Most of you have never heard of Vernon Payne. He's best known as the designer
of a spiffy little biplane called the Knight Twister. Rag & tube fuselage, solid spruce spars, plywood skins on cantilevered wings. Slicker than snot on a door knob. First flew about 1929 and continues doing so today and very well, too. Ask him nice, Vern would build you a set of wings. Fuselage, too. For a short while when he was moving out of his place north of Escondido I worked for Vernon. Not what you'd call a real job even though the sweat was real enough. Mostly helping him prepare for the move, which involved finishing a set a wings he was working on, prepping a fuselage and other minor chores. Skinning a wing, Vern soaked each piece of plywood, fitted it to the wing and let it dry in place. The old barn we worked in was good for that sort of thing, hot and dry and no distractions other than Taddy, the shop cat who like to watch. After the ply had dried to the required shape Vern would check the fit with a bit of chalk, make any adjustments. The fitted panels of the beautiful double-tapered wings were glued all at once using Weldwood ‘Plastic Resin' and nailing strips. Lots of nailing strips, most of which were also pre-molded to match their particular rib, both of us working away with our tiny tack hammers, taking our time but not wasting any, doing it right so we wouldn't have to do it over. And we'd talk. Vern had boots that was older than me but I wasn't no kid; I knew who Gilmore was and the joke about aviation-grade horsemeat, which meant Vern could talk without having to explain every other word. I suspect he needed the companionship as much as the help, working all alone out there in that old barn north of Escondido, having to finish those wings and move a life-time of stuff because the Yuppies were kicking him out. I usually had a sketch book with me, a life-long habit. Vern didn't like it when he saw me sketching the engine arrangement of his latest project, a two-place VW powered thing he called the Dolphin. I gave him the book, told him to tear out anything he didn't want me to have. He flipped through it and saw Taddy curled up atop the blueprint cabinet and a chiaroscuro study created by a slice of sunlight falling across a steel tube fuselage. And of Vern too, bent over the wing, pensive look on his face as he examines a tip rib smaller than a pocket ruler. He gave me back the sketch book, didn't tear anything out. We got to talking about landing gear, which kind was best; that sort of thing. It was an interesting subject to me because I'd just made a composite gear leg out of wood, fiberglas and good intentions that busted all to hell when I did a drop-test. Vernon told me how the CAA used to have a standard formula for acceptable landing gear strength and a drop-test calculation based on the gross weight, a Jesus factor and the stalling speed of that particular aircraft. Then he said, ‘I just used the worse-case, which was fifty inches.' Later, I made a note of that on the corner of a sketch of a landing gear. - - Worse case = 50" - - I don't know exactly when that was. Back in the eighties. About three years ago I wanted to compare the performance of different types of landing gear for a particular design and made up a drop-tester that allowed precise control of the height and the angle at which the wheel contacted the ground. The gear leg bolted to a plate on the end of a long arm that was raised by a little derrick using a screw-thread winch off a boat trailer. I used a glider hook as the release mechanism and welded a tray to the top of the arm so I could stack on plates of lead and scrap iron for the weight. It's quite an affair. Really shook the ground when it hit. And busted everything I tried. (Some of you may have seen pictures of the knee-action gear leg I posted over on the Fly5k mailing list. There were a number of others. All initially failed the drop-test.) I soon became quite the expert at drop-testing. As I gained experience I began to understand how the load enters into the structure and saw ways to make the gear legs stronger without adding too much weight. But always some. It was pretty obvious that most landing gear used on modern airplanes couldn't even come close to that ancient CAA requirement. By the time I got something that was strong enough to withstand the worse-case fifty-inch drop, it was huge. And heavy. More suitable for the NYP with a full load of fuel than a single-place do-it-yourself puddle jumper with a converted VW on the nose. Fiberglas offered some advantages, as did oleo-pneumatic systems but their cost and complexity put them far beyond the means