A380 at LAX
Old March 21st 07, 01:26 AM posted to alt.binaries.pictures.aviation
Meaner than you
Default A380 at LAX
it was a software glitch and a electrical wiring problem, it was talked
about that last year, this is one of the problems they are having....
"Doc" wrote in message
On Tue, 20 Mar 2007 09:26:48 GMT, "Pointer"
http://tinyurl.com/2un6at
See the Fox News Video ( the landing is in the top video option)
Was there a strong Xwind?
instant rudder correction as the wheels touch!
P
I saw the video at cnn.com and I noticed that correction too.
Old March 21st 07, 03:34 AM posted to alt.binaries.pictures.aviation
Willem Van der Voort
Default A380 at LAX Another one
"Meaner than you" schreef in bericht
they need a longer runway to fly the A380 into LAX
Wtf is that cement mixer doing there? ;-)
Strange, why was the A-380 assigned to RW 24R the shortest RW in LAX???
Runway information: Number Category Heading Length Width Surface
06L I 69 8925 ft / 2720 m 150 ft / 46 m Concrete
06R I 69 10285 ft / 3135 m 150 ft / 46 m Concrete
07L I 69 12091 ft / 3685 m 150 ft / 46 m Concrete
07R I 69 11096 ft / 3382 m 200 ft / 61 m Concrete
24L I 249 10285 ft / 3135 m 150 ft / 46 m Concrete
24R IIIA 249 8925 ft / 2720 m 150 ft / 46 m Concrete
25L II 249 11096 ft / 3382 m 200 ft / 61 m Concrete
25R I 249 12091 ft / 3685 m 150 ft / 46 m Concrete
Old March 21st 07, 05:03 AM posted to alt.binaries.pictures.aviation
Ron Monroe
The new longer runway is under construction, and is not ready for the A380.
As was seen with the cement mixer, work is still being done. But, it was a
pretty empty airplane, and had plenty of room for landing on 24R. I think
they said there were only 8 passengers on board, and it didn't have an
interior installed yet. Dale can probably give you more info on the
runways.
Ron
"Willem Van der Voort" wrote in message
Old March 21st 07, 11:36 AM posted to alt.binaries.pictures.aviation
"Ron Monroe" schreef in bericht
hlink.net...
A380. As was seen with the cement mixer, work is still being done. But, it
was a pretty empty airplane, and had plenty of room for landing on 24R. I
think they said there were only 8 passengers on board, and it didn't have
an interior installed yet. Dale can probably give you more info on the
runways.
Ron
Tanks Ron,
Willem
Old March 21st 07, 11:26 PM posted to alt.binaries.pictures.aviation
the Legend of LAX
runways.
Ron
The new r/w is scheduled to open April 2, as a cat I. Cat III will
follow a month or two later. Then they will begin constructing the
taxiway between 25L & 25R. They did some flight checks on the new ILS
last night. It's getting the new fangled end-fire glideslope.
The decision was made to land on 24R so that the taxi routes could be
tested. Also, since there is only one r/w open on the south side, the
Airbus would have effectively shut down half of the airport until
parked. There was also some concern that the engine height was low
enough to actually strike some of the signage. It didn't.
Dale G Elhardt
Cypress Ca
"The universal aptitude for ineptitude makes any human accomplishment an
incredible miracle."
http://home.comcast.net/~laxet/
http://www.jetphotos.net/showphotos.php?userid=7702
Old March 21st 07, 11:58 PM posted to alt.binaries.pictures.aviation
john smith
Does that mean it directly projects the gs instead of reflecting it from
1000 feet down the runway?
Old March 22nd 07, 12:11 AM posted to alt.binaries.pictures.aviation
The new r/w is scheduled to open April 2, as a cat I. Cat III will follow
a month or two later. Then they will begin constructing the taxiway
between 25L & 25R. They did some flight checks on the new ILS last night.
Airbus would have effectively shut down half of the airport until parked.
There was also some concern that the engine height was low enough to
Dale G Elhardt
Cypress Ca
Tanks Dale, very intresting to know
Willem
Old March 22nd 07, 05:11 PM posted to alt.binaries.pictures.aviation
Doug Maclean
"The comprehensive route-proving schedule includes the following
flights and ground tests:
Saturday, 17 March 11:30 hrs: Touchdown of the Airbus A380 at
Frankfurt Airport arriving from Toulouse
Sunday, 18 March Comprehensive ground tests at Frankfurt Airport
Monday, 19 March 9:00 hrs: Departure for New York
Tuesday, 20 March A380 flight from New York to Chicago
Wednesday, 21 March Return flight to New York
Thursday, 22 March Flight from New York to Frankfurt
10:30 hrs: Arrival in Frankfurt
Friday, 23 March 15:30 hrs: Flight departs Frankfurt for Hong Kong
Saturday, 24 March Hong Kong
Sunday, 25 March Return flight from Hong Kong to Frankfurt, landing at
15:10 hrs
18:00 hrs: Flight departs Frankfurt for Washington
Monday, 26 March Washington
Tuesday, 27 March Return flight to Frankfurt
12:00 hrs: Arrival in Frankfurt, further ground tests
Wednesday, 28 March 11:00 hrs: Flight departs Frankfurt for Munich
12:30 hrs: Arrival in Munich
17:30 hrs: A380 departs Munich for Toulouse
Old March 22nd 07, 11:20 PM posted to alt.binaries.pictures.aviation
the Legend of LAX
For a little background explanation for those who don't know how it works:
The antenna sits at the touchdown point (the point where the glide path
actually touches the r/w), 750-1250 feet down the runway & offset
250-650 feet from centerline. It projects a beam toward the the landing
path at an angle of 1.4 (usually) degrees. We use capture effect now,
which is based on the principle that a receiver will lock on to the
stronger of two signals & reject the weaker. I have not been to school
for the end-fire so I don't know its theory yet, but it does basically
the same thing, just using a different method. The antenna sits at about
the same point. Instead of being on a tall mast, it sits almost flat on
the ground, similar to a localizer antenna. It is used where terrain is
not smooth (since the CEGS uses an image antenna as part of its
operation & requires smooth ground plane around it to reflect the
image). I will try to get some pictures & post them showing the
different antennas.
Dale G Elhardt
Cypress Ca
Old March 25th 07, 08:59 AM posted to alt.binaries.pictures.aviation
Daryl Bryant[_2_]
Default A380 at LAX
That's a heavy...
A new Air France Airbus A320 making what was supposed to be a fly-by at a
1998 airshow. The pilot claims the highly automated control system on the
A320 failed to respond properly to commands. The official investigation
blamed pilot error as the cause, but it was later revealed that the aircraft
's black boxes had been switched after the crash. What do you suppose really
happened?
A380 32.jpg (1/1) Jim Long Aviation Photos 4 February 8th 07 11:57 PM
A380 16.jpg (1/1) Jim Long Aviation Photos 0 February 8th 07 06:04 PM
A380 15.jpg (1/1) Jim Long Aviation Photos 0 February 8th 07 06:04 PM
A380 14.jpg (1/1) Jim Long Aviation Photos 0 February 8th 07 06:04 PM
A380 13.jpg (1/1) Jim Long Aviation Photos 0 February 8th 07 06:04 PM
