I have a nice set of DC 10-13-S that I'd like to convert to ANR. Headsets Inc advertises in AOPA Pilot magazine and has a reasonable web site for products and services. They also have some customer testimonials of varying degrees of flattery on their site.
I'd sure be interested in hearing other experiences good or bad, or maybe even other recommendations for upgrading my current headset. (I'm not going to buy a Bose or a Lightspeed, so let's not even go there...) -- Jim Carter Rogers, Arkansas |
A relative of mine has a DC headset that was converted several years ago
with their kit (not the new box that has auto-shutoff). It makes a very big difference. When looking for a second ANR headset, I was either going to do that or go with one of the costly Bose/etc. I ended up going for Bose for the comfort and because it has a higher pitch speaker (more treble?) that makes it easier to hear. If you're comfortable with yours though I would definitely go with their conversion as I think the noise canceling is very comparable to my Bose (except when the Bose's battery dies, the DC would be much better with passive noise reduction). Jim Carter wrote: I have a nice set of DC 10-13-S that I'd like to convert to ANR. Headsets Inc advertises in AOPA Pilot magazine and has a reasonable web site for products and services. They also have some customer testimonials of varying degrees of flattery on their site. I'd sure be interested in hearing other experiences good or bad, or maybe even other recommendations for upgrading my current headset. (I'm not going to buy a Bose or a Lightspeed, so let's not even go there...) -- Jim Carter Rogers, Arkansas |
The Headsets Inc kit is complete, instructions are clear, and they
work well. Be ready to do some pretty fine work though. |
"Jim Carter" wrote in
: I'd sure be interested in hearing other experiences good or bad, or maybe even other recommendations for upgrading my current headset. (I'm not going to buy a Bose or a Lightspeed, so let's not even go there...) I have a set of DC H10-80 that I had converted by Headsets Inc. I bought the H10-80 because, at the time, it had the best noise supression of all DC models. Adding ANR has made the headphones even better. -- |
I absolutely recommend the Headst's, Inc. kits. My friend and I have
converted several DC's, with absolute satisfaction. Happy Flying! Scott Skylane |
In a previous article, "Jim Carter" said:
I'd sure be interested in hearing other experiences good or bad, or maybe even other recommendations for upgrading my current headset. (I'm not going to buy a Bose or a Lightspeed, so let's not even go there...) At Oshkosh a few years back I was going back between the various vendor booths testing out ANR headsets - I was planning to try to stay in the $500-$600 range. But frankly, I couldn't tell the difference between any of them, and couldn't make up my mind. But one of the guys I travelled with said I should just get the Headsets Inc conversion kit for my DC10-13.4s. I don't know which end of a soldering iron is the hot end, so I got them to install them at the booth, and it was great. When I forget to turn them on, the first hint is that I have trouble hearing the radio. But since I moved up to flying a Piper Lance, I never forget to turn them on - that 300hp engine is *loud*. The auto-shutoff has saved my battery more than once. A few times I've had to flick the on switch on and off a few times to get it to turn on, but generally they've been trouble free and very useful. The biggest change I noticed is that with ANR, I'm not so sleepy after a flight. This year I switched to an ultralight headset and passed my DCs onto my wife, and she loves the ANR too. -- Paul Tomblin http://blog.xcski.com/ "Harry very carefully read the manual - four times - because Snape would cut off his breathing privs if he asked him a question that the manual could answer..." -- Harry Potter and the Book Of The BOFH |
On Apr 12, 3:24 am, Scott Skylane wrote:
I absolutely recommend the Headst's, Inc. kits. My friend and I have converted several DC's, with absolute satisfaction. Happy Flying! Scott Skylane I agree! I converted 2 DC H10-13.4 headsets over a year ago. An easy 45 min job if you have moderate hands-on skills (disassembly, soldering, etc.). The only problem I had during re-construction is insufficient room inside the ear cups for the module after installing the foam. Just couldn't get it shoved in all the way and have the speaker lay flat. I had to use a touch of SuperGlue around the speaker flange to make it sit tight on the cup. Other than that, absolutely no problems and I'm very happy with the performance. There's quite a difference when you throw the switch! --Jeff |
On Apr 11, 9:27 pm, "Jim Carter" wrote:
I have a nice set of DC 10-13-S that I'd like to convert to ANR. Headsets Inc advertises in AOPA Pilot magazine and has a reasonable web site for products and services. They also have some customer testimonials of varying degrees of flattery on their site. I'd sure be interested in hearing other experiences good or bad, or maybe even other recommendations for upgrading my current headset. (I'm not going to buy a Bose or a Lightspeed, so let's not even go there...) -- Jim Carter Rogers, Arkansas Just add me as another very happy Headsets Inc customer on my DC headsets. Cary |
Jim, I've done 3 conversions on 3 headsets so far, and have been
completely satisfied. Dave Jim Carter wrote: I have a nice set of DC 10-13-S that I'd like to convert to ANR. Headsets Inc advertises in AOPA Pilot magazine and has a reasonable web site for products and services. They also have some customer testimonials of varying degrees of flattery on their site. I'd sure be interested in hearing other experiences good or bad, or maybe even other recommendations for upgrading my current headset. (I'm not going to buy a Bose or a Lightspeed, so let's not even go there...) -- Jim Carter Rogers, Arkansas |
Jim,
I have a nice set of DC 10-13-S that I'd like to convert to ANR. Go for it. If you're just a little capable with a soldering iron, it's an easy do-it-yourself. Absolutely decent ANR for the money. Well worth it, even though it doesn't come close to the dedicated high-end ANR sets. -- Thomas Borchert (EDDH) |
| Thread Tools | |
| Display Modes | |
| Headsets ? | jad | Rotorcraft | 24 | March 23rd 06 11:31 PM |
| Is there any new scoop on the LS-10? | John Bojack | Soaring | 16 | September 28th 05 10:52 AM |
| Headsets | [email protected] | Owning | 19 | August 18th 05 02:31 AM |
| Air scoop for Russia | Serge Serfaty | Soaring | 2 | July 14th 05 05:20 PM |
| Reverse scoop | Paul Lee | Home Built | 9 | April 13th 04 02:58 AM |
