Hi Folks,
Here's an interesting phenomenon I observed recently and I was wondering if anybody else has seen anything like it. About two weekends ago, I was doing a cross country in actual (IMC) with one of my Instrument Rating students near Cheyenne, WY. We were at 11,000ft for a while and the temperature was near freezing but there was no precipitation in the area. All of a sudden, there was a sound like a pebble hitting the windshield. I explained to my student that it was either an isolated hail pebble or ice coming off the propeller. About ten minutes later, I heard the same sound but this time it sounded more like an electric discharge similar to the one you hear when you touch the door knob after walking on the carpet. I rechecked the fuses and the alternator but everything was working fine. The sound was definitely coming from the outside. Then about five minutes later, we heard the same sound. But this time, I was trying to read the mag compass which is mounted up high on the windshield. I'm pretty sure that I saw a flash of light this time near the top center of the windshield where the Plexiglas meets the aluminum . This made me wonder: When flying in IMC over an extended geographic area (Cheyenne to West of Denver) is it possible for the airplane to start discharging by arcing? Has anybody else seen something similar to this? I should mention that the winds were not especially fast that day (about 160 @ 30kts). |
Most slow airplanes do not have static discharge wicks, but
in the correct conditions, they can build static which can build to very high voltages. It is also possible that the grounds [bonding] between components is not good and that can lead to arcing across hinges and between ailerons and wing, etc. Snow and ice crystals cause the build up, the fix is proper bonding and static wicks, even on a C172. "gman" wrote in message ups.com... | Hi Folks, | Here's an interesting phenomenon I observed recently and I was | wondering if anybody else has seen anything like it. | | About two weekends ago, I was doing a cross country in actual (IMC) | with one of my Instrument Rating students near Cheyenne, WY. We were | at 11,000ft for a while and the temperature was near freezing but | there was no precipitation in the area. All of a sudden, there was a | sound like a pebble hitting the windshield. I explained to my student | that it was either an isolated hail pebble or ice coming off the | propeller. About ten minutes later, I heard the same sound but this | time it sounded more like an electric discharge similar to the one you | hear when you touch the door knob after walking on the carpet. I | rechecked the fuses and the alternator but everything was working | fine. The sound was definitely coming from the outside. Then about | five minutes later, we heard the same sound. But this time, I was | trying to read the mag compass which is mounted up high on the | windshield. I'm pretty sure that I saw a flash of light this time near | the top center of the windshield where the Plexiglas meets the | aluminum . This made me wonder: When flying in IMC over an extended | geographic area (Cheyenne to West of Denver) is it possible for the | airplane to start discharging by arcing? Has anybody else seen | something similar to this? I should mention that the winds were not | especially fast that day (about 160 @ 30kts). | |
On Mar 23, 2:48 pm, "gman" wrote:
Hi Folks, Here's an interesting phenomenon I observed recently and I was wondering if anybody else has seen anything like it. About two weekends ago, I was doing a cross country in actual (IMC) with one of my Instrument Rating students near Cheyenne, WY. We were at 11,000ft for a while and the temperature was near freezing but there was no precipitation in the area. All of a sudden, there was a sound like a pebble hitting the windshield. I explained to my student that it was either an isolated hail pebble or ice coming off the propeller. About ten minutes later, I heard the same sound but this time it sounded more like an electric discharge similar to the one you hear when you touch the door knob after walking on the carpet. I rechecked the fuses and the alternator but everything was working fine. The sound was definitely coming from the outside. Then about five minutes later, we heard the same sound. But this time, I was trying to read the mag compass which is mounted up high on the windshield. I'm pretty sure that I saw a flash of light this time near the top center of the windshield where the Plexiglas meets the aluminum . This made me wonder: When flying in IMC over an extended geographic area (Cheyenne to West of Denver) is it possible for the airplane to start discharging by arcing? Has anybody else seen something similar to this? I should mention that the winds were not especially fast that day (about 160 @ 30kts). In the right atmospheric conditions, insulators like plexiglass can build up a large static charge as air rushes past it. This is basically an air-driven Van De Graff generator. The sound you were hearing was most likely the charge arcing from the plexiglass to the metal frame as it reached a high enough voltage to break down the air and arc over. |
Google Saint Elmo's Fire. It is a fairly common phenomenon.
