Working on getting my PPL and I'm trying to figure out the difference
between standard rate turns versus constant rate turns and their relationship to speed. IIRC, a standard rate turn is 3 degrees per second and turn you 180 degrees in 1 minute. The rule of thumb for the bank angle to achieve this is to divide the airspeed by 10 and add half the resulting answer - i.e., standard rate at 100kts is about 15 degrees of bank... (So, if that's a standard rate turn, what's a constant rate one? Something other than 3 degrees a second?) But there's an indicator of rate of turn on the turn coordinator that indicates the standard rate turn. The mark doesn't move. The turn indicator is a gyro instrument just like the attitude indicator which also indicates bank. Question: How can the TI always hit the same mark for a standard rate turn independant of airspeed if, in fact, I'm turning at different bank angles as indicated on the AI? See, in my hood work, I've only looked at the pitch on the AI, the TI, altitude and compass - never thought to look at the angle of bank. OK, next question... If I'm banking at 20 degrees and moving at 100 kts, I will turn 180 degrees in a given amount of time and radius of turn. If I do that same 20 degrees of bank at 60 kts, I will turn 180 degrees in a given amount of time and radius. I know the radius between the 2 turns will be different. My intuition says that the turn will take the same amount of time - the radius is bigger but you're doing it faster. But the ROT I noted above for a standard rate turn woulf seem to indicate otherwise. I know I'm missing something but seem to be having a brain fart and can't see it. Was gonna go up and try this out but noticed my solo endorsement was up on Friday and my CFI won't be back in town till Monday. Thanks in advance... |
in 1 minute. Yes. (At least for piston powered planes. Jets may use half that IIRC) So [...] what's a constant rate one? Any turn at a constant rate of angular change. A standard rate turn is an example of a constant rate turn. A half standard rate turn is another. the turn indicator is a gyro instrument just like the attitude indicator which also indicates bank. It is a gyro instrument, yes, but it isn't "just like the attitude indicator". Don't let the display confuse you. The gyro is set at an angle, and when the airplane turns, a force develops between the airplane and the fixed axis of the gyro. This turns an indicator. The gyro =will= be dragged unwillingly around the turn, complaining the whole while. (This "complaint" is the turn indication ![]() By choosing the angle carefully, one can also have the =rate= of change of bank be incorporated into the indication, providing a more rapid response, at the expense of purity of indication. And for your last question, yes, for that reason the standard rate turn will indicate the same no matter what the speed and bank angle, because the gyro is not responding to bank angle. It is responding to the rapidity of change of nose direction. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
"Robert Barker" wrote:
Working on getting my PPL and I'm trying to figure out the difference between standard rate turns versus constant rate turns and their relationship to speed. IIRC, a standard rate turn is 3 degrees per second and turn you 180 degrees in 1 minute. The rule of thumb for the bank angle to achieve this is to divide the airspeed by 10 and add half the resulting answer - i.e., standard rate at 100kts is about 15 degrees of bank... (So, if that's a standard rate turn, what's a constant rate one? Something other than 3 degrees a second?) A standard rate turn is a specific KIND of constant rate turn. It's a constant rate turn whose rate happens to be 3 degrees per second. Ask your instructor to show you a chandelle or a lazy eight -- those are maneuvers from the commercial checkride which are NOT constant rate; the rate of turn changes throughout the maneuver. Be warned, your instructor may be hesitant to show you these because the last time he did them is probably the day he took his commercial checkride and he's forgotten how to do them :-) But there's an indicator of rate of turn on the turn coordinator that indicates the standard rate turn. The mark doesn't move. The turn indicator is a gyro instrument just like the attitude indicator which also indicates bank. Question: How can the TI always hit the same mark for a standard rate turn independant of airspeed if, in fact, I'm turning at different bank angles as indicated on the AI? Because the TC isn't an ATTITUDE gyro, it's a RATE gyro. Actually, a modern TC is designed to measure a mix of roll (bank) rate and yaw (turn) rate. There's a lot of clever engineering that went into designing how these little wonders work. |
The TC responds to bank/roll and to turn rate.
