Rolling a Non Aerobat 150
Old March 5th 07, 01:01 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Stefan
Default Rolling a Non Aerobat 150
Dylan Smith schrieb:
I think 'fully stalled' in the context of a spin means that both wings
exceed the critical angle of attack. That's not to say one wing can't
The outer wing isn't necessairily stalled.
have a different AoA than the other (IIRC, the critical angle of attack
is something on the order of 16 degrees)
Even without a thorough knowledge, I dare to believe that this depends
on the profile...
Old March 6th 07, 01:42 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
stearmandriver
On Mar 4, 8:59 pm, DR wrote:
Roger wrote:
A spin is a fully stalled condition. The doors of a 150 or 172 should
be *relatively* easy to open as opposed to being in a high speed
spiral.
As I understand it, there is a difference in the _extent_ of the stall
between the two wings. If that were not the case and both wings were
fully stalled (which would require AOA to be ~90 degrees I think) the
yaw would decay due to fusilage and tail drag?
Cheers Mark
thought I'd jump in on this one. I've been a Stearman driver for about 30 years and might have about as much time in "unusual attitudes" as right side up. In a fully developed spin, the door on the outside of the spin will be pretty difficult to open, and in fact it's tough to even move yourself out on that side. the old military training in open cockpits was to bail to the inside of the spin if unrecoverable. so, the quick release pins are in the aerobat to ensure you can get the door off- Centrifigal force and wind presssure will keep it closed otherwise.
Old March 6th 07, 08:39 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
pittss1c
I know of one to get out of a decathlon. It was from the back seat no less.
(It helps when the wing has departed and there is a big hole above your
head though)
Mike
john smith wrote:
In article . net,
"Todd W. Deckard" wrote:
Why would you say this? The door would be fairly easy to open in a spin.
In a high speed loss of control it might be very difficult to overcome
aerodynamic resistance but it is possible to open a forward hinged door
and force it open enough to squeeze out at even 100kts in straight flight.
With a modern canopy you stand a chance of a survivable deployment at
even a few hundred feet.
I wouldn't be too positive about those statements.
I have over 300 freefalls and 25 hours of acro in a Citabria.
The Citabria only has one door... on the right side. In a right spin,
the rate of descent is still going to be about 800 fpm with an indicated
airspeed of 45-50 mph. That's quite and airload on the inside turn side
of the airframe. Add to that centrifugal forces and getting through the
doorway after jettisoning the door will be a challenging proposition.
You have two sets of seatbelts to release, a headset to remove and a
body with a parachute attached to fit through the doorway. When you exit
you will be on the inside side of the airplane, which you have to clear
before you pull the D-ring.
Tic-toc, the clock is winding down as fast as the altimeter.
I have knowledge of only one acro pilot who successfully exited a
Decathlon.
Old March 23rd 07, 01:36 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Cox
If you do manage to get out of a spinning aircraft, I wouls estimate close
to a 100% better chance of survival if you have a chute on. I sure would
hate to be the person who was able to get out of the so called "impossible
aircraft to get out of" only to find they didn't have a chute on.
Wear a chute, what can it hurt?
Adam
Adam Cope
www.dcaerobatics.com
703-623-9445
Old March 23rd 07, 01:57 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Don Tuite
Adam
Then there's this:
http://www.aero-news.net/index.cfm?C...-7233c1bb43f8&
(Hope it's not a repost. It's about the 150 rudder bumpers jamming.)
Don
Old March 23rd 07, 02:34 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Dudley Henriques[_2_]
Adam
Adam Cope
703-623-9445
I totally agree with this. The " you'll never get out of this airplane
because of the door" routine is something I've heard repeated many times
through my career teaching aerobatics. My standard answer and "lecture"
on this issue is as follows;
For spins, even if the regulations don't call for chutes, I always
recommend wearing them. I always had chutes available for whatever
aircraft we were using for spin training.
A lot has been written and said about the difficulties involved in
getting out of Aerobats, Citabrias, and Decathlons.
There is no doubt that especially with a structural failure, exiting one
of these aircraft could be iffy. That's why any good instructor not only
supplies chutes for spin training, but as well performs a complete
egress brief specific to aircraft type to the point where once the bail
out call has been made, each occupant knows what the exit procedure will
be. This is especially critical in tandem aircraft.
I should mention that even with the most complete egress briefing, there
is STILL an element of doubt that a successful exit from these airplanes
can be executed in the time available under extreme g in a post
structural failure.
The factors involving a successful bail out are so diverse that there
are just no guarantees.
In the Pitts S2 for example, if the upper wing fails, the flying wires
will most likely remain attached and the upper wing will beat the
occupants to death before a bail out can be achieved.
All this being considered, the use of chutes is not only recommended,
but in my opinion a necessary part of every non- standard flight whether
it be aerobatics or spin training.
The bottom line is that wearing a chute gives you a fighting chance for
survival. Not wearing a chute gives you no chance at all.
Its a smart pilot who takes advantage of all available options!
Dudley Henriques
Old March 23rd 07, 03:22 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
john hawkins
close to a 100% better chance of survival if you have a chute on. I sure
would hate to be the person who was able to get out of the so called
"impossible aircraft to get out of" only to find they didn't have a
chute on.
Adam
Adam Cope
703-623-9445
through my career teaching aerobatics. My standard answer and "lecture" on
A lot has been written and said about the difficulties involved in getting
supplies chutes for spin training, but as well performs a complete egress
brief specific to aircraft type to the point where once the bail out call
has been made, each occupant knows what the exit procedure will be. This
can be executed in the time available under extreme g in a post structural
failure.
The factors involving a successful bail out are so diverse that there are
just no guarantees.
All this being considered, the use of chutes is not only recommended, but
in my opinion a necessary part of every non- standard flight whether it be
Dudley Henriques
Dudley,
Could you give some specifics about exiting a citabria?
I used to do aerobatics in one and always wore a chute. I never suspected
that I would have trouble exiting if I pulled the door hinge pins, I thought
the door would vanish and leave me a big hole to climb out.
The only serious instructor I had was in a Stearman and he never discussed
exiting in case of trouble.
Obviously I was completely ignorant. Better to learn late than never.
  #28
Old March 23rd 07, 03:55 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
george
And have quick release pins on the doors with the handles -inside-
  #29
Old March 23rd 07, 04:14 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Our procedure was to yank the QR pins and turn the handle;
Champion may well have improved the quick release doors by now. Its been
a long time ago for me in the Citabria :-)
I would suggest a good look through the POH and a brief from the
airplane operator for the current scoop on this.
DH
chute on.
Adam
Adam Cope
703-623-9445
failure.
just no guarantees.
Dudley Henriques
Dudley,
  #30
Old March 23rd 07, 03:24 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
C J Campbell[_1_]
On 2007-02-28 19:41:14 -0800, john smith said:
In article . net,
Decathlon.
There was a guy down in Borrego Springs who managed to bail out when
his Citabria would not recover. Checking the wreckage later he found
the seatbelt from the rear seat had wrapped itself around the stick.
He could have sworn he had secured that thing.
Waddling Eagle
World Famous Flight Instructor
Rolling a Non Aerobat 150 Larry Dighera Piloting 98 June 18th 05 12:28 AM
Rolling a Non Aerobat 150 Jose Instrument Flight Rules 1 May 2nd 05 03:59 PM
Rolling a Non Aerobat 150 Jose Piloting 1 May 2nd 05 03:59 PM
Rolling a Non Aerobat 150 Larry Dighera Piloting 1 April 29th 05 07:31 PM
Rolling a Non Aerobat 150 kage Owning 0 April 29th 05 04:26 AM
