appropriate controls,
they should all be able to do it, or something is wrong.
The simulator does not depict the beauty of the Rocky Mountains in
any way.
It's not a scenery simulator.
I have hiked all over the Rockies and its not possible to
replicate that beauty of Romo in a simulator with fake images.
It's not a hiking simulator, either.
Maybe so but that is how we learn to become better real life pilots.
No, that is how one discovers that he is a poor pilot, or that he is
in a situation that he will not survive.
Good lord, how big an idiot are you anyway?
Bertie
  #135
Old March 20th 07, 11:40 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Mark Hansen writes:
It's really sad to see people go through this over and over and over
and over....
Only if you are frustrated by your inability to control others.
Control?
Bwawhahwhahhwhahhwhahwhha!
God you're just priceless!
bertie
  #136
Old March 20th 07, 11:42 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Tim writes:
Horse****. I have a middle class income. I own a plane. It is a
matter of priorities. Instead of buying/leasing a new car, one can
instead own an old, used airplane. Too many people I know with low
to middle incomes spend like crazy on cars, TVs, stereos, golf, etc.
I chose to spend it on flying. Once again you prove that you have no
idea what the F you are talking about.
I depend on data and statistics, rather than anecdotes.
or experience
bertie
  #137
Old March 20th 07, 11:46 PM posted to rec.aviation.piloting
Default Understanding MXspeak was Boarding with engines running
Mxsmanic wrote in
Paul Tomblin writes:
I'll take a real Warrior over a fake 747 any day of the year. At
least when I fly somewhere, when I get out of the plane I'm really
there, not in a pathetic little ******** in Paris.
For me, actually arriving at a real destination would be a huge
disadvantage. I don't really want to end up in Aspen or St. Maarten or
anything like that. They simply have interesting airports.
Good grief
Why stop there? i'm sure your home planet is lovely this time of year.
Bertie
Medical running out? [email protected] Piloting 6 May 28th 06 02:19 PM
Running dry? Greg Copeland Piloting 257 August 26th 05 03:47 PM
Running runup? G. Burkhart Piloting 39 July 7th 04 11:25 AM
Running an 0-235 well beyond TBO Paul Folbrecht Owning 8 March 14th 04 12:30 AM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
