dave writes:
My bonanza has a 70A alternator that is belt driven off the back of the engine, IO470. Sounds more sensible than pulling a prop.... Best belt setup I ever saw was a Greyhound bus [!] w/ a ~250A/28vdc alternator. It was driven by triple belt set, tensioned by an air cylinder/regulator. When a belt broke: a) close valve b) push alternator to loosen c) remove old belts if any; put on matched set of three. d) open valve; air tightens belts to correct tension. e) start bus, drive away. Literally a 5 minute repair. Long part is getting belts from stockroom. Toyota already offers what Detroit is promising - actually I think Ford does too. My Camry Hybrid has electric power steering, electric power assist brakes, electric AC, etc. The engine only runs when it needs to. Very clever car. I've put about 1400 miles on it and so far so good. The Grand Plan was 42VDC [More V == less A for same W] cars, with a 15KV starter/alternator. It adds umph during passing situations. No lamps, all LED's/HID headlights. Valve train controlled by the FADEC-type system. So step on gas, starter spins a zero-compression engine, then valves close, fuel's injected; alleged 0.5 sec restart time at stoplight. Big plus on all electric is location is flexible; why have the compressor under the hood at all? [Think roof-rack AC system] Second plus is no exposed shaft on AC compressor, hence no Freon leakage. With hybrids, you can change the picture considerably. But lots of weight added for more battery capacity. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
David Lesher wrote:
Sounds more sensible than pulling a prop.... When you guys do pull the prop to change a belt, do you ty-wrap a spare belt to the engine, just in case? |
The OP plane has a belt driven alternator off of the accessory case, so
changing the belt is simply a matter of loosening two bolts. So far, after five hours, the last belt from Aviall (made by Continental) is still in place and working. |
B A R R Y wrote:
When you guys do pull the prop to change a belt, do you ty-wrap a spare belt to the engine, just in case? A friend does with his 172... |
I haven't in the past. The argument against is that most belts fail because
of heat and age. A tie-wrapped belt will be the same age and exposed to the same heat, maybe more. Having just replaced the belt with my mechanic, pulling the prop is no big deal. I do carry a spare belt in the back, and if I needed to, I would do the swap, use the smaller safety wire and get back to have it done in a way that could be logged. Just know the torque specs for the bolts, they're rather low considering the job they're asked to do. "B A R R Y" wrote in message et... David Lesher wrote: Sounds more sensible than pulling a prop.... When you guys do pull the prop to change a belt, do you ty-wrap a spare belt to the engine, just in case? |
"David Lesher" wrote in message ... Valve train controlled by the FADEC-type system. So step on gas, starter spins a zero-compression engine, then valves close, fuel's injected; alleged 0.5 sec restart time at stoplight. Obvious, but never occurred to me. Thanks for information. Taking the camshaft out of our IC engines is going to provide significant performance improvement and additional capabilities. The Audi V12 racing engine is diesel fueled with full electronic control of valves and injectors. Common rail injection using VERY high fuel pressure. There may be more use of 2 stroke? |
"Private" writes:
Taking the camshaft out of our IC engines is going to provide significant performance improvement and additional capabilities. The Audi V12 racing engine is diesel fueled with full electronic control of valves and injectors. Common rail injection using VERY high fuel pressure. There may be more use of 2 stroke? First I've heard of the Audi. I don't know exactly how they planned to activate the valves; there's a major amount of work involved in same, over small distances & very short times. I know various cars advance/retard the camshaft timing but that's a little easier... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
"LWG" writes:
I haven't in the past. The argument against is that most belts fail because of heat and age. A tie-wrapped belt will be the same age and exposed to the same heat, maybe more. Well, maybe. But an unstressed belt would be surely be enough to get you home again, even if several years old. And borrowed tools would install same, I'd think. [Signoff is another issue. Is belt replacement legal for an owner to do?] And I bet not all props pull & replace as easily as the one just mentioned. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
"David Lesher" wrote in message ... "Private" writes: Taking the camshaft out of our IC engines is going to provide significant performance improvement and additional capabilities. The Audi V12 racing engine is diesel fueled with full electronic control of valves and injectors. Common rail injection using VERY high fuel pressure. There may be more use of 2 stroke? First I've heard of the Audi. I don't know exactly how they planned to activate the valves; there's a major amount of work involved in same, over small distances & very short times. I know various cars advance/retard the camshaft timing but that's a little easier... http://en.wikipedia.org/wiki/Audi_R10 http://www.audiusa.com/audi/us/en2/e...sport/r10.html http://www.audiusa.com/audi/us/en2/e...di_engine.html I recently spoke to a suspension engineer for this team. He told me that the valves had magnetic stems and were actuated by electrically energizing opening and closing coils with light or no springs. This contradicts the information in the links above which refer to DOHC. I have also heard that Cat has had a running prototype heavy diesel with no camshaft. Happy landings, |
On Tue, 3 Apr 2007 16:51:32 +0000 (UTC), David Lesher
wrote: "Montblack" writes: This sounds like a case for "House" ...or in your case, "Hangar". :-) If it's easy to get at, and all other things being equal, can you swap alternators with a known good one (meaning pulley)? I've wondered about the whole idea of belt drive; given that you must pull the prop to change same. I've pondered a smooth pulley in place of the existing one, then a rubber drive wheel on the alternator/vacuum pump etc.... I suppose icing may be an issue, as well as having to locate the accessories directly adjacent to the engine axis. The other way would be driving the belt with the back of engine pulley, but that has other issues... BTW, Real Soon Now, Detroit is promising everything will be electric-driven; water pump, power steering, air conditioning, you name it. They'll build a starter/ alternator into the flywheel/bell housing area. The engine won't idle; it will stop at red lights and restart when you hit the gas... Mine works that way now and it'son purpose. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
| Who pays? | Viperdoc[_4_] | Owning | 15 | March 30th 07 05:31 AM |
| Another who pays question | Viperdoc[_4_] | Owning | 14 | March 30th 07 03:37 AM |
| It Pays to be a Pilot | Seth Masia | Piloting | 5 | November 23rd 05 11:46 AM |
| Collector pays homage to wartime aviators with his military | NewsBOT | Simulators | 0 | February 18th 05 10:46 PM |
| Reading R.A.O. pays off | The Weiss Family | Owning | 23 | September 14th 04 04:02 PM |
