#61
![]() "Neil Gould" wrote in message et... Recently, Steven P. McNicoll posted: "Neil Gould" wrote in message et... Perhaps you misunderstood Jose's example, but I believe he's correct; while an altimeter senses the pressure at the level of the insturment, it *indicates* the calibration set by either the shop (e.g. compensating for the altitude of the installation) or the pilot via the Kollsman window. I understood it, I didn't say he was wrong. Perhaps I misunderstood your response. Jose stated: [...] An altimeter indicates whatever it is set to indicate. [...] and: If you don't get an altimeter setting, you will (likely) set the altimeter so that the hands indicate the airport elevation as indicated on your charts, even though you and the instrument are a hundred feet higher. If you do get an altimeter setting, you'll set it for that. Then the question becomes (since the altimeter doesn't know that it's in a tall airplane) whether, at calibration in the shop, it was set to indicate actual instrument altitude or to indicate something else (like instrument altitude minus a hundred feet). [...] To which you replied: In other words, an altimeter indicates altitude at the level of the instrument itself. How do you reconcile your comment against Jose's statements? Both statements will only be true under a very limited set of circumstances that I would think excludes "In other words...". You snipped part of Jose's message: "Also, even if the static port and the instrument themselves are separated in altitude, it would be the instrument altitude's pressure that is sensed, since the "column of air" is connected, and ends at the instrument." In other words, an altimeter indicates altitude at the level of the instrument itself. |
#62
On Apr 3, 12:11 am, TheSmokingGnu
wrote: The imaginary aircraft is sitting at Imaginary Airfield (KIMG), which sits at a billiards-table-flat 50 MSL. The aircraft's static port is mounted at the centerline of the fuselage, which is 10 feet from the ground. The instrument in question is mounted 4 feet above the centerline. What will the gauge read when set to the proper barometric scale? 50, 60, or 64 feet? Any of the above ;-) To repeat what I posted back on March 9th... The actual altimeter test is described in FAR 43 CFR Appendix E, and allowable error varies from 20' at sea level, to much more at higher altitudes. http://www.flightsimaviation.com/dat...t_43-appE.html In theory, the instrument is calibrated on the bench to read at its own height, but can later be adjusted in the aircraft to read wheel height. Whether it should be or not, doesn't seem to be addressed in the regulations that I could find. There's an old saying, that "hell for scientists" is defined as a place where all the conditions are perfect, but none of the instruments are. Kev |
#63
"Also, even if the static port and the instrument themselves are separated in altitude, it would be the instrument altitude's pressure that is sensed, since the "column of air" is connected, and ends at the instrument." In other words, an altimeter indicates altitude at the level of the instrument itself. No. Correctly it would be "In other words, an altimeter =senses= =pressure= at the level of the instrument itself." Sensing pressure and indicating altitude are two different things. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#64
if you mount an altimeter at the 100' level of a 200' tower,
equiped it with a static tube 100' long, that the altimeter will read the same regardless if end of the tube, is stationed at the top or bottom of the tower. That is a mostly true statement. Conditions inside the tube could differ from ambient conditions, this would engender a teeny (but real) difference in readings. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#65
![]() "Jose" wrote in message t... No. Correctly it would be "In other words, an altimeter =senses= =pressure= at the level of the instrument itself." Sensing pressure and indicating altitude are two different things. An altimeter senses pressure in order to indicate altitude. |
#66
Now we're getting somewhere. The pressure is sensed based on the laws of physics. The altitude is indicated based on calibration and Kollsman setting. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
#67
![]() "Jose" wrote in message t... An altimeter senses pressure in order to indicate altitude. Now we're getting somewhere. The pressure is sensed based on the laws of physics. The altitude is indicated based on calibration and Kollsman setting. Maybe I'm missing something here, but would it simplify to say: That if you mount an altimeter at the 100' level of a 200' tower, equiped it with a static tube 100' long, that the altimeter will read the same regardless if end of the tube, is stationed at the top or bottom of the tower. ????? |
#68
That's not logical.
AFAIC, logic itself describes the process of reasoning and deducing, not the axioms under which it operates. To take the falling-object-example: In a universe where gravitational force and inertia are both equally proportional to the object's mass, it follows that ceteris paribus, increased mass will not increase the object's acceleration. In a universe where inertia increases faster with mass than gravitational force, a heavier object will ceteris paribus have a lower acceleration. Both sentences are entirely logical, that is, the final statement is inferred from the axioms in a manner conforming to the rules of logic. Whether it is applicable to the world we live in depends on whether the axioms apply to the real world. To get back to the discussion at hand, it thus makes no sense to say that "heavy objects fall faster is logical" or "heavy objects fall faster is not logical". The process of arriving at that statement is what logic is all about, a single statement thus cannot be either logical or not. You always need the axioims that you start out with, and the statement one that you get when combining the axioms. Only then can you judge whether the statement logically follows from the axioms. The statement "heavy objects fall faster" may seem more or less in line with a person's intuition, but it is in and of itself neither logical nor unlogical. |
#69
"Neil Gould" wrote in message Recently, Steven P. McNicoll posted: "Neil Gould" wrote in message Perhaps you misunderstood Jose's example, but I believe he's correct; while an altimeter senses the pressure at the level of the insturment, it *indicates* the calibration set by either the shop (e.g. compensating for the altitude of the installation) or the pilot via the Kollsman window. I understood it, I didn't say he was wrong. Perhaps I misunderstood your response. Jose stated: [...] An altimeter indicates whatever it is set to indicate. [...] and: If you don't get an altimeter setting, you will (likely) set the altimeter so that the hands indicate the airport elevation as indicated on your charts, even though you and the instrument are a hundred feet higher. If you do get an altimeter setting, you'll set it for that. Then the question becomes (since the altimeter doesn't know that it's in a tall airplane) whether, at calibration in the shop, it was set to indicate actual instrument altitude or to indicate something else (like instrument altitude minus a hundred feet). [...] To which you replied: In other words, an altimeter indicates altitude at the level of the instrument itself. How do you reconcile your comment against Jose's statements? Both statements will only be true under a very limited set of circumstances that I would think excludes "In other words...". You snipped part of Jose's message: "Also, even if the static port and the instrument themselves are separated in altitude, it would be the instrument altitude's pressure that is sensed, since the "column of air" is connected, and ends at the instrument." That part was snipped because it didn't alter or directly address what an altimeter indicates. In other words, an altimeter indicates altitude at the level of the instrument itself. I think the issue is with your use of the term "indicates altitude", which should be "senses pressure". The altimeter "indicates" via the display (dial or digital), and the display is adjustable both during installation/calibration and by the pilot to adjust for atmospheric pressure. Consider that when you tell a pilot that the "altimeter is 30.12", the pilot adjusts the _indicated altitude_ by setting the Kollsman window to that _pressure setting_. We don't watch the Kollsman (the only "indication" of "altitude" consistent with the controller's information) when trying to land. ;-) Neil |
#70
![]() "Jose" wrote in message t... Now we're getting somewhere. The pressure is sensed based on the laws of physics. The altitude is indicated based on calibration and Kollsman setting. Correct. |
Deck height | Sean Trost | Home Built | 5 | July 16th 04 03:46 AM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 03:14 PM |
Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 07:42 AM |
Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 02:31 PM |
