DG-300/303 owners...
Old April 10th 07, 04:10 AM posted to rec.aviation.soaring
ContestID67
Default DG-300/303 owners...
After reading all this I am still unsure what is wrong. Can someone
paint (or draw) me a mental picture on what was manufacturered
incorrectly? Also, what is a roving?
Finally, I assume that only DG-300/303's that say ELAN on them are
affected.
- John
Old April 10th 07, 04:43 AM posted to rec.aviation.soaring
Mike[_8_]
Short answer
The spar caps on a sailpane are often made of rovings. Rovings are
long strands of, in this case, uni fiberglass (lots of it) postitioned
at the thickest part of the chord, that extend from the spar roots to
an area usually just short of the tip of a wing. For optimum strength
they must be straight. If there are sections of the material that are
not straight, a percentage of the spar strength is lost. On some
DG300's some of the rovings were not laid in correctly, are not
straight,so there have been reductions on the operating limitations of
the sailplanes for safety reasons.
Mike
affected.
- John
Old April 10th 07, 06:17 AM posted to rec.aviation.soaring
Jack
Also, see the pictures at the URL previously posted by Markus
Graeber [shorter form below]:
http://tinyurl.com/yoj2hl
Jack
http://groups.yahoo.com/group/dg-300
Old April 10th 07, 06:56 AM posted to rec.aviation.soaring
affected.
- John
This is copied from a LAK 17 site. I think it is dated approx.
1996 Note that when you have ripples in the roving it degrades the
compression as a bend can't take compressive forces as well as
something absolutely straight.
THE SAGA OF A CARBON SPAR DESIGN BY JIM MARSKE (1996)
When I went about designing the wing spar for the Genesis 2, I tried
to find design strength values for the carbon rovings to be used in
the spar caps, the manufacturer's data sheet claimed 310,000 psi
tensile strength but gave no compression data. A call to the
manufacturer produced a claim of 100,000 psi in compression. Talking
with others who have constructed carbon wing spars, I was advised to
be careful as such values cannot be obtainable and to back off to
90,000 psi in tension and 60,000 in compression. To satisfy myself, I
had several test strips made up of hand laid-up carbon rovings and
sent them to an independent test laboratory for strength evaluation.
The results of the five test samples were disturbing. In tension the
values ranged from 152,000 to 190,000 psi. In compression the values
ranged from 48,000 to 74,000 psi. The reason why there was so much
scatter and the values lower than expected is that it is almost
impossible to lay the rovings down without zigzag waves every few
inches. You can only pull the tow till its shortest filament pulls
tight and the rest lay in small waves. As a result of this condition,
and to acquire the necessary strength, the G1 prototype spar is fairly
heavy and very stiff. To prove the spars strength, we static loaded it
to +5g's and -3g's. Wing deflection, measured at the tip, was 25
inches at+5g's.
We needed carbon that was stronger and more consistent in strength
values, Therefore, we looked into pulltruded carbon rods, Samples were
ordered and examined, but waves were found in those filaments also, At
about this same time, I found a brief article in Sport Aviation
concerning a carbon rod expounding very straight filament alignment. A
sample rod was obtained and after examination of the filaments, we saw
that they were indeed very straight. Furthermore, the manufacturer
claimed a tensile strength of 315,000 psi and a compressive value of
200,000 psi, which was impressive. When bending the 1 /8 inch diameter
rod to first sign of fracture, it was the tensile filaments that were
failing one at a time. In addition to the high strength properties of
these rods, the automated manufacture of the rod controlled the resin
content, which is not possible in a hand laid-up situation, and
dimensions of the rod assured consistent strength properties.
The next step was to prove that the rod would function as a spar cap,
and that it would carry the required loads without delamination. A
Genesis spar segment of the aircraft center section was made and
tested in the Sportine Aviacija laboratory. No failure occurred during
a load sequence to a load limit of +8.3g's. This load represents an
aircraft design load of 1200 pounds, times a safety factor of 1 .5 as
required by JAR-22. Impressed with these results, the load was
increased past the required load limit of +8.3g's to +1 g's without
incident. Going to +10.5g's we reached the maximum output load of the
test machine, and again no degradation of the rods was observed. This
load was nearly twice the required spars design load of +5.55g's.
Satisfied with the static results, we did not however have a history
of dynamic cyclic endurance testing for this particular rod. Since the
majority of the rods do not span full length of the spar we had
concerns as to what would happen at the end of each rod end in the mid
section of the spar where a stress riser may occur. So we embarked
upon a cyclic endurance test at an elevated load to force an early
failure.
The first run was a 4g positive loading. We hoped for 5,000 cycles but
stopped at 10,000 cycles. We then increased the load to 6g's expecting
a failure in a few hundred cycles; we stopped the test at 5,500
cycles. The test spar was then inverted in the fixture to apply
negative loading. The test lab director insisted that we start at -3g.
We started at -4g's and ran for 5,000 cycles. No degradation was
noted. To finish the test we repeated the static loading test again.
One cycle to +8.33g's and two cycles to -5.33g's. Again no degradation
was visible.
