Why The Hell... (random rant)
Old April 5th 07, 09:15 PM posted to rec.aviation.student,rec.aviation.piloting
Default Why The Hell... (random rant)
In rec.aviation.piloting Mxsmanic wrote:
writes:
And that tells you your course, not which direction the nose is pointed.
For navigation, your ground track is more important.
There is no GPS instrument available that will tell you which way
your nose is pointed.
As I've said, you just use two.
There is are GPS instruments available that can be linked to tell you
that.
The only two places on Earth a magnetic compass doesn't work in an
airplane are over the north and south magnetic poles.
No. There are thousands of local magnetic anomalies that can make a compass
useless.
Not at airplane altitudes and speeds.
If there are thousands, name just 30.
Piston engines have magnetos which generate the spark plug firing
voltage, and only the spark plug voltage.
Last time I checked, sparks counted as electricity.
Well, I can see electricity can be added to that ever growing list
of things about which you know nothing.
Magnetos generate pulses measured in the thousand of volts and microamps
of current. Even if they were hooked to something else, which they
aren't, the power generated would be useless for powering something like
a GPS.
My god, everytime you say something, more ignorance just roles out.
Jim Pennino
Remove .spam.sux to reply.
  #164
dgs writes:
So, when he attempts to label people as stupid (even if only by
implication), or treat others as if they're idiots, remember, he's
actually proposing that he be treated as if he's stupid too. At least
it's consistent.
No. When I give honest assessments of something or someone, I expect others
to do the same.
Honest does not equal true.
Honest just means that you aren't lying when you spout your ignorant,
incorrect, nonsense; you really believe your own crap.
Jim Pennino
  #165
Maxwell writes:
Odd..you are clearly the poster child for stupidity, but you don't see
hostile.
I'm neither stupid nor hostile.
A smart person wouldn't keep spouting the same ignorant nonsense
after they've been given references to eliminate the ignorance.
Jim Pennino
  #166
Old April 5th 07, 09:56 PM posted to rec.aviation.student,rec.aviation.piloting
Peter Dohm
"RomeoMike" wrote in message
Astro navigation, but it's still an angle away from a standard
vector. So different sciences are using the same word with different
meanings.
However, you're of course correct that for magnetic navigation,
declination and variation are the same thing.
http://www.ngdc.noaa.gov/seg/geomag/faqgeom.shtml
Kev
Thanks to you, farr1220, and Peter. I always wondered in the back of my
mind how the term declination came to mean variation. Now I'm ready to
navigate the outer space :-)
Hmmmm. I see that what I have been calling declination is called
inclination on the NOAA site, so I will correct as appropriate.
In view of my recollections of ground school, I believe that it might be
least confusing to continue using the term deviation for the instrument
error as installed, variation for the difference between true and magnetic
north, and inclination for the angle between the lines of force and the
horizontal--leaving the term declination unused.
Peter
(Planning to think about this at leisure)
  #167
Old April 5th 07, 09:59 PM posted to rec.aviation.student,rec.aviation.piloting
Steven P. McNicoll
"Peter Dohm" wrote in message
You could use declination for the difference between the magnetic variation
a VOR is set to and the actual local magnetic variation.
  #168
Old April 5th 07, 10:33 PM posted to rec.aviation.student,rec.aviation.piloting
On Apr 6, 12:31 am, Ron Natalie wrote:
On Apr 5, 5:37 am, "EridanMan" wrote:
On Apr 4, 5:23 am, "Steven P. McNicoll"
"EridanMan" wrote in message
egroups.com...
Why in gods name are VOR's Mag heading based?
Tradition.
Best answer I've heard yet
Isn't the difference between your compass heading and the radial you
are flying the drift? Knowing drift is pretty useful...
The correction angle maybe. You aren't drifting at all if you are
on the radial.
Yes, that's what I mean, you are holding off "x" degrees of drift.
That fact is very useful and given the choice between a true and
magnetic VOR I think I would prefer magnetic for just that reason.
You?
Cheers MC
  #169
Old April 5th 07, 10:40 PM posted to rec.aviation.student,rec.aviation.piloting
meanings.
Kev
Yes and then aviators would be in perfect alignment with ocean
naavigators who use variation and deviation. The conversion from true
to compass heading makes a nice nemonic:
timid virgins make dull company
for TRUE (variation) MAGNETIC (deviation) COMPASS
Cheers MC
  #170
Old April 5th 07, 10:44 PM posted to rec.aviation.student,rec.aviation.piloting
Steven P. McNicoll
Most are neither. The GRB VORTAC was aligned to a magnetic variation of 1E
in 1965. It's still there, but local magnetic variation is now 3W The
airways are more closely aligned with true north than magnetic north.
RANT! wise purchaser Owning 2 March 27th 07 10:04 PM
Random thoughts 2 Bill Daniels Soaring 6 September 1st 06 05:37 AM
A Jeppesen rant Peter R. Piloting 4 January 17th 05 03:54 AM
Why didn't GWB [insert rant] Jack Military Aviation 1 July 15th 04 11:30 PM
Random Hold Generator... Tina Marie Instrument Flight Rules 0 November 5th 03 04:21 PM
