#51
Thanks. I've visited that site before; the author becomes very abstract at
times, but it is useful information. Personally, as an engineer and generally 'theoretical' guy, I enjoy the abstraction... but I understand what you're saying. By pitch climbing do you mean with the yoke, or with trim adjustments? Yoke. Changing pitch attitude almost always induces phugoid oscillations, with the yoke, those oscillations are trivial (almost subconscious) to damp. Trim provides no such mechanism (without grabbing the yoke anyways), so its generally a bad idea to fly with it. For any pitch attitude change, the general rule of thumb is pitch, power, trim off pressure as necessary, in that order. If I have nose-down trim applied to go fast at my low altitude, it seems I should be able to trim slightly upwards and change altitude easily, then trim back for level flight at the new altitude. If I already have nose-up trim applied, this may not work, and eventually I'll have to add power. It sounds like you're trying to fight the simulated phugoid oscillation by using trim to make very low amplitude adjustments... This just increases the period of the oscillations, it in no way prevents them from occurring. Power is a good, 'side effect free' mechanism of doing fine trimming of your aircraft's altitude. In fact, I know instructors who advocate only ever using the power to make the final 'lock' onto a new cruise altitude, no matter what. For example, the mechanism you would use to level off from a cruise climb would be as follows: 500 feet below target altitude, push the nose forward gently to bring airspeed up to cruise airspeed. Once you've reached cruise airspeed, go ahead and trim to hold the attitude, but allow your power surplus to continue pulling you up the last hundred feet or so to your target altitude, only backing off the power the moment you reach it. The descend-to-altitude is the same procedure, only with reduced power instead (set up the aircraft in cruise attitude before you hit your target altitude at a reduced descent power setting, and allow the aircraft to settle onto target altitude before increasing power back to cruise power) I can see the theoretical advantages to this approach, but I would be lying if I said I used to religiously (I still don't keep that far ahead of the aircraft). |
#52
On Apr 7, 8:11 am, Mxsmanic wrote:
Suppose you're in your small aircraft and you want to climb from 4000 to 6000, As with all things aviation, it depends. Under IFR, they like you to climb quickly, at least 500 fpm. That often requires mixture rich, maybe rpm increase, plus more manifold pressure via throttle (unless you're already maxed out above 5000 ft). On the other hand, if you've been yakking with a passenger and suddenly realize you're 200 ft low, just pull the yoke. For serious climbing, use power and rich mixture, then reduce MP, prop, and mixture as needed at desired altitude. |
#53
![]() "EridanMan" wrote in message ups.com... snip Yoke. Changing pitch attitude almost always induces phugoid oscillations, with the yoke, those oscillations are trivial (almost subconscious) to damp. Trim provides no such mechanism (without grabbing the yoke anyways), so its generally a bad idea to fly with it. You bring up a good point on phugoids. I have flown everything from J-3 cubs to F-4E (but no heavy time) and the difference in phugoid tendancy is HUGE. On the Air Force jets, the trim in on the stick, so I didn't fly just trim. I am currently flying a Taylorcraft which must have a highly damped phugoid. I find I can fly it with only trim to make gradual changes in altitude. In other planes, this can't be done as you mention. Danny Deger For any pitch attitude change, the general rule of thumb is pitch, power, trim off pressure as necessary, in that order. If I have nose-down trim applied to go fast at my low altitude, it seems I should be able to trim slightly upwards and change altitude easily, then trim back for level flight at the new altitude. If I already have nose-up trim applied, this may not work, and eventually I'll have to add power. It sounds like you're trying to fight the simulated phugoid oscillation by using trim to make very low amplitude adjustments... This just increases the period of the oscillations, it in no way prevents them from occurring. Power is a good, 'side effect free' mechanism of doing fine trimming of your aircraft's altitude. In fact, I know instructors who advocate only ever using the power to make the final 'lock' onto a new cruise altitude, no matter what. For example, the mechanism you would use to level off from a cruise climb would be as follows: 500 feet below target altitude, push the nose forward gently to bring airspeed up to cruise airspeed. Once you've reached cruise airspeed, go ahead and trim to hold the attitude, but allow your power surplus to continue pulling you up the last hundred feet or so to your target altitude, only backing off the power the moment you reach it. The descend-to-altitude is the same procedure, only with reduced power instead (set up the aircraft in cruise attitude before you hit your target altitude at a reduced descent power setting, and allow the aircraft to settle onto target altitude before increasing power back to cruise power) I can see the theoretical advantages to this approach, but I would be lying if I said I used to religiously (I still don't keep that far ahead of the aircraft). |
#54
EridanMan writes:
