#31
"Jose" wrote in message . .. No. The altimeter senses pressure at the level of the instrument itself. It indicates altitude depending on its calibration and kollsman setting. You're contradicting yourself. |
#32
The static lines are vented to the atmosphere, so the change in pressure
with altitude takes place in the static lines just as it does in the atmosphere. That's not logic, that's physics. Many things that are logical (heavy objects fall faster) are not supported by the laws of physics. That degree of physics knowledge is not necessary to piloting an aircraft (though it is helpful), thus I expect not all pilots know this. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#33
"Jose" wrote in message ... Many things that are logical (heavy objects fall faster) are not supported by the laws of physics. That's not logical. |
#34
It indicates altitude depending on its calibration and kollsman setting. You're contradicting yourself. Only if pressure and altitude are the same. And only if sensing and indicating are the same. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#35
That's not logical.
Of course it's logical. The heavier they are, the more force is exerted on them. You can test this by dropping a stone and a feather. As it turns out, in our universe, increased inertia exactly counterbalances the increased gravitational force, but there is no (logical) reason for the universe to operate that way. In fact, I am not convinced that it does operate that way to the last decimal point. If logic were sufficient, there would be no experimental physics. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#36
Huh? Drag force isn't logical.
It is to me. No, it is merely consistant with your experience. That is empirical, not theoretical. Drag force can be derived in theory, but that requires knowledge of atoms and molecules, which themselves are not logical. The universe could be made up of wiggly strings, for all we know. That it is made up of atoms is another =experimental= result. That they are governed by quantum mechanics is yet =another= experimental result, which is most =definately= not logical. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#37
Recently, Steven P. McNicoll posted:
"Jose" wrote in message t... Poor logic. An altimeter indicates whatever it is set to indicate. It senses pressure, and moves hands on a dial. Take the case where you are in a one hundred foot tall aircraft with the altimeter right at the top of the cockpit with you, a hundred feet in the air. (We'll neglect the tail for now). If you don't get an altimeter setting, you will (likely) set the altimeter so that the hands indicate the airport elevation as indicated on your charts, even though you and the instrument are a hundred feet higher. If you do get an altimeter setting, you'll set it for that. Then the question becomes (since the altimeter doesn't know that it's in a tall airplane) whether, at calibration in the shop, it was set to indicate actual instrument altitude or to indicate something else (like instrument altitude minus a hundred feet). I bet there are standards for that. I don't know what they are, but they may well incorporate the hundred feet deviation, since it is the =installation= that is certified. Also, even if the static port and the instrument themselves are separated in altitude, it would be the instrument altitude's pressure that is sensed, since the "column of air" is connected, and ends at the instrument. In other words, an altimeter indicates altitude at the level of the instrument itself. Perhaps you misunderstood Jose's example, but I believe he's correct; while an altimeter senses the pressure at the level of the insturment, it *indicates* the calibration set by either the shop (e.g. compensating for the altitude of the installation) or the pilot via the Kollsman window. Neil |
#38
"Jose" wrote in message t... Of course it's logical. The heavier they are, the more force is exerted on them. You can test this by dropping a stone and a feather. I'd have to do it in a vacuum to eliminate the drag force. |
#39
"Neil Gould" wrote in message et... Perhaps you misunderstood Jose's example, but I believe he's correct; while an altimeter senses the pressure at the level of the insturment, it *indicates* the calibration set by either the shop (e.g. compensating for the altitude of the installation) or the pilot via the Kollsman window. I understood it, I didn't say he was wrong. |
#40
I agree that it measures pressure and that the indicated altitude is based
on calibration. I agree that it could be calibrated for the bottom, mid, or top of the plane (for whatever it would matter). Personally, my altimeter was calibrated sitting on a bench with no regard for the difference in height between the landing gear, the static port, or the position of the altimeter. From a purely theoretical view, I don't think you can say that an altimeter measures pressure at the location of the instrument. It's a closed system to the static port. While the pressure inside the tubing will respond to elevation changes similar to the open atmosphere, there is a difference. Admitedly, the difference over the height of an aircraft is insignificant. But stretch that tubing to a low pressure system in the next state and your altimeter will defininetly not be reading the local pressure. The question remains, are big airplane altimeters calibrated to account for the distance between the landing gear and the instrument. Someone else asked about when setting the altimeter based on field elevation rather than by Kollsman setting. Another way to ask the question is, "When setting the altimeter to field elevation in a tall airliner, how close is the Kollsman value to the local barametric pressure?" -- ------------------------------- Travis Lake N3094P PWK "Jose" wrote in message . .. In other words, an altimeter indicates altitude at the level of the instrument itself. No. The altimeter senses pressure at the level of the instrument itself. It indicates altitude depending on its calibration and kollsman setting. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
| Deck height | Sean Trost | Home Built | 5 | July 16th 04 04:46 AM |
| Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 05:56 PM |
| Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 04:14 PM |
| Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 08:42 AM |
| Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 03:31 PM |
