Pushing the limit
Old August 17th 03, 08:48 PM
Dan Shackelford
Default Pushing the limit
On Sun, 17 Aug 2003 20:10:40 +0100, Mycroft wrote:
Can anyone think instances when an AC has been push beyond it's limits or
has done things it was never supposed too? The reason I ask is that I
recently read that when Lancasters were carrying Grandslams during WW2 the
engines were seriously over reved at take off because the bomb exceeded the
AC max payload weight by aprox 9000lbs.
Myc
Well, there are certainly instances of P-51s coming back with a few more
degrees of dihedral in the wings and maybe missing a bolt or two from
pulling out of dives that went way over the redline. Probably other
fighters as well.
Old August 17th 03, 09:06 PM
Cub Driver
During the evacuation of Burma in 1942, aircraft routinely carried
civilian passengers far beyond their rated capacity. DC-3s carried 50
or more people. Two-man Lysanders carried five and six people.
all the best -- Dan Ford
email: www.danford.net/letters.htm#9
see the Warbird's Forum at www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
Old August 17th 03, 11:26 PM
william cogswell
"Chris Mark" wrote in message During the evacuation of Burma in 1942,
you don't have to go back that far. Recall the fall of South Vietnam.
Probably the all-time record for the fixed wing and/or helicopter cramming
most people on board belongs to that episode
Chris Mark
You can get even more recent, i read a story that during the annual fishing
season in Alaska the fish haulers can with faa blessing (or at least their
professed ignorace) can exceed max gross weight by 10-15%
Old August 17th 03, 11:45 PM
BUFDRVR
Several B-52s were over G'd during Linebacker II, including one D model that
did a inadvertant barrel roll. During Desert Storm, several crew members recall
seeing well over 400 KIAS when flying low levels the first week. The BUFF max
IAS is 390 KIAS.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old August 18th 03, 12:11 AM
Dudley Henriques
"Mycroft" wrote in message
I had a P51D all the way out to .75 once after an O2 failure at altitude. I
had some "guest" engineers from North American as well as my personal crew
chief look the bird over pretty well afterward. Things were REALLY hum'in in
the pit there for a while for me:-)))
Although we estimated the tip rotational velocities went through the roof,
the airplane came through it ok. I did have a walking stick for awhile as
the airplane went into compressibility, but once down into denser air it
recovered ok with gentle back pressure to keep the g in limits.
No biggie really...tough airplane!
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/CFI
Retired
Old August 18th 03, 02:07 AM
Chris Mark
From "Air Force" magazine V83 N4:
"At Da Nang, a civilian airlift began, presaging the later confusion and terror
at Saigon. Edward J. Daly, president of World Airways, defied US Ambassador
Graham A. Martin and dispatched two Boeing 727s to Da Nang, flying on the first
one himself. After landing, his airplane was mobbed by thousands of people,
some 270 of whom were finally jammed on board. (All but a handful of these were
armed soldiers-not the civilians that Daly had intended to evacuate.) The 727
took off amid gunfire and a grenade explosion that damaged the flaps. It hit a
fence and a vehicle before staggering into the air. People had crowded into the
wheel well, and one man was crushed as the gear came up and jammed.
"Somehow the 727 made it back to Saigon, gear down and with split flaps,
managing to land safely. The dreadful photos of the dead man's feet hanging
from the gear doors told the miserable story. Ironically the one man's death
saved four others who had also climbed into the wheel well, for his crushed
body had prevented the gear from retracting all the way. Later, when the
details of the overweight and damage-laden takeoff were sent to Boeing for
analysis, the response was that the 727 should not have been able to fly."
Chris Mark
Old August 18th 03, 08:04 AM
Peter Twydell
In article , David Lesher
writes
"Mycroft" writes:
I thought I would pose the limit question as it make a change from best this
that or the other questions. Another story comes to mind from the Berlin
airlift when a C47 was given a load of coal really meant for an Avro York so
ended up with double it's max load; The pilot commented "I thought she was a
bit sluggish".
I recall the Airlift story the C47 misloaded with n sheets of
not the ordered perforated aluminium planking for runways, but n of
perforated STEEL planking...
According to a caption on a documentary on TV the other night, the C-
47's payload was 60000 lb; so what's the problem? ;-)
Peter
Ying tong iddle-i po!
Old August 20th 03, 10:32 PM
Arie Kazachin
In message - "Mycroft" writes:
Myc
In the most general sense, any military equipment often used beyond
it's limits or in a way it wasn't designed to - after all, how can you
fight without improvising?
I think an IAF F-15 landing having slightly more than one wing is quite
beyond what MD engineers designed it for.
An F-4E being able to land one piece after doing 14G was also remarkable
(although turned into static display and technitians training).
* Arie Kazachin, Israel, e-mail: *
NOTE: before replying, leave only letters in my domain-name. Sorry, SPAM trap.
___
.__/ |
| O /
_/ /
| | I HAVE NOWHERE ELSE TO GO !!!
| | /O\
| _ \_______[|(.)|]_______/
| * / \ o ++ O ++ o
\ \_)
\_|
Old September 8th 03, 06:05 AM
Les Matheson
IIRC all the MC-130's and EC-130's that departed Massirah Island for Desert
One in 1980 were over gross weight at take off and were pretty severely
stressed on landing in the Iranian desert. There were some pretty hairy
takeoffs from that site, too.
Sounds like the MH-53's that are working in Afghanistan are being "ridden
hard and put up wet", also.
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
Cessna 182T w. G-1000 pirep C J Campbell Instrument Flight Rules 63 July 22nd 04 07:06 PM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