of a first-time builder on a tight budget. It was all rather discouraging. A couple of days ago I was digging through a file looking for... I can't remember what... when I came across a blurry copy of a 1930's article by Raoul J. Hoffmann, the aeronautical engineer who crunched the numbers for Matty Laird. Hoffman was one of my dad's heros and it was a good choice. The article was titled ‘Landing Gear Shock Stresses' and included the usual boilerplate formulae, a couple of graphs and a few column-inches of text. I'd seen it before, hadn't looked at it too closely since I'd already decided to emulate Vernon Payne's method of using the worse-case drop height. But as I scanned the article something jumped out at me. "...drop from a height in inches equal to .38 times the calculated stalling speed in miles per hour... (but) ...not over 15 INCHES for conventional airplanes." FIFTEEN inches. Not fifty. I sat down and ran the numbers. Maximum applied load not to exceed 5.5 times the gross weight (I've been using 6.0). But the drop test need not exceed FIFTEEN inches. I've been using fifty. No wonder my gear legs came out like something off the Dreadnaught. - - - - - - - - - - - - - - - - Taddy came to live with us after Vern and his wife moved into a place that didn't allow pets. They would drop by now and then to say hello, more to Taddy than us but they were nice visits. Vern passed away a few years ago but will never be forgotten. His little bipe is a rare combination of art and science, as was Vernon Payne himself. Ignorance is mankinds normal state, alleviated by information and experience. Much of that experience is negative; we learn to do things right by doing it wrong. If fate gives us another shot at it, we do it differently the next time around. Once we learn to do things right we become the local expert, the fellow who can show you how to kill a grizzly with a spear or attach a propellor to a pulley hub. But as Smokey Yunick once said, "Most experts aren't." And I'd just proved him right because nothing leads us astray faster than the things we THINK we know. Vern was a pro; he obviously said ‘fifteen' and I heard it as fifty. -R.S.Hoover |
Great tribute to the man.
There is a Twister (Nagle Twister, look in Reno race results) at 4n0 (Newman's Field) here in Kalamazoo, flown by Bill. It is indeed a scooter. -- Dan D. .. "Veeduber" wrote in message ... Most of you have never heard of Vernon Payne. He's best known as the designer of a spiffy little biplane called the Knight Twister. Rag & tube fuselage, solid spruce spars, plywood skins on cantilevered wings. Slicker than snot on a door knob. First flew about 1929 and continues doing so today and very well, too. Ask him nice, Vern would build you a set of wings. Fuselage, too. For a short while when he was moving out of his place north of Escondido I worked for Vernon. Not what you'd call a real job even though the sweat was real enough. Mostly helping him prepare for the move, which involved finishing a set a wings he was working on, prepping a fuselage and other minor chores. Skinning a wing, Vern soaked each piece of plywood, fitted it to the wing and let it dry in place. The old barn we worked in was good for that sort of thing, hot and dry and no distractions other than Taddy, the shop cat who like to watch. After the ply had dried to the required shape Vern would check the fit with a bit of chalk, make any adjustments. The fitted panels of the beautiful double-tapered wings were glued all at once using Weldwood 'Plastic Resin' and nailing strips. Lots of nailing strips, most of which were also pre-molded to match their particular rib, both of us working away with our tiny tack hammers, taking our time but not wasting any, doing it right so we wouldn't have to do it over. And we'd talk. Vern had boots that was older than me but I wasn't no kid; I knew who Gilmore was and the joke about aviation-grade horsemeat, which meant Vern could talk without having to explain every other word. I suspect he needed the companionship as much as the help, working all alone out there in that old barn north of Escondido, having to finish those wings and move a life-time of stuff because the Yuppies were kicking him out. I usually had a sketch book with me, a life-long habit. Vern didn't like it when he saw me sketching the engine arrangement of his latest project, a two-place VW powered thing he called the Dolphin. I gave him the book, told him to tear out anything he didn't want me to have. He flipped through it and saw Taddy curled up atop the blueprint cabinet and a chiaroscuro study created by a slice of sunlight falling across a steel tube