Bob Gardner "gman" wrote in message ups.com... Hi Folks, Here's an interesting phenomenon I observed recently and I was wondering if anybody else has seen anything like it. About two weekends ago, I was doing a cross country in actual (IMC) with one of my Instrument Rating students near Cheyenne, WY. We were at 11,000ft for a while and the temperature was near freezing but there was no precipitation in the area. All of a sudden, there was a sound like a pebble hitting the windshield. I explained to my student that it was either an isolated hail pebble or ice coming off the propeller. About ten minutes later, I heard the same sound but this time it sounded more like an electric discharge similar to the one you hear when you touch the door knob after walking on the carpet. I rechecked the fuses and the alternator but everything was working fine. The sound was definitely coming from the outside. Then about five minutes later, we heard the same sound. But this time, I was trying to read the mag compass which is mounted up high on the windshield. I'm pretty sure that I saw a flash of light this time near the top center of the windshield where the Plexiglas meets the aluminum . This made me wonder: When flying in IMC over an extended geographic area (Cheyenne to West of Denver) is it possible for the airplane to start discharging by arcing? Has anybody else seen something similar to this? I should mention that the winds were not especially fast that day (about 160 @ 30kts). |
"gman" wrote
About two weekends ago, I was doing a cross country in actual (IMC) with one of my Instrument Rating students near Cheyenne, WY. We were at 11,000ft for a while and the temperature was near freezing but there was no precipitation in the area. All of a sudden, there was a sound like a pebble hitting the windshield. I explained to my student that it was either an isolated hail pebble or ice coming off the propeller. About ten minutes later, I heard the same sound but this time it sounded more like an electric discharge similar to the one you hear when you touch the door knob after walking on the carpet. I rechecked the fuses and the alternator but everything was working fine. The sound was definitely coming from the outside. Then about five minutes later, we heard the same sound. But this time, I was trying to read the mag compass which is mounted up high on the windshield. I'm pretty sure that I saw a flash of light this time near the top center of the windshield where the Plexiglas meets the aluminum . This made me wonder: When flying in IMC over an extended geographic area (Cheyenne to West of Denver) is it possible for the airplane to start discharging by arcing? Has anybody else seen something similar to this? I should mention that the winds were not especially fast that day (about 160 @ 30kts). Had a similar experience while flying in the midwest during a pretty decent snow storm. It was a night flight and we were cruising along when suddenly the charts I had placed up on the glareshield jumped up and stuck to the inside of the windshield. I could feel the strong static charge when I took them off, and there was also a nice discharge from my fingertips. For the next 30 minutes or so you could put your fingertips up near the windshield and draw a constant corona discharge from about 1/4-in away. I had never seen anything like that before and have never seen it again since. BDS |
"Jim Macklin" wrote
Most slow airplanes do not have static discharge wicks, but in the correct conditions, they can build static which can build to very high voltages. It is also possible that the grounds [bonding] between components is not good and that can lead to arcing across hinges and between ailerons and wing, etc. Snow and ice crystals cause the build up, the fix is proper bonding and static wicks, even on a C172. Bonding and static wicks will not prevent a static charge from building on an insulator such as the windscreen itself, but they certainly will keep the entire airframe at the same potential as you mention. In fact, theoretically you could have a ground plate on one side of the windscreen and still build a static charge on the other side of the windscreen under the right conditions. That's the nature of static charges on insulators. BDS |
![]() toecutter wrote Hawker 800's have plastic windscreens and a marginal ground path. Think about cold, dry air at altitude. They will indeed light you up if you aren't careful. Snap, Crackle and Pop. BTW, you're usually standing on a stepladder when you get poked... You might need to explain that one, a little more. What are you doing up around a windshield at altitude on a stepladder? g -- Jim in NC |
The term is capacitor. Most plastic has an anti-static
coating and plastic airplanes have conductive elements built-in. Franklin must have said it, the key to electricity is , ouch! "BDS" wrote in message ... | "Jim Macklin" wrote | | Most slow airplanes do not have static discharge wicks, but | in the correct conditions, they can build static which can | build to very high voltages. It is also possible that the | grounds [bonding] between components is not good and that | can lead to arcing across hinges and between ailerons and | wing, etc. | | Snow and ice crystals cause the build up, the fix is proper | bonding and static wicks, even on a C172. | | Bonding and static wicks will not prevent a static charge from building on | an insulator such as the windscreen itself, but they certainly will keep the | entire airframe at the same potential as you mention. In fact, | theoretically you could have a ground plate on one side of the windscreen | and still build a static charge on the other side of the windscreen under | the right conditions. That's the nature of static charges on insulators. | | BDS | | |
![]() "Jim Macklin" wrote The term is capacitor. Most plastic has an anti-static coating and plastic airplanes have conductive elements built-in. Franklin must have said it, the key to electricity is , ouch! You know, the electricity is not what usually hurts me, though. It is losing all of the skin off my knuckles, when I get jolted, and involuntarily try to remove my hand from behind the panel, or from in ... (insert your favorite location where your hand is when it gets shocked) far too rapidly! Same thing goes with being on a ladder and getting shocked. The shock will not hurt nearly as much as falling off of the ten foot ladder you are standing on, but it is hard to remember that, at the time it happens! g -- Jim in NC |
IFR static discharge | [email protected] | Home Built | 0 | April 2nd 06 08:06 PM |
The Vanishing Honorable Discharge | Otis Willie | Naval Aviation | 0 | October 29th 04 02:58 AM |