As for the effect of speed on rate of turn, ask the baseball pitcher about whether he would have missed the building had he slowed down and then banked steeply? The rate of turn decreases and the radius increases with increased air speed (TAS) and the radius is 4 times greater if you double the speed, so it is lost cause, unless you have the power of an F16, you can't maintain a turn at an 85° bank in level flight. Typical autopilot systems just do a 25° bank angle and let the rate work itself out. "Roy Smith" wrote in message ... | "Robert Barker" wrote: | | Working on getting my PPL and I'm trying to figure out the difference | between standard rate turns versus constant rate turns and their | relationship to speed. | | IIRC, a standard rate turn is 3 degrees per second and turn you 180 degrees | in 1 minute. The rule of thumb for the bank angle to achieve this is to | divide the airspeed by 10 and add half the resulting answer - i.e., standard | rate at 100kts is about 15 degrees of bank... (So, if that's a standard | rate turn, what's a constant rate one? Something other than 3 degrees a | second?) | | A standard rate turn is a specific KIND of constant rate turn. It's a | constant rate turn whose rate happens to be 3 degrees per second. | | Ask your instructor to show you a chandelle or a lazy eight -- those are | maneuvers from the commercial checkride which are NOT constant rate; the | rate of turn changes throughout the maneuver. Be warned, your instructor | may be hesitant to show you these because the last time he did them is | probably the day he took his commercial checkride and he's forgotten how to | do them :-) | | But there's an indicator of rate of turn on the turn coordinator that | indicates the standard rate turn. The mark doesn't move. The turn | indicator is a gyro instrument just like the attitude indicator which also | indicates bank. Question: How can the TI always hit the same mark for a | standard rate turn independant of airspeed if, in fact, I'm turning at | different bank angles as indicated on the AI? | | Because the TC isn't an ATTITUDE gyro, it's a RATE gyro. Actually, a | modern TC is designed to measure a mix of roll (bank) rate and yaw (turn) | rate. There's a lot of clever engineering that went into designing how | these little wonders work. |
Jim,
Typical autopilot systems just do a 25° bank angle and let the rate work itself out. Uhm, with the proliferation of rate-based AP systems (both from S-TEC and King), that statement simply doesn't hold true anymore for GA aircraft. It may have been true way back (can't imagine it, really, though, 25 degrees seems very steep), but it certainly isn't any longer. The S-Tecs (at least the 50) do 90 percent of standard rate, the King KAP 140 is similar. -- Thomas Borchert (EDDH) |
"Thomas Borchert" wrote in message ... Jim, Typical autopilot systems just do a 25° bank angle and let the rate work itself out. Uhm, with the proliferation of rate-based AP systems (both from S-TEC and King), that statement simply doesn't hold true anymore for GA aircraft. It may have been true way back (can't imagine it, really, though, 25 degrees seems very steep), but it certainly isn't any longer. The S-Tecs (at least the 50) do 90 percent of standard rate, the King KAP 140 is similar. -- Thomas Borchert (EDDH) Thanks to everyone who replied! Grabbed some coffee and my calculator this morning and ran thru some numbers... It seems obvios now, but not sure what I was basing my "intuition" on... |
| Thread Tools | |
| Display Modes | |
| A Q on horizontal turns | Ramapriya | Piloting | 14 | January 8th 05 12:46 AM |
| Why is a standard hold right turns? | Roy Smith | Instrument Flight Rules | 51 | August 28th 04 07:09 PM |
| Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 04:48 PM |
| Standard rate turn in Boeing 757? | Garyurbach | Piloting | 43 | June 18th 04 12:04 AM |
| Lapse Rate Question | Waduino | Soaring | 0 | October 1st 03 08:32 PM |
