I saw a video of a F35 that could vector its jet downwards, and take off
vertically. Is that to be standard on the F35 or will it be an option? |
![]() "The Old Bloke" wrote in message ... I saw a video of a F35 that could vector its jet downwards, and take off vertically. Is that to be standard on the F35 or will it be an option? Here's the link http://www.lep.co.uk/ViewArticle.asp...4&SectionID=74 |
... I saw a video of a F35 that could vector its jet downwards, and take off vertically. Is that to be standard on the F35 or will it be an option? There will be 3 variants of the F-35. The STOVL version is going to the US Marines and the Brits It's not really an 'option' because the aircraft must be built for STOVL use....you couldn't convert either of the other two models once built. -- The Raven http://www.80snostalgia.com/download...unds/wings.mp3 |
![]() "The Raven" wrote in message ... "The Old Bloke" wrote in message ... I saw a video of a F35 that could vector its jet downwards, and take off vertically. Is that to be standard on the F35 or will it be an option? There will be 3 variants of the F-35. The STOVL version is going to the US Marines and the Brits It's not really an 'option' because the aircraft must be built for STOVL use....you couldn't convert either of the other two models once built. Yeh, I know. Option was a bad choice of words. The Aus Navy has said it was going to acquire STOL F35s to operate from a Landing Platform-type ship. I never realised that the F35 was capable of vertical takeoff. |
... "The Raven" wrote in message ... "The Old Bloke" wrote in message ... I saw a video of a F35 that could vector its jet downwards, and take off vertically. Is that to be standard on the F35 or will it be an option? There will be 3 variants of the F-35. The STOVL version is going to the US Marines and the Brits It's not really an 'option' because the aircraft must be built for STOVL use....you couldn't convert either of the other two models once built. Yeh, I know. Option was a bad choice of words. The Aus Navy has said it was going to acquire STOL F35s to operate from a Landing Platform-type ship. I never realised that the F35 was capable of vertical takeoff. Only capable of vertical take off with minimal loads as I understand it. The three versions a CTOL - Conventional Take Off Landing STOVL - Short Take Off, Vertical Landing (noting the emphasis on short take off rather than vertical). CV (from memory) - Carrier Version Australia would most likely purchase the CV for somewhat similar reasons they prefer the F-111's with the longer wings. RAN will not be using F-35, the intention is to replace the F/A-18 and the F-111's. This would make it a RAAF only aircraft as the Navy have not operated any fixed wing combat aircraft for quite some time. -- The Raven http://www.80snostalgia.com/download...unds/wings.mp3 |
![]() "The Raven" wrote in message ... "The Old Bloke" wrote in message ... "The Raven" wrote in message ... "The Old Bloke" wrote in message ... I saw a video of a F35 that could vector its jet downwards, and take off vertically. Is that to be standard on the F35 or will it be an option? There will be 3 variants of the F-35. The STOVL version is going to the US Marines and the Brits It's not really an 'option' because the aircraft must be built for STOVL use....you couldn't convert either of the other two models once built. Yeh, I know. Option was a bad choice of words. The Aus Navy has said it was going to acquire STOL F35s to operate from a Landing Platform-type ship. I never realised that the F35 was capable of vertical takeoff. Only capable of vertical take off with minimal loads as I understand it. The three versions a CTOL - Conventional Take Off Landing STOVL - Short Take Off, Vertical Landing (noting the emphasis on short take off rather than vertical). CV (from memory) - Carrier Version Australia would most likely purchase the CV for somewhat similar reasons they prefer the F-111's with the longer wings. RAN will not be using F-35, the intention is to replace the F/A-18 and the F-111's. This would make it a RAAF only aircraft as the Navy have not operated any fixed wing combat aircraft for quite some time. Thanks for the input Regards |
