Annual Off to a Good Start
Old March 26th 07, 02:39 PM posted to rec.aviation.owning
Gig 601XL Builder
Default Annual Off to a Good Start
Jay Honeck wrote:
I'm using Torx on the plane I'm building in several access panel
locations.
That is SO smart.
Is it illegal to subsitute Torx (or square-drive) screws in
certificated aircraft? If so, why?
I doubt it. And please note that I'm only using them in non-strucural areas
with one exception. The top skin between the panel (which is a bulkhead in
my plane) and the firewall. This will allow me total access behind the
panel. Also remember that the design here is for blind rivets. And the
designer gave his blessing to the modification. There are going to be about
60 of the little buggers in there.
  #62
Old March 26th 07, 02:42 PM posted to rec.aviation.owning
Gig 601XL Builder
Mike Spera wrote:
Probably because no "airplane parts store" (including the highly
respected discounter o'them all, Chief) carries anything but
Phillips. .stuff snipped
I'm gonna replace stainless with stainless. They are a BIT harder
and don't rust up quite as bad. Stainless to speednut has never
been a problem insofar as I know.
.other stuff snipped
Now that we have broached the subject, where do you find stainless
threaded speed nuts. There are a pile of them used on Cherokees to
hold on the wing/stabilator tips (8-32 I believe). I have never been
able to get a source.
Anyone?
Thanks,
Mike
If one of these places don't have them they probably don't exsist.
http://www.gen-aircraft-hardware.com/
http://www.mcmaster.com/ (Not Aircraft but great none the less)
chicago area residential airpark and maintenance facility good deals on annual inspections [email protected] Owning 7 September 15th 05 02:55 AM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
Is a 152 a good start? AliR Piloting 17 April 20th 05 05:52 PM
[US: PA/NY/NJ] Governor's Cup off to a good start Papa3 Soaring 0 April 13th 05 10:36 PM
'Good' Annual This Year Ben Smith Owning 38 July 26th 03 05:44 AM