It sounds like you're trying to fight the simulated phugoid oscillation by using trim to make very low amplitude adjustments... I try it sometimes, on the theory that the more precise changes possible with tiny bits of trim might prevent me from overcorrecting, whereas gross movement of the yoke seems more likely to take me past the correct adjustment. This just increases the period of the oscillations, it in no way prevents them from occurring. If the period becomes long enough, the oscillation is gone for all effective purposes. Sometimes I cheat and turn on the autopilot to trim out the oscillations. I also sometimes use the autopilot to trim and then adjust power until the AP is giving me neutral trim (which gives me more trim authority and hopefully reduces drag, although it also means that I can't necessarily fly at high speeds). Power is a good, 'side effect free' mechanism of doing fine trimming of your aircraft's altitude. In fact, I know instructors who advocate only ever using the power to make the final 'lock' onto a new cruise altitude, no matter what. See above. I've also tried setting neutral trim (in steps or in one adjustment) and then using power to find a setting that will keep me at the desired altitude with that trim. It seems to be more difficult but the aircraft is very stable once in that configuration. 500 feet below target altitude, push the nose forward gently to bring airspeed up to cruise airspeed. Once you've reached cruise airspeed, go ahead and trim to hold the attitude, but allow your power surplus to continue pulling you up the last hundred feet or so to your target altitude, only backing off the power the moment you reach it. That sounds like a plan. I don't know if I've tried it (I may have done so unconsciously, but I'll have to try it explicitly). I can see the theoretical advantages to this approach, but I would be lying if I said I used to religiously (I still don't keep that far ahead of the aircraft). I suppose it depends to some extent on how much time you have on your hands. If you're going to be in cruise for a long while, it's more practical than if you know you're going to have to change altitude regularly (as over terrain of widely varying elevations at lower altitudes). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#55
Paul kgyy writes:
For serious climbing, use power and rich mixture, then reduce MP, prop, and mixture as needed at desired altitude. _Always_ rich for a climb? At altitudes above a few thousand feet MSL, it seems that a rich mixture just slows me down. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#56
![]() "Mxsmanic" wrote in message ... Paul kgyy writes: For serious climbing, use power and rich mixture, then reduce MP, prop, and mixture as needed at desired altitude. _Always_ rich for a climb? At altitudes above a few thousand feet MSL, it seems that a rich mixture just slows me down. When was the last time you cleaned the plugs in your DESK? |
#57
In rec.aviation.piloting Mxsmanic wrote:
EridanMan writes: It sounds like you're trying to fight the simulated phugoid oscillation by using trim to make very low amplitude adjustments... I try it sometimes, on the theory that the more precise changes possible with tiny bits of trim might prevent me from overcorrecting, whereas gross movement of the yoke seems more likely to take me past the correct adjustment. Pilots in real airplanes learn to fly using the yoke to control the airplane and the trim to remove yoke pressure. Since simulators that simulate yoke pressure cost as much as real airplanes, you will never be able to do it. This just increases the period of the oscillations, it in no way prevents them from occurring. If the period becomes long enough, the oscillation is gone for all effective purposes. Sometimes I cheat and turn on the autopilot to trim out the oscillations. I also sometimes use the autopilot to trim and then adjust power until the AP is giving me neutral trim (which gives me more trim authority and hopefully reduces drag, although it also means that I can't necessarily fly at high speeds). Power is a good, 'side effect free' mechanism of doing fine trimming of your aircraft's altitude. In fact, I know instructors who advocate only ever using the power to make the final 'lock' onto a new cruise altitude, no matter what. See above. I've also tried setting neutral trim (in steps or in one adjustment) and then using power to find a setting that will keep me at the desired altitude with that trim. It seems to be more difficult but the aircraft is very stable once in that configuration. In real aircraft you set the power to an appropriate value, adjust the attitude for level flight, and trim off the pressure. 500 feet below target altitude, push the nose forward gently to bring airspeed up to cruise airspeed. Once you've reached cruise airspeed, go ahead and trim to hold the attitude, but allow your power surplus to continue pulling you up the last hundred feet or so to your target altitude, only backing off the power the moment you reach it. That sounds like a plan. I don't know if I've tried it (I may have done so unconsciously, but I'll have to try it explicitly). I can see the theoretical advantages to this approach, but I would be lying if I said I used to religiously (I still don't keep that far ahead of the aircraft). I suppose it depends to some extent on how much time you have on your hands. If you're going to be in cruise for a long while, it's more practical than if you know you're going to have to change altitude regularly (as over terrain of widely varying elevations at lower altitudes). In a real airplane that burns real gas that costs real money, you climb to a cruise altitude that allows for all the terrain and stay there. -- Jim Pennino Remove .spam.sux to reply. |
#58
Paul kgyy writes: For serious climbing, use power and rich mixture, then reduce MP, prop, and mixture as needed at desired altitude. _Always_ rich for a climb? At altitudes above a few thousand feet MSL, it seems that a rich mixture just slows me down. In a real airplane with a real engine that generates real heat and costs real money to overhaul there are conciderations beyond how fast you go. -- Jim Pennino Remove .spam.sux to reply. |
#59
to a cruise altitude that allows for all the terrain and stay there. Hell, I dunno, I think in a real plane that burns real gas, his inadvertent decision to toddle along at Vy would actually give him pretty good gas milage ![]() But yeah, I missed that bit. |
#60
Methods of launch | Jim Culp | Soaring | 0 | November 20th 06 07:39 AM |
Methods of Launch | Nigel Baker | Soaring | 3 | November 17th 06 04:35 PM |
methods of lauch | Robert Gaines | Soaring | 0 | November 16th 06 01:17 AM |
Vector altitude for ILS below GS intercept altitude? | M | Instrument Flight Rules | 23 | May 20th 06 07:41 PM |
Pressure Altitude or Density Altitude | john smith | Piloting | 3 | July 22nd 04 10:48 AM |