So we asked Klemas, Sportine Aviacija's chief engineer as to just how
many flight hours all this cyclic testing is equivalent to, Klemas
gave me a report on recorded accelerations made on one of their
LAK-12's during 50 hours of flying, which included towing, takeoffs,
landings and ground handling. The accelerations were all counted and
grouped together to form a 50 hour flight period. The cycles were then
multiplied by 200 to find the life of 10,000 flight hours for the
LAK-12.
THE SAGA OF A CARBON SPAR DESIGN continue
This data was then transferred into chart form. I overlaid the Genesis
data on the same chart to obtain a comparison. A diagram of the
results appears below.
pictu Genesis spar test results compared to the LAK-12 spar test
results.
After completing a quick calculation, which still requires further
evaluation, I feel that we have acquired an excess of 5,000 flight
hours (probably 6,000 hours) in positive loading and an excess of
10,000 flight hours in negative loading. I understand that a survey of
various glider clubs around the world responded to an inquiry as to
the maximum flight hours that had been accumulated on any of their
gliders. Only a few gliders had accumulated near 5000 flight hours.
However one Australian club reported nearly 6,000 flight hours.
G2 WING SPAR DEVELOPMENT
As mentioned previously, the Sportine Aviacija facility has an
extensive engineering test lab and experienced engineering staff.
These capabilities in combination with our own engineering efforts
have produced some amazing results in the area of the wing spar
development for the G2.
For example, the main spar on the G1 prototype was constructed in the
usual manner using hand laid-up carbon fiber roving. However
laboratory tests have shown that there is plenty of room for
improvement in this process. So we decided to look into using
prestressed carbon fiber rods as a replacement to the carbon roving
used in the wing spars. These rods alone are five times stronger than
conventional hand laid-up carbon roving.
Using the Sportine Aviacija test lab, we prepared a sample for cyclic
fatigue testing and took it through 10,000 cycles at +4 g's, 5,000
cycles at +6 g's and 5000 cycles at -4 g's. Then as required for
Jar-22 certification, we loaded this same spar sample twice for 10
seconds (once for 3 seconds is all that's required) at +8,3 and -5,3
g's and experienced absolutely no degradation or failure whatsoever,
We then took it to 10 g's and also experience no degradation or
failure. Certification test results like this are practically unheard
of in sailplane development, but that's not to say they shouldn't be.
Old April 10th 07, 06:58 AM posted to rec.aviation.soaring
Marc Ramsey
A short article with some additional information has been posted at the
AMS-Flight web site:
http://www.ams-flight.si/
Marc
Old April 10th 07, 07:03 AM posted to rec.aviation.soaring
www.marskeaircraft.com/carbonrod.html
Another article on rovings vs Graphlite rods. The Genesis 2, LAK 17,
LAK 19 and probably also the LAK 20 use the Graphlite rod design for
their wing spars. I hope Jim Marske doesn't mind that I posted these
but they are out on the net anyway.
Old April 10th 07, 09:19 PM posted to rec.aviation.soaring
Markus Graeber
DG just posted the preliminary TA which is awaiting approval by the
EASA (European FAA):
http://www.dg-flugzeugbau.de/Data/tn-359-24.pdf
DG also added some more FAQs at the bottom of the web page dealing
with the main spar issue:
http://www.dg-flugzeugbau.de/holm-dg300-e.html
Markus
  #28
Old April 11th 07, 01:43 AM posted to rec.aviation.soaring
Bob Kuykendall
I wrote this short article on what I think the problem is, based on
the DG advisory and the photos at segelflug.de:
http://www.hpaircraft.com/misc/dg300spars.htm
It is only my guess at what the issues are, please view it with some
skepticism. Please alert me to any factual errors.
Thanks, and best regards
Bob K.
  #29
Old April 15th 07, 09:52 PM posted to rec.aviation.soaring
Ian[_1_]
On Fri, 06 Apr 2007 23:34:52 -0700, Marc Ramsey wrote:
You should take a look at this:
Marc
Just finished reading this and the related thread. This is a nightmare for
the affected owners and many others in the industry!
However as a suggestion:
Would it be possible to determine if any one aircraft has the defect by
measuring wing deflection under a known load?
From my understanding of the defect, the misaligned fibres would not only
reduce the strength of the spar, but also it's stiffness. By measuring the
deflection of a sample of wings under load and then opening them up to
determine whether they have the defect or not, it might be possible to
draw up a non invasive procedure which can be used to determine if the
defect exists in a particular aircraft, and if it does, to what extent.
Anybody from DG reading this?
Ian
  #30
Old April 16th 07, 02:14 AM posted to rec.aviation.soaring
Jack
Marc
I don't know about your deflection suggestion, but how DG handles
this spar-cap situation for all of the DG-300 owners should have a
significant bearing on whether, and how much, the market will
discount all of their products in the future.
A few dollars spent now to shore up what had been a good reputation
can pay big dividends. We shall soon see if DG is to remain a
desirable marque.
Jack
Beech Duke Owners/ex-Owners ple help... Stanley Owning 12 June 10th 16 12:36 AM
SHK Owners [email protected] Soaring 1 February 7th 06 06:37 PM
R22 owners please help with AD 2004-06-52 rotortrash Rotorcraft 20 April 28th 04 04:33 PM
ASW20 owners Andrew Henderson Soaring 0 April 10th 04 12:28 PM
Any UH-1 owners in here? Jim Rotorcraft 7 October 6th 03 02:33 AM
