Altimeter Calibration Height
Old April 5th 07, 08:12 PM posted to rec.aviation.piloting
Jose
Default Altimeter Calibration Height
In other words, an altimeter indicates altitude at the level of the
instrument itself.
That seems reasonable.
But what if the instrument itself is 100 ft tall? Or maybe just 30 inches
tall? Which point on the altimeter should one pick and why?
To answer that question, one must understand that an altimeter does not
sense altitude, it senses pressure. The pressure would be some sort of
average over the entire height of the sensing surface, whose exact value
would depend on the construction of the device. That pressure would
likely be equal to the ambient pressure at some altitude within that range.
By painting appropriate numbers next to the pointer, one could get the
altimeter to indicate altitude. It is the choice of numbers that is the
issue, as that is arbitrary, and not subject to the laws of physics,
only to the laws of the FAA.
Jose
Get high on gasoline: fly an airplane.
  #102
Old April 5th 07, 11:00 PM posted to rec.aviation.piloting
Neil Gould
Recently, Steven P. McNicoll posted:
"Neil Gould" wrote in message
t...
After puzzling the difficulties that several of us have had in
trying to explain the differences between "indicated" (e.g. what the
pilot sees) -- and "senses" (how the altimeter is calibrated), I can
only guess that for you, sitting in the tower, there is no practical
difference because you are always at the same altitude. ;-) You
can review some of the excellent explanations that Jose and others
have provided to answer your question.
What made you think I needed the difference between "indicated" and
"senses" explained to me?
Your usage of the two terms.
Let's take a different tack, maybe this will help.
BTDT, and understand the mechanics involved. I do appreciate your
challenges that make me think about this more thoroughly, though. Also,
consider the distinction between calibration and adjustment, where
calibration is how the altimeter is installed, and adjustment is made via
the Kollsman window/knob. Both of these factors can affect the indicated
altitude regardless of the actual altitude of the altimeter.
Neil
  #103
Old April 6th 07, 12:03 AM posted to rec.aviation.piloting
Matt Whiting
Yes, great idea.
Take an altimeter and set it on a table. Don't move it!
Turn the knob that adjusts the pressure scale to one extreme. Record
the indication on the face of the altimeter. Now turn the knob to the
other extreme of travel. Record the indication on the face of the
instrument. Now the big question: which value recorded is the altitude
at the level of the instrument?
Matt
  #104
Old April 6th 07, 12:40 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Matt Whiting" wrote in message
news
Right and the altitude indicated has little to do with the altitude of
the instrument.
Right. That's why changing the altitude of the instrument, as is done by
climbing or descending, has so little effect on the indicated altitude.
I can just as easily change the Kollsman setting and change the indicated
altitude without changing the altitude of the instrument at all. Or I can
wait for the ambient pressure to change and watch the indicated altitude
change without moving the instrument. Thus the instrument doesn't
indicate the altitude of itself, it indicates the pressure it is
experiencing.
Do you have a webcam? I'd like to see you typing with your foot in your
mouth.
  #105
Old April 6th 07, 12:44 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Jose" wrote in message
t...
This tack has been taken, and shows our understanding of the issue. Yes,
the indicated altitude will change when the altimeter is moved up to the
top of the tower, despite the static port being at the base.
Eureka!
The physics of the instrument is not at issue. Rather, the calibration
rules are, and
those are made by the FAA.
I've said nothing about calibration rules.
  #106
Old April 6th 07, 12:45 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Jim Logajan" wrote in message
Then it wouldn't fit in the airplane.
  #107
Old April 6th 07, 12:48 PM posted to rec.aviation.piloting
Steven P. McNicoll
I used them correctly. Perhaps your understanding of them is incorrect.
One step at a time. Let's see where you are in your understanding of
altimetry before we move on. Answer the questions.
  #108
Old April 6th 07, 12:53 PM posted to rec.aviation.piloting
Steven P. McNicoll
Yes, great idea.
I thought so.
Turn the knob that adjusts the pressure scale to one extreme. Record the
indication on the face of the altimeter. Now turn the knob to the other
extreme of travel. Record the indication on the face of the instrument.
Now the big question: which value recorded is the altitude at the level of
the instrument?
altimetry before we move on. Answer the questions I posed to Neil Gould.
  #109
Old April 6th 07, 04:11 PM posted to rec.aviation.piloting
Matt Whiting
Yes, great idea.
I thought so.
the instrument?
Yes, one step at a time. Tell me how an instrument that indicates its
own altitude can indicate two vastly different values without changing
its altitude? It is a very simple question.
Matt
  #110
Old April 6th 07, 04:16 PM posted to rec.aviation.piloting
Steven P. McNicoll
news
Yes, one step at a time. Tell me how an instrument that indicates its own
altitude can indicate two vastly different values without changing its
Let's answer the questions in the order they were asked.
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
Cloud Height Indicator Bob Bristow Home Built 0 August 11th 03 07:42 AM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
