Question to Mxmanic
Old April 13th 07, 06:24 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Question to Mxmanic
Viperdoc writes:
And, how did it feel when MSFS simulated pulling or pushing G's? Did your
head get heavy? Did you grey or red out? Or perhaps you've ridden in a
centrifuge to nine G and experienced this as well.
MSFS simulates the gray out and red out. Obviously, there is no motion.
Mxsmanic
Little Endian writes:
Does MSFS simulate wake turbulence? From the little that I have seen
it does not seem to. Are there other regular PC based simulators that
do?
FS 2004 does not, nor does the built-in AI ATC delay for wake turbulence. I
don't know about FSX or other sim software.
Old April 13th 07, 06:41 PM posted to rec.aviation.piloting,rec.aviation.student
Little Endian
Ok. So its much less realistic than I thought because wake turbulence
avoidance is a very important concern for real pilots.
Old April 13th 07, 08:04 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
True, but it's not something that requires practice. In real life, you simply
take care to avoid wake turbulence; in the sim, you can take the same
precautions if you wish, but you don't have to.
Old April 13th 07, 08:35 PM posted to rec.aviation.piloting,rec.aviation.student
Snowbird
"Mxsmanic" wrote ...
simply
Well, in real aviation the most valuable use of simulators is for practising
upsets and other abnormal situations that are not safe or feasible to do in
the real aircraft. So it would be an extremely useful feature to have in
MSFS.
In addition, if the feature were in MSFS, it would aid realism to basic
flight training as well i.e. flying a correct 360-degree turn.
Old April 13th 07, 08:41 PM posted to rec.aviation.piloting,rec.aviation.student
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Am I the only one seeing the irony in this/
Someone who claims that a sim is close to real life, and wants
to do everything that is done in the real world, but thinks that it is
*OPTIONAL* to handle a problem that has killed people over the years?
You don't get to cherrypick operations like this. If you're in
a PC-12 and you come in 1 mile in trail of a B767, you don't get to
pick and say "I'm not going to take precautions for wake turbulence" in
the real world; you either do it, or you risk your life. If you want to
do this in the real world (which in your case, you don't (thank the
gods) ), you had best do what you can to avoid it, whether it's there
or not.
You contradict yourself with every statement you make, Anthony.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFGH9zXyBkZmuMZ8L8RAvg9AJ9h54Cj17DNwXRrTF4UtE QjcZdeiQCgzW1q
fbo0LG/lsrJotCZuKQFr5oY=
=foHT
-----END PGP SIGNATURE-----
Old April 13th 07, 09:09 PM posted to rec.aviation.piloting,rec.aviation.student
Jay Honeck
How does MS flight simulator simulate the symptoms of hypoxia?- Hide quoted text -
Half a bottle of Jack Daniel's
It's funny you should say that. I have flown our MSFS-based "Kiwi"
flight simulator
(see it he http://www.alexisparkinn.com/flight_simulator.htm ) at
the end of a very long day, after consuming three 16-ounce Sprecher
Ambers (within the span of a 114-minute movie), and can vouch for the
fact that alcohol is a pretty good mild hypoxia simulator.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 13th 07, 09:18 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley
"karl gruber" wrote in message
Half full or half empty?
Old April 13th 07, 10:17 PM posted to rec.aviation.piloting,rec.aviation.student
ManhattanMan
from an engineering standpoint, the bottle wasn't designed
correctly...........
Old April 13th 07, 11:08 PM posted to rec.aviation.piloting,rec.aviation.student
Little Endian
In the sim it makes no sense to avoid wake turbulence because you will
never know if you succeeded, its an exercise in futility.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
