On Apr 7, 2:34 am, Marc Ramsey wrote:
You should take a look at this: http://www.dg-flugzeugbau.de/holm-dg300-e.html Marc I tried to read the computer translation out of curiosity, it is dreadful. To encapsulate: Most, if not all DG 300 are restricted to a much lower speed and load envelope due to flaws found in the spar production. The fibers in the spar caps are not strait or aligned due to manufactured flaws in the root area, hence the compression strength is reduced. The gliders will be able to fly with a reduce flight envelope. Not fix is possible due to cost. In a nut shell the value of that glider is substantially reduced. Udo |
The Company ELAN from Slovenia, which produced for Glaser Dirks GmbH
changed the production process without permission of Wilhelm Dirks at an unknown date. This means that nobody knows which gliders are affected. Andreas http://www.dg-flugzeugbau.de/holm-dg300-e.html My German skills are non-existant. Can anyone tell me if the lengthier German part mentions which serial numbers are affected, because the English part says the manufacturing error began sometime during the production run. Presumably that means some of the early DG-300's were built right. Thanks, Bullwinkle |
Ok guys,
I did a bit of research on the issue. Here the key points from DG's posting with some additional information about DG's and Elan's history. For those who wonder, I'm a native German speaker :-) : The issue: - Elan, who has been producing all DG 300/303 since its launch (up it being taken over by AMS-Flight in 1999), apparently changed the production process of the main spar at some unknown point in the past without Glaser-Dirks (the DG predecessor) approval leading to the possibility of faulty main spars (not all main spars produced by them are necessary faulty). - The glider that initially revealed the faulty main spar as a result of a servere landing accident is about 20 years old with aprox. 1500h. - There are about 500 DG-300/303 gliders still flying with an average age of about 15 years and a total of about 1 million hours. - No DG 300/303 has ever had a failed wing in flight as a result of structural failure. - The required breaking strength of the wing at the time of certification was 1.725 times the max allowed in flight-load. The actual certification test to failure was stopped at 2.1 times the max allowed in-flight load without the wing failing. - DG does not now how many gliders are affected, out of 8 tested 3 had a faulty main spar. - To test the wing is difficult and expensive, the wing has to be cut open. Possible solutions: 1. All gliders will be grounded 2. All gliders will have to be inspected within a reasonable time period and repaired if necessary. The inspection would cost around EUR 6000 per glider, a repair, if necessary can easily reach EUR 5000. All gliders would have to come to DG's factory in Germany since it would be near impossible to develop guidelines about what is still acceptable and what has to be repaired. 3. DG tries, using calculations, tests to failure and load tests on faulty main spars, to prove that even faulty main spars have enough strength as a result of the very high structural reserves of the original design. This approach might allow to continue operating the glider with reduced operating limits without the need for inspections and repairs. DG decided to go the 3. route to avoid having to ground all gliders and has spent to date about EUR 10,000 to do the required testing. Based on the suprisingly good results when testing the faulty main spars they got the following operating limitations approved by the EASA (European FAA equivalent): New Operating Limits for all DG-300/303: - Max speed reduced from 270 km/h to 250 km/h - Maneuvering speed reduced from 200 km/h to 175 km/h - MTOW reduced from 525 kg to 450 kg - No aerobatics (also applies to the DG-300 Acro) If you want to avoid these limitations you will have to get the glider inspected and repaired if