Question to Mxmanic
Old April 16th 07, 03:56 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Question to Mxmanic
mike regish writes:
On a bumpy day you wouldn't be able to tell the wake from the overall
turbulence.
I agree.
On an otherwise smooth day you can.
Probably--if you actually hit it.
It can be done, Tony.
Not without descending. The wake _must_ descend. This means that you cannot
catch it unless you descend, also. If you can explain how this rule can be
broken, I'm listening.
  #124
Old April 16th 07, 04:15 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Kev" wrote in message
On Apr 16, 9:41 am, Jose wrote:
I seem to recall recent magazine (web?) articles where the idea that
you can hit your own wake while actually holding altitude, should be
downplayed nowadays. You _have_ to descend a little bit to do so,
How tall is the wake?
Good point. Still, using the calculator at:
http://www.csgnetwork.com/aircraftturninfocalc.html
It's going to take about 30 seconds to fly a 360 steep turn at
100kts. My wake _should_ descend about 150' during that time (300
fpm). I can't imagine a C172 wake being tall enough to stay in my
way unless something else is ocurring (me descending, or the wake
staying up).
Would love to hear a decent explanation. Kev
I am certainly no expert on the subject, but I think most of the data on
wake turbulence comes from studies held at or very near the ground.
Certainly not all, because I recall an old FAA film on landing in wake
turbulence using a 182 to fly into the wake at altitude. But IIRC it was
part of an awareness film on wake turbulence on approach, just demonstrated
at altitude for safe demonstration of its actual effects.
Based on the numbers I recall, they did indeed teach that the wake from a
landing heavy would NORMALLY travel both down and away from the aircraft a 5
kts or so. But they were also quick to mention that a simple 5 kt or so
crosswind componet could leave the vortex in the middle of the runway for
quite some time.
The problem with trying to use this information at altitude is that you
don't have the ground to help stablize the vertical movement of the vortex.
And every pilot knows the air at altitude is very seldom static, especailly
in warm weather. As someone else mentioned, the vortex that started as a
very small column at the wing tip, can grow very large by the time you
complete a 360 turn at even 60 degrees of bank.
The point is, you are dealing with far to many variables to expect absolute
answers your question or even your own in flight results. Wake turbulence is
really only a problem at altitude if you don't avoid the flight path of
heaver aircraft, and understanding it's presence on take off and landing,
because it is much easier to intercept their flight path around runways.
  #126
Old April 16th 07, 04:25 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
Jose writes:
The downwash is at least equal in height to the total wingspan of the
aircraft. