Bad landings
Old April 15th 07, 06:04 PM posted to rec.aviation.piloting
Morgans[_2_]
Default Bad landings
: Does the main gear caster on those? I think I heard that it does, but I
: have no confirmation of that.
: Jim in NC
No
OK, now, I gotta ask more questions! g
I realize (I think) how a Ercoupe works, in the "no rudder control on the
floor models" works, with interconnects between the ailerons and the
rudders.
What about this, or how, does this arrangement make crosswind landings a "no
brainer?"
Jim in NC
Old April 15th 07, 06:42 PM posted to rec.aviation.piloting
Larry Dighera
On Sun, 15 Apr 2007 13:04:51 -0400, "Morgans"
wrote in :
brainer?"
Never having flow one, I offer:
The proper cross-wind landing technique for an Ercupe is to crab into
the wind maintaining flight-track straight down the runway centerline
all the way to the runway surface. At touchdown, the trailing-link
main gear design induces a side force near the CG that causes proper
alignment of the airplane's longitudinal axis with the runway
centerline.
It's a useful, inexpensive and relatively robust aircraft, that can be
operated as a Light Sport Aircraft, IIRC.
Old April 15th 07, 10:33 PM posted to rec.aviation.piloting
Newps
You simply land in a crab and the plane straightens itself out. Any
plane will do this but the Ercoupe is designed to do it without damaging
anything.
: Jim in NC
No
rudders.
brainer?"
  #24
Old April 16th 07, 12:27 AM posted to rec.aviation.piloting
Matt Whiting
anything.
Not any plane will do this. Tail draggers won't.
Matt
  #25
Old April 16th 07, 02:40 AM posted to rec.aviation.piloting
john smith[_2_]
anything.
They will if they have cross-wind landing gear. :-)
Actually, they will roll while still in the crab until the pilot kicks
rudder to straighten the alignment.
++NEW++3 DVD SET 'ON LANDINGS' +Much More Pilot Publications Products 0 June 26th 04 03:42 PM
++NEW++3 DVD SET 'ON LANDINGS' +Much More Pilot Publications General Aviation 0 June 26th 04 03:42 PM
++NEW++3 DVD SET 'ON LANDINGS' +Much More Pilot Publications Aviation Marketplace 0 June 26th 04 03:42 PM
Night landings vs. day landings Gerald Sylvester Piloting 15 February 12th 04 06:38 AM
off airport landings Stan Gosnell Rotorcraft 8 September 13th 03 04:49 PM