fuselage. And of Vern too, bent over the wing, pensive look on his face as he examines a tip rib smaller than a pocket ruler. He gave me back the sketch book, didn't tear anything out. We got to talking about landing gear, which kind was best; that sort of thing. It was an interesting subject to me because I'd just made a composite gear leg out of wood, fiberglas and good intentions that busted all to hell when I did a drop-test. Vernon told me how the CAA used to have a standard formula for acceptable landing gear strength and a drop-test calculation based on the gross weight, a Jesus factor and the stalling speed of that particular aircraft. Then he said, 'I just used the worse-case, which was fifty inches.' Later, I made a note of that on the corner of a sketch of a landing gear. - - Worse case = 50" - - I don't know exactly when that was. Back in the eighties. About three years ago I wanted to compare the performance of different types of landing gear for a particular design and made up a drop-tester that allowed precise control of the height and the angle at which the wheel contacted the ground. The gear leg bolted to a plate on the end of a long arm that was raised by a little derrick using a screw-thread winch off a boat trailer. I used a glider hook as the release mechanism and welded a tray to the top of the arm so I could stack on plates of lead and scrap iron for the weight. It's quite an affair. Really shook the ground when it hit. And busted everything I tried. (Some of you may have seen pictures of the knee-action gear leg I posted over on the Fly5k mailing list. There were a number of others. All initially failed the drop-test.) I soon became quite the expert at drop-testing. As I gained experience I began to understand how the load enters into the structure and saw ways to make the gear legs stronger without adding too much weight. But always some. It was pretty obvious that most landing gear used on modern airplanes couldn't even come close to that ancient CAA requirement. By the time I got something that was strong enough to withstand the worse-case fifty-inch drop, it was huge. And heavy. More suitable for the NYP with a full load of fuel than a single-place do-it-yourself puddle jumper with a converted VW on the nose. Fiberglas offered some advantages, as did oleo-pneumatic systems but their cost and complexity put them far beyond the means of a first-time builder on a tight budget. It was all rather discouraging. A couple of days ago I was digging through a file looking for... I can't remember what... when I came across a blurry copy of a 1930's article by Raoul J. Hoffmann, the aeronautical engineer who crunched the numbers for Matty Laird. Hoffman was one of my dad's heros and it was a good choice. The article was titled 'Landing Gear Shock Stresses' and included the usual boilerplate formulae, a couple of graphs and a few column-inches of text. I'd seen it before, hadn't looked at it too closely since I'd already decided to emulate Vernon Payne's method of using the worse-case drop height. But as I scanned the article something jumped out at me. "...drop from a height in inches equal to .38 times the calculated stalling speed in miles per hour... (but) ...not over 15 INCHES for conventional airplanes." FIFTEEN inches. Not fifty. I sat down and ran the numbers. Maximum applied load not to exceed 5.5 times the gross weight (I've been using 6.0). But the drop test need not exceed FIFTEEN inches. I've been using fifty. No wonder my gear legs came out like something off the Dreadnaught. - - - - - - - - - - - - - - - - Taddy came to live with us after Vern and his wife moved into a place that didn't allow pets. They would drop by now and then to say hello, more to Taddy than us but they were nice visits. Vern passed away a few years ago but will never be forgotten. His little bipe is a rare combination of art and science, as was Vernon Payne himself. Ignorance is mankinds normal state, alleviated by information and experience. Much of that experience is negative; we learn to do things right by doing it wrong. If fate gives us another shot at it, we do it differently the next time around. Once we learn to do things right we become the local expert, the fellow who can show you how to kill a grizzly with a spear or attach a propellor to a pulley hub. But as Smokey Yunick once said, "Most experts aren't." And I'd just proved him right because nothing leads us astray faster than the things we THINK we know. Vern was a pro; he obviously said 'fifteen' and I heard it as fifty. -R.S.Hoover |
I know it's going to vary with the flexibility of the gear, but in the
