Centerlines on taxiways
Old March 31st 07, 11:04 PM posted to rec.aviation.piloting,rec.aviation.student
Pixel Dent
Default Centerlines on taxiways
Mxsmanic wrote:
Doesn't anyone have an answer to this question?
If anyone gives you an answer you will just proceed to tell him that he
must be wrong. In interest of saving time you should probably just skip
the initial question, tell us that all the answers you would have
received are wrong, and we'll all be happier that way.
Old March 31st 07, 11:10 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Maxwell writes:
Of course not. At least not one that would be acceptable to your
standards.
My standards require that the FARs be observed, so you may be right, at least
in the case of some respondents.
Old March 31st 07, 11:12 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Pixel Dent writes:
must be wrong.
I don't think anyone here has the answer, so that's a moot assumption.
Old April 1st 07, 01:29 AM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
Pixel Dent writes:
must be wrong.
I would bet 95% of us know, and the other 5% will recall the minute they
hear the answer.
Old April 1st 07, 01:32 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Maxwell writes:
hear the answer.
Nope. There aren't too many 747 pilots on this newsgroup.
Old April 1st 07, 02:37 AM posted to rec.aviation.piloting,rec.aviation.student
Darkwing
Maxwell writes:
hear the answer.
Your not even a C150 pilot so why don't you go back to sim-land little boy.
DW
Old April 1st 07, 03:35 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Darkwing writes:
I prefer the 747, 737, and Baron.
Old April 1st 07, 07:00 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Mxsmanic wrote in
Maxwell writes:
You're missing something.
Okay, what am I missing?
Marbles?
Bertie
Old April 1st 07, 07:01 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Darkwing writes:
little boy.
You have never flown any of them. While I...
BTW, I stil haven't got your $25 asswipe.
Bertie
Old April 1st 07, 08:45 PM posted to rec.aviation.piloting
"JonH" wrote in
I'll bite.
My experience with 747s and taxiing is that, when approaching a 90
degree LH turn, for instance, the plane will be steered passed the (LH
turn) centerline and continue straight until that LH centerline is
about even with my shoulder. (That is to say that if you put a yard
stick across my chest, it will be pointing straight down the taxi-way
that I want to go to) At that point a LH turn is then started. The
nose wheel is turned slightly sharp and to a point midway between taxi
way edge and centerline for a second or two (assuming 8 knot GS ) and
then it is brought right to the centerline for a decent turn. While in
the turn your vision in front of the plane is nothing but weeds and
dirt. The reasons for this method have been hit upon befo You must
keep the main gear on the center portion of the taxi way or otherwise
risk stuck and/or damaged plane. With that gear so far behind you -
100ft? - you must overshoot your turn, or run off the taxi way.
777s are pretty much the same.
Give th eman a cigar.
Bertie
Odd sight at JFK near A and J taxiways Teacherjh Piloting 1 February 11th 04 08:22 PM