necessary. The liability/legal issues/responsability: The great majority of the affected gliders were delivered by & paid to Glaser-Dirks which went bankrupt in 1996. The current DG-Flugzeugbau only took over the Type Certificates and spare part supply but not the product liability, the actual gliders and faulty main spars were not manufactured by Glaser-Dirks but by Elan which does not dispute this. Elan refuses to shoulder any costs related to the investigation of the faulty main spars and does not respond to any inquiries. All gliders with faulty main spars produced by Elan are out of warranty. About 10 gliders were produced by Elan or its successor AMS-Flight and delivered by the current DG-Flugzeugbau, all these gliders are out of warranty as well. AMS-Flight was established in 1999 to continue Elan's existing aircraft production and took over the entire Elan Flight Division of Elan as of Sep. 1st, 1999. AMS produced and delivered about 25 gliders under their own responsibility and claims, that they converted the production process back to the original specifications. However, they don't seem to be able to state when and starting with which serial number they did so. It is likely that the only DG-303s that are still under warranty are technically ok but nobody knows for sure and only an inspection will be able to prove that. Here the companies' time lines & current sales: 1973 - Glaser-Dirks Flugzeugbau GmbH founded, prudction of the DG-100 begins 1978 - Elan founded 1983 - DG-300 introduced and produced by Elan 1996 - Glaser-Dirks Flugzeugbau GmbH goes bankrupt - DG Flugzeugbau GmbH buys up key parts of Glaser-Dirks (excluding the product liability of the DG-300 series), Elan continues to produce the DG-300/303. 1999 - AMS-Flight established to continue Elan's existing aircraft production, takes over the entire Elan Flight Division of Elan as of Sep. 1st, 1999. 2006 - AMS-Flight stops DG-303 ELAN manufacturing. As of February 2006 444 DG-300 ELAN & 67 DG-303 ELAN gliders were produced. 2006 - AMS sales EUR 2.4 million (projected), 40 employees 2006 - DG sales EUR 7 million (delivered 50 planes), 75 Employees The potential costs of fixing all affected DG-300/303 gliders Inspection: 500 gliders in service x EUR 6000 per inspection = EUR 3,000,000 Repairs: 188 gliders (3 out of 8) x EUR 5000 per repair = EUR 940,000 Total (without any related costs): EUR 3,940,000 (approx. USD 5,265,000) Looking at that total you can see that this could potentially bankrupt either company (with related loss of employment), hence DG's close look at their legal responibility... I'm not taking any sides on this, look at above facts and judge for yourself. Either way there will only be losers in this messy affair... Markus |
Hi guys,
John Giddy pointed out an important restriction I left out in my summary above (not sure how I missed that, sorry about that): - Maximum mass of non-lifting parts is reduced from 246 kg (542 lb) to 240 kg (529 lb) So the complete set of new restrictions to the operational limits is as follows: - Max speed reduced from 270 km/h (146 kt) to 250 km/h (135 kt) - Maneuvering speed reduced from 200 km/h (108 kt) to 175 km/h (94 kt) - MTOW reduced from 525 kg (1157 lb) to 450 kg (992 lb) - Maximum mass of non-lifting parts reduced from 246 kg (542 lb) to 240 kg (529 lb) - No aerobatics (also applies to the DG-300 Acro) DG's definition of non-lifting parts is as follows: - Fuselage (with permanently installed equipment, canopy, and main pins) - Cockpit load (Pilot + parachute + equipment for instance tail fin battery in baggage compartment instead of in tail fin) - Horizontal tail This means that your max. cockpit load is reduced by 6 kg (13 lb) all other things being equal. I just saw that DG apparently just posted the complete English translation of their German posting: http://www.dg-flugzeugbau.de/holm-dg300-e.html I hope this helps, Markus |
DG... has spent to date about EUR 10,000 to do the required testing.