references is there any spec for max G's a gear should handle? On 10 Sep 2003 21:32:44 GMT, (Veeduber) wrote: : :Ignorance is mankinds normal state, alleviated by information and experience. :Much of that experience is negative; we learn to do things right by doing it :wrong. If fate gives us another shot at it, we do it differently the next time :around. Once we learn to do things right we become the local expert, the :fellow who can show you how to kill a grizzly with a spear or attach a ropellor to a pulley hub. But as Smokey Yunick once said, "Most experts:aren't." And I'd just proved him right because nothing leads us astray faster :than the things we THINK we know. Vern was a pro; he obviously said :‘fifteen' and I heard it as fifty. -- My name is Nobody |
wrote: I know it's going to vary with the flexibility of the gear, but in the references is there any spec for max G's a gear should handle? precisely 1.2370814 more than it will *ever* be subjected to. grin On 10 Sep 2003 21:32:44 GMT, (Veeduber) wrote: : :Ignorance is mankinds normal state, alleviated by information and experience. :Much of that experience is negative; we learn to do things right by doing it :wrong. If fate gives us another shot at it, we do it differently the next time :around. Once we learn to do things right we become the local expert, the :fellow who can show you how to kill a grizzly with a spear or attach a ropellor to a pulley hub. But as Smokey Yunick once said, "Most experts:aren't." And I'd just proved him right because nothing leads us astray faster :than the things we THINK we know. Vern was a pro; he obviously said :‘fifteen' and I heard it as fifty. -- My name is Nobody |
"Veeduber" wrote ...
A couple of days ago I was digging through a file looking for... I can't remember what... when I came across a blurry copy of a 1930's article by Raoul J. Hoffmann, the aeronautical engineer who crunched the numbers for Matty Laird. Hoffman was one of my dad's heros and it was a good choice. The article was titled 'Landing Gear Shock Stresses' and included the usual boilerplate formulae, a couple of graphs and a few column-inches of text. I'd seen it before, hadn't looked at it too closely since I'd already decided to emulate Vernon Payne's method of using the worse-case drop height. But as I scanned the article something jumped out at me. "...drop from a height in inches equal to .38 times the calculated stalling speed in miles per hour... (but) ...not over 15 INCHES for conventional airplanes." FIFTEEN inches. Not fifty. You could have backed out the number from FAR23.473(d) but who reads the regs. (d) The selected limit vertical inertia load factor at the center of gravity of the airplane for the ground load conditions prescribed in this subpart may not be less than that which would be obtained when landing with a descent velocity (V), in feet per second, equal to 4.4 (W/S)\1/4\, except that this velocity need not be more than 10 feet per second and may not be less than seven feet per second. Rich |
ChuckSlusarczyk wrote: In article , Veeduber says... MAJOR SNIP of a good story: Ignorance is mankinds normal state, alleviated by information and experience. Much of that experience is negative; we learn to do things right by doing it wrong. If fate gives us another shot at it, we do it differently the next time around. Once we learn to do things right we become the local expert, the fellow who can show you how to kill a grizzly with a spear or attach a propellor to a pulley hub. But as Smokey Yunick once said, "Most experts aren't." And I'd just proved him right because nothing leads us astray faster than the things we THINK we know. Vern was a pro; he obviously said ‘fifteen' and I heard it as fifty. Great story!!Just goes to show how sometimes we just don't hear right :-) Thanks Chuck S Maybe that is Juan and zoomer's problem, huh? |
Richard Isakson cited the present-day FAR's as saying:
load conditions prescribed in this subpart may not be less than that which would be obtained when landing with a descent velocity (V), in feet per second, equal to 4.4 (W/S)\1/4\, except that this velocity need not be more than 10 feet per second and may not be less than seven feet per second. ---------------------------------------------------------- Yeah, that cleared things up :-) For everyone else who didn't get it, the object of the message was to illustrate that I DIDN'T check the numbers because I THOUGHT I already knew them. (And being ex-Navy a four-foot drop-test sounded good to me :-) ---------------------------------------------- To put the matter into a more understandable perspective, my drop-tests were generating loads on the order of 