Boeing prepares fuel cell Motorglider
Old March 28th 07, 03:55 PM posted to rec.aviation.soaring
Default Boeing prepares fuel cell Motorglider
The demonstrator aircraft is a Dimona motor glider, built by Diamond
Aircraft Industries of Austria, which also performed major structural
modifications to the aircraft. With a wing span of 16.3 meters (53.5
feet), the airplane will be able to cruise at approximately 100
kilometers per hour (62 miles per hour) using fuel cell-provided
power.
More info and picture www.aerogazette.com
Old March 29th 07, 01:30 AM posted to rec.aviation.soaring
Vaughn Simon
power.
The glider uses lithium batteries plus the fuel cell to get sufficient
power for launching. According to the Boeing diagram
http://boeingmedia.com/imageDetail.c...90&clr=release it has a crazy-tiny
hydrogen (fuel) tank. First, it appears to use compressed hydrogen rather than
liquid hydrogen, but even liquid hydrogen would need significantly more volume
than an equivalent amount of gasoline. Definitely just a technology
demonstration stunt, not a practical aircraft.
Vaughn
Old March 29th 07, 04:26 PM posted to rec.aviation.soaring
SAM 303a
"Vaughn Simon" wrote in message
power.
crazy-tiny hydrogen (fuel) tank. First, it appears to use compressed
hydrogen rather than liquid hydrogen, but even liquid hydrogen would need
significantly more volume than an equivalent amount of gasoline.
Definitely just a technology demonstration stunt, not a practical
aircraft.
Vaughn
That may be true, but it is the coolest v1.0 technology I've seen in a
while.
Old March 29th 07, 05:44 PM posted to rec.aviation.soaring
Mike Lindsay
Vaughn Simon writes
Vaughn
Yes. No doubt they said much the same about Orville and Wilbur's 1903
Flyer.
Mike Lindsay
Old March 29th 07, 06:40 PM posted to rec.aviation.soaring
Big John
This could well be a system to use in Iraq. Electric motor so no
noise. IR and millimeter Radar systems aboard. Could cruise over town
and watch for IED's beng planted without the bad guys knowing they
were being watched.
Hope this is the end result.
Big John
power.
www.aerogazette.com
Fuel Cell Demonstrator Airplane Larry Dighera Piloting 3 March 28th 07 02:51 PM
Exposed Electrical Wires in Boeing 737 Fuel Tanks! Larry Dighera Piloting 0 July 17th 06 06:13 PM
Bush Prepares for Possible GPS Shutdown Chris Gumm Piloting 74 December 20th 04 04:48 PM
Bastogne: The AAC Prepares ArtKramr Military Aviation 6 December 22nd 03 02:58 PM
Boeing to fly fuel-cell GA plane... DeltaDeltaDelta Piloting 6 July 15th 03 07:25 PM
