#51
Mxsmanic,
Or am I missing something? Life? -- Thomas Borchert (EDDH) |
#52
Mxsmanic,
Sixty degrees would be 2.7 Gs, GO AWAY! -- Thomas Borchert (EDDH) |
#53
#54
Sorry, I didn't notice the 60-degree part. Sixty degrees would be 2.7 Gs,
Incorrect statement. Sixty degrees would be 2 Gs. |
#55
Snowbird writes:
Do you have a reference saying this is always the case? Every reference I've checked says so. They sink at a variable rate, but usually at least 150-200 feet per minute, sometimes much more. They have to do this, because it is the reaction to forcing the downwash downward that produces lift. Maybe the propwash? I'd expect the propwash to be drawn down with the downwash, but I'm not sure. I would not expect the propwash to be significant after two minutes. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#56
In rec.aviation.piloting Mxsmanic wrote:
writes: Real people in real airplanes training to become real pilots do real 45 degree bank, constant altitude turns on a regular basis and run into their real wake. My research indicates that this is not possible. Your research at what, at your desk in front of Microsoft Flight Simulator? In my experience as a real pilot of real airplanes, it has happened. In the experience of many real pilots of real airplanes, it has happened. The altitude tolerance on a 360 degree turn is +/- 100 feet from start to finish. Once again, you have no context for understanding. snip ignorant nonsense -- Jim Pennino Remove .spam.sux to reply. |
#57
On Apr 13, 8:04 am, Mxsmanic wrote:
Snowbird writes: How does MS flight simulator simulate the symptoms of hypoxia? No provision is made for simulation of hypoxia of altitude. If the aircraft is accelerated, the simulator does simulate the visual effects of positive and negative Gs. No it doesn´t you moron. Bertie |
#58
On Apr 14, 7:18 pm, Mxsmanic wrote:
Snowbird writes: Do you have a reference saying this is always the case? Every reference I've checked says so. They sink at a variable rate, but usually at least 150-200 feet per minute, sometimes much more. They have to do this, because it is the reaction to forcing the downwash downward that produces lift. Maybe the propwash? I'd expect the propwash to be drawn down with the downwash, but I'm not sure. I would not expect the propwash to be significant after two minutes. Good grief. Bertie |
#59
On Apr 14, 7:16 pm, Mxsmanic wrote:
writes: Real people in real airplanes training to become real pilots do real 45 degree bank, constant altitude turns on a regular basis and run into their real wake. My research indicates that this is not possible. The wake sinks at a rate between 150 and 500 feet per minute (roughly). Thus, it would always be well below the airplane by the time it closes its own circle, unless the airplane is also descending. I've seen reports of pilots descending in a 360-degree turn and running into their own wakes. If they can descend and encounter their own wake, then they cannot remain at the same altitude and encounter it. It cannot be in two places at once. You´re an idiot. Bertie |
#60
![]() "Mxsmanic" wrote in message ... Snowbird writes: How does MS flight simulator simulate the symptoms of hypoxia? No provision is made for simulation of hypoxia of altitude. If the aircraft is accelerated, the simulator does simulate the visual effects of positive and negative Gs. The VISUAL effects of positive and negative Gs. Priceless! Lay off the simulated hypoxia sauce, you moron. You need to loose some simiulated altitude real fast. |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
