Question to Mxmanic
Old April 16th 07, 10:30 AM posted to rec.aviation.piloting,rec.aviation.student
mike regish
Default Question to Mxmanic
On a bumpy day you wouldn't be able to tell the wake from the overall
turbulence.
On an otherwise smooth day you can.
It can be done, Tony.
mike
"Mxsmanic" wrote in message
writes:
You do a 360 and run into a bump when, and only when, you complete
the 360.
Or you run into bumps but only notice the one that you hit when you
complete
the 360.
  #112
Old April 16th 07, 02:37 PM posted to rec.aviation.piloting,rec.aviation.student
Kev
On Apr 14, 4:27 pm, "george" wrote:
I always maintained altitude and rate of turn in steep turns with the
end result being hitting my own slipstream.
As have we all on nice days, and students like to brag about it. Yet
Mx is correct, in theory we should not be able to do this.
I seem to recall recent magazine (web?) articles where the idea that
you can hit your own wake while actually holding altitude, should be
downplayed nowadays. You _have_ to descend a little bit to do so,
which means that, while you might be within the +/- 100' test
scenario, you are NOT holding the same exact altitude.
Hmm. Or else it means that the wake doesn't necessarily descend as
we're taught. On a warm clear day (which is when I've hit my own
wake), I betcha that the wake is being held upward a tiny bit by the
heat from the ground.
Cheers, Kev
  #113
Old April 16th 07, 02:41 PM posted to rec.aviation.piloting,rec.aviation.student
Jose
How tall is the wake?
Jose
Get high on gasoline: fly an airplane.
  #115
Old April 16th 07, 03:07 PM posted to rec.aviation.piloting,rec.aviation.student
Kev
Good point. Still, using the calculator at:
http://www.csgnetwork.com/aircraftturninfocalc.html
It's going to take about 30 seconds to fly a 360 steep turn at
100kts. My wake _should_ descend about 150' during that time (300
fpm). I can't imagine a C172 wake being tall enough to stay in my
way unless something else is ocurring (me descending, or the wake
staying up).
Would love to hear a decent explanation. Kev
  #116
Old April 16th 07, 03:22 PM posted to rec.aviation.piloting,rec.aviation.student
Jose
way...
I can. 150 feet is not tall at all for a wake. Remember, the air
around the wake is also being dragged by the wake vortex.
You're going to bump into something.
Jose
  #117
Old April 16th 07, 03:35 PM posted to rec.aviation.piloting,rec.aviation.student
staying up).
Upon what do you base the assumption your wake should decend 150'?
I have never heard of any study of the wake properties of GA aircraft
and the wake of a C172 is very different than the wake of a 747 so
to extrapolate from studies of transport catagory wakes is pointless.
Jim Pennino
Remove .spam.sux to reply.
  #118
Old April 16th 07, 03:45 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Kev writes:
Then you must be descending through the rising column of air.
  #119
Old April 16th 07, 03:47 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Jose writes:
The downwash is at least equal in height to the total wingspan of the
aircraft. Downwash is a large mass of air moving slowly. Still, you should
not be hitting your own wake in a 360-degree turn unless you are descending to
catch it. Oddly enough, if you are descending, the wake moves more slowly
(because you are generating less lift).
  #120
Old April 16th 07, 03:51 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Jose writes:
It's extremely tall for a small aircraft. The wake would probably be about 50
feet high.
Remember, the air around the wake is also being dragged by the wake vortex.
But at very slow speed. Even the downwash itself is moving slowly, only a few
knots. Any of the winds that one often encounters at altitude would be enough
to rapidly disperse it.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