Are we supposed to be impressed that DG spends this on the fleet? That is less than it would cost to ship, inspect and repair a single US-based glider! |
On Apr 9, 9:22 am, "Mike Yankee" wrote:
DG... has spent to date about EUR 10,000 to do the required testing. Are we supposed to be impressed that DG spends this on the fleet? That is less than it would cost to ship, inspect and repair a single US-based glider! A quick clarification to my original cost translation after carefully re-reading the original German post: The inspection is estimated at EUR 6000 per glider. If a repair is deemed necessary it can easily reach EUR 5000 PER MAIN SPAR. Since a glider has 2 wings with 2 spars we'd end up with a worst case scenario of EUR 16000 per glider and a potential total of some 376 main spars affected in a fleet of some 500 gliders (initial test showed 3 out of 8 main spars defective). So the potential total costs for the entire fleet would be: - Inspection: 500 gliders in service x EUR 6000 per inspection = EUR 3,000,000 - Repairs: 376 main spars (3 out of 8) x EUR 5000 per repair = EUR 1,880,000 - Total (without any related costs) = EUR 4,940,000 (approx. USD 6,521,000) Also note that DG's owner apparently just added some comments below the original posting related to the considerable discussion going on especially in German forums. The extended DG posting: http://www.dg-flugzeugbau.de/holm-dg300-e.html For those of you who know some German here a link to the discussion on one of the main forums: http://www.segelflug.de/cgi-bin/wwwt...oard=Flugzeuge The pictures DG's owner (Friedel Weber) refers to in his comments can be found he http://www.segelflug.de/cgi-bin/wwwt...5&o=#Post65186 Markus |
Markus Graeber wrote:
On Apr 9, 9:22 am, "Mike Yankee" wrote: DG... has spent to date about EUR 10,000 to do the required testing. Are we supposed to be impressed that DG spends this on the fleet? That is less than it would cost to ship, inspect and repair a single US-based glider! A quick clarification to my original cost translation after carefully re-reading the original German post: The inspection is estimated at EUR 6000 per glider. If a repair is deemed necessary it can easily reach EUR 5000 PER MAIN SPAR. Since a glider has 2 wings with 2 spars we'd end up with a worst case scenario of EUR 16000 per glider and a potential total of some 376 main spars affected in a fleet of some 500 gliders (initial test showed 3 out of 8 main spars defective). 3 of 8 in a sample that size (8) is playing pretty fairly free and loose with statistics. Did DG sample gliders they thought would be affected or did they sample across the entire manufacturing run? The numbers could be much different. Also, since they say they've tested 8 gliders, it costs EUR 6000/glider to test, and they've spent EUR 10,000, I'm assuming they've only tested wrecked gliders. That, or they hired an accountant from Enron. ;-) Shawn |
On Apr 9, 11:52 am, Shawn wrote:
3 of 8 in a sample that size (8) is playing pretty fairly free and loose with statistics. Did DG sample gliders they thought would be affected or did they sample across the entire manufacturing run? The numbers could be much different. Also, since they say they've tested 8 gliders, it costs EUR 6000/glider to test, and they've spent EUR 10,000, I'm assuming they've only tested wrecked gliders. That, or they hired an accountant from Enron. ;-) Shawn 8 samples implies that they tested 4 gliders including the one that showed the original defect after a severe landing accident. From what I understand that original glider was repaired and is airworthy again (and for sale by the club in Germany that owns it), it probably is the only one right now with a guarantee that it has no main spar defects and as such can be operated within the old operating limits... I would guess they tested whatever they had at hand and of course the sample might not be representative but all you can go by right now to get an idea of the extend of the problem; especially since Elan is not able/willing to provide any more information as to when they did the change to the wing manufacturing process which can possibly lead to the main spar defects discovered. I assume the EUR 10,000 mentioned is the cost of the load test & tests to destruction they did on affected wings to establish the new operating limitations. Markus |
Instead of being absolutely straight, the rovings of one spar cap
showed a slightly wave-like pattern. Alarmed by this discovery we investigated the spar caps of several other DG-300 wings, which were in for repair in our factory or other approved maintenance shops. We found a similar, but less severe pattern at some of these wings too. The most important question right to the beginning: "Why may DG-300 spars exhibit this wave-like pattern, and is this flaw also possible at spars of other DG airplanes?" The answer: This specific flaw is limited to the DG-300/303 series! For all DG wings, except for the DG-300 and DG-600, the spar caps are manufactured in separate a mould, which allows maximum precision for the roving placement. While the rovings for the DG-600 are placed directly into the wing mould, they are inserted into a prefabricated channel which becomes an integral part of the wing structure. This allows the same precision for the roving placement. Only the DG-300/303 uses a different manufacturing method (which is also used by other manufacturers), therefore only the DG-300/303 is prone to the described manufacturing flaw. Notice the statement (which is also used by other manufacturers) |
Beech Duke Owners/ex-Owners ple help... | Stanley | Owning | 12 | June 10th 16 12:36 AM |
SHK Owners | [email protected] | Soaring | 1 | February 7th 06 06:37 PM |
R22 owners please help with AD 2004-06-52 | rotortrash | Rotorcraft | 20 | April 28th 04 04:33 PM |
ASW20 owners | Andrew Henderson | Soaring | 0 | April 10th 04 12:28 PM |
Any UH-1 owners in here? | Jim | Rotorcraft | 7 | October 6th 03 02:33 AM |
