I would recommend against using any fiberglass sleeve
that slips over the wing as a tiedown. They will tend to pull on the control surfaces, unless you make them so that the controls can move full travel within the sleeve. And even if you do that, you will not be applying the load where it is good for the wing. You will either be pulling from the leading edge, or you will be pulling in the middle of the bottom side of the sleeve, where it will pull away from the wing and try to pinch the leading and trailing edges. Does your glider have a CG Hook? If so, make yourself a short rope from 3/8ths hollow braid polypropelene, or similar. On one end, put a chain link or a Tost ring. Put a loop in the other end. Secure the loop to the ground (through one of those tie-down rings on paved ramps, or a good tie-down stake you put in them move the plane over), and hook the other to your CG hook. Push the glider back until the rope goes tight, and block the wheel. Tie the tail aft to another tiedown, and put stands under the wings. As long as you rope goes 30 to 45 degrees forward of straight down, you should not have to worry about back releasing. Load to this towhook (for ground launching) is generally between 80 to 100 percent of gross weight for the weak link. So, the structure is probably designed to handle at least two times this. And to get load on this equal to two times the gross weight, would require lift production equal to 4 to 5 times the empty weight. (remember, the wing has to lift the empty weight before it can start loading the hitch). Pluses: No sleeves on the wings to load up your control surfaces or hold moisture against your gelcoat. And, have you looked at those sleves and gotten an idea as to how much load they could really handle? I bet most would come apart at a less than a couple of hundred pounds. The tow hook is a designed in strong point in the airframe, made to handle big loads. If you put the tail dolly on, the angle of attack will be low enough that with flaps set to negative, it would probably take 100 MPH winds to even start loading that tiedown rope, if it ever got loaded. Just a thought. Steve |
"Steve Leonard" wrote in message ... Does your glider have a CG Hook? You just hit a pet subject of mine. All glider tie-down systems, particularly permanent tie-downs, should include an attachment to the tow hook. I have seen at least two otherwise properly tied down gliders ruined by being blown over backwards by thunderstorm winds. In my judgment, both of them would have survived had there been a tie-down anchor attached to the tow hook. Why would you NOT attach a tie-down to the strongest, most convenient point on the airframe? Vaughn |
On Mar 23, 9:59 pm, Steve Leonard
Does your glider have a CG Hook? If so, make yourself a short rope from 3/8ths hollow braid polypropelene, or similar. On one end, put a chain link or a Tost ring. Put a loop in the other end. Secure the loop to the ground (through one of those tie-down rings on paved ramps, or a good tie-down stake you put in them move the plane over), and hook the other to your CG hook. Push the glider back until the rope goes tight, and block the wheel. Tie the tail aft to another tiedown, and put stands under the wings. Works great at Hobbs, which is where I started using it. You didn't copy me did you ![]() Andy (GY) |
On Mar 24, 2:40 pm, "Andy" wrote:
On Mar 23, 9:59 pm, Steve Leonard Does your glider have a CG Hook? If so, make yourself a short rope from 3/8ths hollow braid polypropelene, or similar. On one end, put a chain link or a Tost ring. Put a loop in the other end. Secure the loop to the ground (through one of those tie-down rings on paved ramps, or a good tie-down stake you put in them move the plane over), and hook the other to your CG hook. Push the glider back until the rope goes tight, and block the wheel. Tie the tail aft to another tiedown, and put stands under the wings. Works great at Hobbs, which is where I started using it. You didn't copy me did you ![]() Andy (GY) Andy: Thanks for the suggestion. I will give it a try. Dick |
My Ventus B has removable wingtips...Dave Nelson build
some wood plugs that fit into the holes the wingtips insert into. I remove the wingtips, insert the wood dowels...use the wingstand on one side and the wingwheel on the other...and then tie down to the wooden dowels sticking out of the end of the wings. |
On Mar 24, 9:22 pm, Stewart Kissel
wrote: My Ventus B has removable wingtips...Dave Nelson build some wood plugs that fit into the holes the wingtips insert into. I remove the wingtips, insert the wood dowels...use the wingstand on one side and the wingwheel on the other...and then tie down to the wooden dowels sticking out of the end of the wings. Stewart" Thanks for the suggestion. Dick |
Whatever else you do, if strongs winds are possible
then securely tie down (not weigh down) the wing tips if they are sitting on unstable tripod stands. In a serious wind, if the glider is facing into wind then the wings can fly and bend up away from the stands which then fall over and the wings then can bang up and down on the fallen stands - which, in the case of Cobra types, have sharp pointy bits that stick up when the little legs are folded. We had this happen to a Duo a few years ago - the wings tips were weighed down by being tied to 25kg water bottles which just lifted with the wing tip. The same day an ASH 25 had its wings lifted and its stands blow over but it then blew backwards 10 yards so the tips land on grass and not the stands. I now chock the wheel front and back, use stable old fashioned wooden wing trestles and tie down the tips with sleeves attached to 'The Claw' John Galloway |
On Mar 25, 12:23 pm, John Galloway wrote:
Whatever else you do, if strongs winds are possible then securely tie down (not weigh down) the wing tips if they are sitting on unstable tripod stands. In a serious wind, if the glider is facing into wind then the wings can fly and bend up away from the stands which then fall over and the wings then can bang up and down on the fallen stands - which, in the case of Cobra types, have sharp pointy bits that stick up when the little legs are folded. We had this happen to a Duo a few years ago - the wings tips were weighed down by being tied to 25kg water bottles which just lifted with the wing tip. The same day an ASH 25 had its wings lifted and its stands blow over but it then blew backwards 10 yards so the tips land on grass and not the stands. I now chock the wheel front and back, use stable old fashioned wooden wing trestles and tie down the tips with sleeves attached to 'The Claw' John Galloway John: Thanks for the information. It is helpful. Dick |
| Wedekind sleeve for Std Cirrus | John Galloway | Soaring | 8 | July 9th 13 03:15 PM |
| Navman GPS sleeve | Oscar Goudriaan | Soaring | 1 | March 2nd 07 10:27 PM |
| pvc tubing/sleeve source? | Jim Burns | Owning | 4 | September 28th 06 04:36 AM |
| pvc tubing/sleeve source? | Jim Burns | Home Built | 4 | September 28th 06 04:36 AM |
| Welding question: reinforce by inner sleeve | Michael Horowitz | Home Built | 7 | June 12th 06 08:11 PM |
