#101
"Rip" wrote in message
et... Judah, one of his problems is that he fixates on insufficient information, and then gets frustrated when his assumptions are incorrect. Obviously, MX can only concieve of downwash generated by the wings as they create lift. Apparently, he can't concieve of the UPWASH created by the tail surfaces pushing DOWN, nor the potential for interaction between the two, or other turbulence that may be created in the air mass merely because a large object is plowing through it at a high rate of speed. Rip Or that the wake of a Cessna 150 might not sink as fast as the wake of a fully loaded 747... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#102
Rip wrote in news:AIvUh.10078$YL5.3718
@newssvr29.news.prodigy.net: Judah, one of his problems is that he fixates on insufficient information, and then gets frustrated when his assumptions are incorrect. He doesn't get frustrated. He simply denies the possibility that he is wrong by changing the scope of the original question so he can claim he was right all along. His ego simply won't allow him to be wrong. It's like a disease. Obviously, MX can only concieve of downwash generated by the wings as they create lift. Apparently, he can't concieve of the UPWASH created by the tail surfaces pushing DOWN, nor the potential for interaction between the two, or other turbulence that may be created in the air mass merely because a large object is plowing through it at a high rate of speed. I didn't think of this myself, but it certainly makes sense to me. I suspect it will make sense to MX too, and then he will try to convince us all that this doesn't qualify as Wake Turbulence or that he was only referring to downwash from the wings to begin with or some other change in the scope of his comments to make him right (at least in his own mind). |
#103
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:WvWdnUKzmpUiF7_bnZ2dnUVZ_rOqnZ2d@wideopenwest .com... "Rip" wrote in message et... Judah, one of his problems is that he fixates on insufficient information, and then gets frustrated when his assumptions are incorrect. Obviously, MX can only concieve of downwash generated by the wings as they create lift. Apparently, he can't concieve of the UPWASH created by the tail surfaces pushing DOWN, nor the potential for interaction between the two, or other turbulence that may be created in the air mass merely because a large object is plowing through it at a high rate of speed. Rip Or that the wake of a Cessna 150 might not sink as fast as the wake of a fully loaded 747... -- Or that the tip vortices might be called that for a reason, or the effects that might have, etc. ad infinitum. Peter |
#104
On 4/15/2007 1:35 PM Judah jumped down, turned around, and wrote:
It's like a disease. A disease ... or a syndrome? http://en.wikipedia.org/wiki/Asperger_syndrome http://www.aspergers.com/ It's a puzzlement. -- dgs |
#105
"d.g.s." wrote in news:58fm5hF2fkop4U1
@mid.individual.net: On 4/15/2007 1:35 PM Judah jumped down, turned around, and wrote: It's like a disease. A disease ... or a syndrome? http://en.wikipedia.org/wiki/Asperger_syndrome http://www.aspergers.com/ It's a puzzlement. Tough to say. I think he's closer to Schizophrenia than Aspergers, but I'm not a doctor. For one thing, Aspergers subjects focus on a specific activity to the exclusion of other activities. Manic, on the other hand, has demonstrated that he can haunt several differently themed newsgroups besides just Aviation - including Travel, Photography, and Technology newsgroups. No, I don't think he's got Aspergers. |
#106
Mxsmanic wrote:
Judah writes: What is the wingspan of the aircraft? The wingspan shouldn't matter. Altimeters make this less likely than you might believe. Perhaps you are the one that doesn't realize something. As you admit below, you didn't put much thought into your determination. To convince me, I need an explanation of why wakes descend universally except by some magic exception when someone is doing a 360-degree turn. Perhaps you are not considering all the causes of turbulence that follow an aircraft (in it's wake)? Cheers MarkC |
#107
Rip wrote:
Judah, one of his problems is that he fixates on insufficient information, and then gets frustrated when his assumptions are incorrect. Obviously, MX can only concieve of downwash generated by the wings as they create lift. Apparently, he can't concieve of the UPWASH created by the tail surfaces pushing DOWN, nor the potential for interaction between the two, or other turbulence that may be created in the air mass merely because a large object is plowing through it at a high rate of speed. Rip BINGO! Cheers MarkC |
#108
DR writes:
Perhaps you are not considering all the causes of turbulence that follow an aircraft (in it's wake)? Perhaps others are not considering all the causes of turbulence besides aircraft wakes. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#109
In rec.aviation.piloting Mxsmanic wrote:
DR writes: Perhaps you are not considering all the causes of turbulence that follow an aircraft (in it's wake)? Perhaps others are not considering all the causes of turbulence besides aircraft wakes. You do a 360 and run into a bump when, and only when, you complete the 360. Invisible UFO's crossing at your exact starting point? -- Jim Pennino Remove .spam.sux to reply. |
#110
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
