Question to Mxmanic
Old April 14th 07, 06:14 PM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Default Question to Mxmanic
Mxsmanic,
Or am I missing something?
Life?
Thomas Borchert (EDDH)
  #52
Thomas Borchert
Mxsmanic,
Sixty degrees would be 2.7 Gs,
GO AWAY!
  #54
Old April 14th 07, 06:18 PM posted to rec.aviation.piloting,rec.aviation.student
Little Endian
Sorry, I didn't notice the 60-degree part. Sixty degrees would be 2.7 Gs,
Incorrect statement. Sixty degrees would be 2 Gs.
  #55
Mxsmanic
Snowbird writes:
Do you have a reference saying this is always the case?
Every reference I've checked says so. They sink at a variable rate, but
usually at least 150-200 feet per minute, sometimes much more.
They have to do this, because it is the reaction to forcing the downwash
downward that produces lift.
Maybe the propwash?
I'd expect the propwash to be drawn down with the downwash, but I'm not sure.
I would not expect the propwash to be significant after two minutes.
  #57
Old April 14th 07, 06:45 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip
On Apr 13, 8:04 am, Mxsmanic wrote:
Snowbird writes:
How does MS flight simulator simulate the symptoms of hypoxia?
No provision is made for simulation of hypoxia of altitude. If the aircraft
is accelerated, the simulator does simulate the visual effects of positive and
negative Gs.
No it doesn´t you moron.
Bertie
  #58
Old April 14th 07, 06:47 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip
On Apr 14, 7:18 pm, Mxsmanic wrote:
Snowbird writes:
Maybe the propwash?
Good grief.
Bertie
  #59
Old April 14th 07, 06:47 PM posted to rec.aviation.piloting,rec.aviation.student,alt.disasters.aviation
Bertie the Bunyip
On Apr 14, 7:16 pm, Mxsmanic wrote:
writes:
Real people in real airplanes training to become real pilots do real
45 degree bank, constant altitude turns on a regular basis and run into
their real wake.
My research indicates that this is not possible. The wake sinks at a rate
between 150 and 500 feet per minute (roughly). Thus, it would always be well
below the airplane by the time it closes its own circle, unless the airplane
is also descending.
I've seen reports of pilots descending in a 360-degree turn and running into
their own wakes. If they can descend and encounter their own wake, then they
cannot remain at the same altitude and encounter it. It cannot be in two
places at once.
You´re an idiot.
Bertie
  #60
Old April 14th 07, 06:53 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
Snowbird writes:
aircraft
and
negative Gs.
The VISUAL effects of positive and negative Gs. Priceless!
Lay off the simulated hypoxia sauce, you moron. You need to loose some
simiulated altitude real fast.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
