How do controllers coordinate clearances through sectors?
Old March 26th 07, 06:34 PM posted to rec.aviation.ifr
Robert M. Gary
Default How do controllers coordinate clearances through sectors?
I'm curious, how does one controller secure a direct clearance through
mulitple other controllers' areas? Sometimes it seems that after a
handoff the receiving controller doesn't know what your clearance is
(but certainly must have that area available for you).
As a typical example, I was flying home from Monterey last night and,
after passing the San Jose arrival area, received an updated
clearance, direct to my destination. Two controllers later, the
controllers asked me if I was direct to the VOR. I said no, I'm direct
home.
I'm curious how the issuing controller is able to ensure a clearance
all the way home direct. And how is it that a receiving controller
doesn't know what a plane's current clearance is? Doesn't this all
make it hard to plan conflict free traffic???
Do controller's "own" their own areas or does the computer? Can the
computer approve a clearance through a controller's area w/o his
acknowledgement? Does a controller need the computer to approve what
he does in his area?
-Robert
Old March 26th 07, 10:02 PM posted to rec.aviation.ifr
Bob Gardner
I don't pretend to be an expert, but my educated guess is that each
controller is interested only in his/her own airspace and doesn't really
care about what happens after you are handed off to the next sector.
Bob Gardner
home.
-Robert
Old March 26th 07, 10:05 PM posted to rec.aviation.ifr
Robert M. Gary
But the question is, does he care about clearances through his
airspace issued by other controllers? And, does he know what
clearances aircraft have that enter his airspace?
-Robert
Old March 26th 07, 11:14 PM posted to rec.aviation.ifr
Mitty
Well, he has a flight strip with the full clearance on it (or in some cases an
electronic flight strip -- ZMP is in the process of conversion.)
If you are getting vectors, he may not have the vector though. I don't believe
that the automated handoff has any facility for passing the vector information,
although part of the data tag in a handoff (from Center to a TRACON for example)
can indicate the runway that the flight is being vectored for.
I just spent 3 hours plugged in at several positions in the MSP TRACON and one
of the things I learned is that when you check in with a new controller and have
been getting vectors they like you to include your assigned heading. For
example, "Cherokee November blah blah blah is level at 7 thousand, heading zero
two zero" and not just "Cherokee November blah blah blah is level at 7 thousand"
which is what I had been doing.
Another interesting thing I learned was that the TRACON radar doesn't show the
little vector that indicates direction of flight like the Center radars do.
There's just the target dot and the data block. So you can sin big time on your
heading and, if you don't sin too long, the controller will never know. At MSP
anyway.
Some of the controllers will undoubtedly chime in here.
On 3/26/2007 4:05 PM, Robert M. Gary wrote the following:
-Robert
Old March 27th 07, 12:38 AM posted to rec.aviation.ifr
John R. Copeland
"Robert M. Gary" wrote in message oups.com...
-Robert
I think there's some coordination that we pilots don't see.
Occasionally I go from central Ohio to northern Minnesota via
FWA OSH AUW BJI, which narrowly skirts some special-use airspaces.
One Sunday morning before reaching Ft Wayne, a ZID controller
asked me if I'd like to go direct Bemidji.
I answered, "Yes, but they usually won't let me do that."
Her reply: "It's not busy this morning. I think I can work it out for you."
And she did. And I thanked her for that.
Old March 27th 07, 03:24 AM posted to rec.aviation.ifr
Newps
The clearance is on the strip. If it's different the previous
controller is required to coordinate.
That's a requirement of the previous controller.
Old March 27th 07, 03:28 AM posted to rec.aviation.ifr
Newps
The previous controller is required to coordinate that.
I don't
believe that the automated handoff has any facility for passing the
vector information, although part of the data tag in a handoff (from
Center to a TRACON for example) can indicate the runway that the flight
The center has no control over my data tag. The center does not vector
to a runway, that is an approach controls job.
show the little vector that indicates direction of flight like the
Center radars do.
That's because center controllers are retarded and wouldn't know which
way the little airplanes are moving if the computer doesn't tell them.
Old March 27th 07, 03:33 AM posted to rec.aviation.ifr
Newps
If I change your clearance before you takeoff I will make the change in
the computer. It is the centers responsibility to get those updates.
If I clear you direct after takeoff I am locked out of making changes in
the computer and have to coordinate over the landline.
A controller owns his own airspace. No computer owns anything.
Can the
acknowledgement?
The computer does not approve/disapprove a clearance other than not
accepting a clearance that doesn't work. For example trying to input
going from one airway to another when those two airways don't cross or
otherwise meet. You can always clear someone direct.
Old March 27th 07, 03:57 AM posted to rec.aviation.ifr
John R. Copeland
"Newps" wrote in message . ..
Center radars do.
ROTFL! Good zinger, Newps.
Old March 27th 07, 05:41 AM posted to rec.aviation.ifr
Robert M. Gary
So, last night my updated direct clearance affected my route through 4
controller's airspace ( I have 4 handoffs since). Did the issuing
controller have to call all 4 of those controllers before giving me
the clearance?
-Robert
Big Debts are costing troops their Security clearances Tiger Naval Aviation 8 October 28th 06 01:53 AM
Obtaining IFR clearances in Canada Andrew Sarangan Instrument Flight Rules 10 July 22nd 04 03:47 PM
Question: civilian contractors and security clearances Charlie Wolf Naval Aviation 5 July 6th 04 03:54 AM
Clearances for Practice Jerry Kaidor Instrument Flight Rules 1 March 28th 04 07:00 PM
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 02:51 AM
