Richard,
As a superior alternative to Weldbond, you could also use an industrial contact cement called Pliobond 20 (there are other versions available, but this one would suit your application). It was designed by Goodyear 40+ years ago, and remains the premium industrial contact cement. It is a little hard to find, but worth it. I agree with the pencil line alignment marking before gluing, as well as the Tesa tape on the leading edge. Both sensible suggestions. (other post in thread) Changing subject slightly.... is there a commonly available solvent for the Gorilla glue? I've used it on other projects, and I'm really impressed with its strength. I just don't know about how to remove it once cured.' As to a solvent for the mighty Gorilla Glue, try using a liquid paint stripper made for polyurethane paint, or straight methylene chloride (gloves and goggles!). What I have found works best though, is to mask off any areas you do not want it on or in, and remove it while half cured and leathery using an X-acto or equivalent. It is a fantastic adhesive when properly used. Paul Hanson 'Do the usual, unusually well'--Len Niemi At 19:04 11 April 2007, Jeplane wrote: I need to glue a Schleicher tail skid on my ASW19. 1- What type of glue would you use? 2- Can the tail skid tape be the same as the wings tape? Thanks for the comments Richard ASW19 Phoenix, AZ Sisu 1a |
Richard,
Plexiglass Glue | Jim Vincent | Soaring | 6 | March 23rd 07 08:25 PM |
Glue it to it | [email protected] | Home Built | 22 | December 15th 06 10:38 AM |
Removable glue | Lou | Home Built | 2 | April 14th 05 06:57 AM |
Glue | Adair | Home Built | 3 | July 18th 03 10:15 PM |
Glue | David | Home Built | 1 | July 16th 03 05:51 PM |