100,000 lb-ft of energy. Had I been using the figures Rich cites (ie, 7fps) the loads would have been about 18,000 lb-ft. Drop something a distance of 15" and it will be traveling about nine feet per second when it hits the ground. With a drop-weight of 750 pounds that will result in a load of about thirty thousand pounds, an amount that should have been easily handled by the 5/8" axles, thin-walled tubing and quarter-inch bolts used in my original landing gear. ----------------------------------------- As a further point of interest the 15" height cited by Vernon Payne as the worse-case according to 1930's CAA acceptance standards is well within the envelop allowed for light aircraft under the modern-day standard cited by Rich. (The modern-day worse case works out to about 19") ------------------------------------------ But that WASN'T THE POINT. Being aviation types I assumed everyone already knew that stuff, that you'd start to smile when you saw the first mention of FIFTY INCHES for a drop test and would be laughing along with me by the time I got to the punch line. However, if ANY of this is new to you, I suggest you hit the books. There's only a couple of equations invovled here, one for the gravitational constant of acceleration, the other for energy in motion. And if you think I'm a whiz kid, the joke's on you :-) I managed to escape the rigors of a formal education by going to sea at a young age. -R.S.Hoover - PS -- Reading over that, maybe the joke IS on you. Or on America. A lot of the stuff I was taught in gammar school more than fifty years ago is now considered College Level material. I was about eleven years old when they hit us with 'Mechanics of Motion,' a chapter we were expected (and required) to master before the Christmas break. Today, 'education' appears to have become a largely SOCIAL activity of which the acquisition of knowledge is a mere by-product, given little emphasis. Nowadays they need a seventy dollar text book the size of a coffee table to teach that one chapter. 'Newton's Laws' or some damn thing. Mostly white space except for all the pretty pictures. Then they spend a full year spoon-feeding that pap to youngsters already old enough to vote. Americans may not be any less intelligent now as then but devoting a full year to what every schoolboy picked up in a couple of weeks isn't what I'd call smart. -- rsh |
Veeduber wrote:
But that WASN'T THE POINT. Being aviation types I assumed everyone already knew that stuff, that you'd start to smile when you saw the first mention of FIFTY INCHES for a drop test and would be laughing along with me by the time I got to the punch line. No argument with what you posted, just an anecdote. I witnessed some of the drop tests of the T-45 (they Navy's newest jet trainer). The spec called for a 24 ft/sec sink rate endpoint. That's a drop from about 9 ft. The drop fixture was surrounded by chain link mesh, presumably to keep airplane bits from flying across the shop floor. The mesh served its purpose on at least one test I saw. So did the drip pans set to catch leaking hydraulic fluid g Dave 'did you hear a thump?' Hyde |
Sadly it's not much of a joke. At the rate things are degrading the next Dark
Ages aren't that inconceivable or that far off. There may be a lot more collective knowledge today than there was 50 years ago (and I'm not too sure about that) but the level of general knowledge among the population here in the US - HAS - declined and is pathetic. (why else would the have to skew the SAT scores 200 points to get the same numbers they did 20 years ago?) One should have at least a rudimentary knowledge of the way things that directly effect his/her life work. Relying on the advice and productivity of "professionals trained to do that" without even the most basic understanding leaves one very vulnerable to both the laws of nature and your unscrupulous fellow man. For what it's worth I got the point of the original post, found it amusing and entertaining. I almost went down the exact same path before I read the specs in part 23, but my worst case was a "student's stall landing from 6 feet. Thats how they got the number" ================= - PS -- Reading over that, maybe the joke IS on you. Or on America. A lot of the stuff I was taught in gammar school more than fifty years ago is now considered College Level material. I was about eleven years old when they hit us with 'Mechanics of Motion,' a chapter we were expected (and required) to master before the Christmas break. Today, 'education' appears to have become a largely SOCIAL activity of which the acquisition of knowledge is a mere by-product, given little emphasis. |
