Another LSA question.
Old April 7th 07, 03:35 PM posted to rec.aviation.piloting
Lou
Default Another LSA question.
A question came up in conversation the other day that got all
different kinds of answers so
I thought I would try it here.
Can a person get their PPL ticket using an LSA aircraft?
Lou
Old April 7th 07, 03:49 PM posted to rec.aviation.piloting
john smith[_2_]
In article om,
Lou
Many pilots have obtained their PPL using aircraft such as Cubs and
Champs. The only requirement is that they be equipped to allow the pilot
candidate to perform the functions stipulated in the test guide.
So long as the aircraft, pilot candidate and pilot examiner do not
exceed the LSA weight limit, why not?
Old April 7th 07, 04:24 PM posted to rec.aviation.piloting
601XL Builder
Lou
Yes
Old April 7th 07, 05:13 PM posted to rec.aviation.piloting
Montblack
("Lou" wrote)
In fact, a person can get their PPL (in an LSA Ercoupe or a non-LSA
Ercoupe), so long as it's an Ercoupe WITHOUT rudder pedals - in 25 hours,
instead of 40 hours. Your ticket will carry a no rudder pedal
restriction/limitation.
http://www.avweb.com/news/avmail/187166-1.html
2nd story down
http://www.aopa.org/asf/publications...m?article=5422
"It's my guess that anyone taking sport pilot training in an Ercoupe is a
lot more likely to get their ticket in the 20-hour minimum." By Rod Machado
Hope I'm not passing along an OWT.
Montblack
Old April 7th 07, 06:37 PM posted to rec.aviation.piloting
Andrew Sarangan
Lou
LSA comes into consideration only for sport pilots. For all other
pilots it is just another aircraft. You can take a checkride, or fly
IFR or do whatever that you normally do with airplanes.
Old April 7th 07, 10:45 PM posted to rec.aviation.piloting
Cubdriver
Sure, that's how I got mine ... well, that's how I got my recreational
pilot certificate.
However! You can't do all your training in the average LSA because
they aren't equipped for night flight. If you can find an LSA with the
required equipment, you'll be fine.
I can even assure you that FAA personnel are willing to go up in an
LSA if required. I needed a Statement of Demonstrated Ability (SODA)
because I am blind in my left eye, and two suits duly came down from
Portland ME to go for a ride in the Piper Cub with me. (Well, one went
on the ride, and the other sat on the ground and grilled my flight
instructor.) And of course the check pilot also went Cubbing with me,
on one of the coldest days on record in New Hampshire. Needless to
say, the check flight also broke a record, for brevity.
Blue skies! -- Dan Ford
Old April 8th 07, 06:55 PM posted to rec.aviation.piloting
Newps
Lou
What if the plane doesn't have equipment used in the
PPL course of study, like VOR?
You don't need a VOR in the plane just like you don't need a GPS or NDB.
Old April 8th 07, 07:08 PM posted to rec.aviation.piloting
Jim Stewart
Lou
Old April 8th 07, 08:13 PM posted to rec.aviation.piloting
Andrew Sarangan
Lou
You don't need a VOR, just demonstrate proficiency using an electronic
navigation system. However, that is besides the point. An LSA could be
equipped well, or it could be bare bones, just like any other
airplane. The LSA's I have seen are equipped far better than the
regular airplanes. Our club LSA has an IFR approach certified GPS,
autopilot, a second nav/comm and the whole works.
Old April 9th 07, 01:34 AM posted to rec.aviation.piloting
ArtP
On 8 Apr 2007 12:13:42 -0700, "Andrew Sarangan"
Which LSA? How do you like it?
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
