Google Earth Question
Old March 27th 07, 04:49 PM posted to rec.aviation.piloting
john smith[_2_]
Default Google Earth Question
Is it possible to build an automated flight path file for download onto
Google Earth?
An example would be patch and altitude for the RIPON Arrival into KOSH.
If Google ever gets around to upadating that area to high res, it would
be a good addition to the AirVenture website for those who do not have a
copy of the video taped arrival.
Old March 27th 07, 10:27 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"john smith" wrote in message
Google Earth?
Ask over on rec.aviation.soaring - I believe that there is existing software
to do this.
Geoff
Old March 27th 07, 10:46 PM posted to rec.aviation.piloting
onto Google Earth?
I know that if you have a series of lat/lon points, you can roll your
own KML file with the points and Google Earth will accept it. On a
car trip, I logged the raw serial-port output (NMEA sentences) of a
GPS, then wrote a program to pull out the latitude and longitude data
and put it in a KML file, which Google Earth then loaded with no
problem. (Yes, I know there are programs that will do this for you,
but that wasn't the point.)
I don't know if it's possible to create a file that will draw lines on
the Google Earth image or create a "fly-through" of defined points, but
I suspect it is.
would be a good addition to the AirVenture website for those who
do not have a copy of the video taped arrival.
If you have a high-res picture of the area in question (preferably
shot straight down), you can tell Google Earth to display it on top
of whatever satellite images it has. This might only be practical
for a relatively small area, though.
Matt Roberds
Old March 28th 07, 11:51 PM posted to rec.aviation.piloting
Darkwing
Google Earth?
Not *exactly* what you are looking for but still interesting -
http://aimsports.com/weblog/index.html#a000158
DW
Old March 29th 07, 02:56 AM posted to rec.aviation.piloting
Kev
Google Earth?
Someone wrote an addon to MSFS 2004 that fed Google Earth with your
flight path in realtime, so that you could use GE for your outside
display. Do a search for it.
Kev
Google Earth fun Al Denelsbeck Aviation Photos 4 January 11th 07 04:31 PM
Google Earth - Glider David Pye Soaring 1 June 8th 06 04:39 PM
SeeYou 3D and Google Earth [email protected] Soaring 4 May 23rd 06 04:24 AM
Google Earth - Soaring Sites [email protected] Soaring 5 March 23rd 06 04:08 AM
Google Earth ttaylor at cc.usu.edu Soaring 8 September 22nd 05 12:07 PM
