cub to sua conversion
Old March 23rd 07, 12:45 AM posted to rec.aviation.soaring
Tuno
Default cub to sua conversion
Is there a convenient way to convert .cub format airspace files (e.g.
as used by SeeYou) to .sua format (as used by various other programs)?
~ted/2NO
Old March 23rd 07, 12:54 PM posted to rec.aviation.soaring
Clint
I was sitting with the same problem and the only solution I found was
using StePlan. It can convert between the formats easily - you
literaly highlight the area on the map you want converted and it
writes the sau file. Magic. I just used the demo version to do this so
it didn't even cost money - can't beat that solution.
Cheers
Clinton
LAK 12
Old March 23rd 07, 01:23 PM posted to rec.aviation.soaring
Andrej Kolar
Hi Ted,
there isn't because some of our sources for airspace files years ago
demanded that this would not be possible.
However - at present all of the airspace we make available to you
comes from sources which are available in either OpenAir or TNP
formats. See the Support forum at www.naviter.si, go to Forum
Airspace and you will find what you are looking for. If you don't -
feel free to leave a message there too.
Regards,
Andrej Kolar
glider pilots use
http://www.SeeYou.si
Tuno je napisal:
~ted/2NO
LS-4 to LS-4a conversion Dan Peters Soaring 1 September 1st 06 02:29 AM
LS-4 to LS-4a conversion Dan Peters Soaring 1 August 29th 06 07:50 AM
Taildragging conversion [email protected] Piloting 8 August 6th 06 04:09 AM
Turnpoint conversion SW? For Example John Smith Soaring 11 March 23rd 05 07:56 PM
Corvair Conversion Gig Giacona Home Built 17 October 27th 03 10:43 PM
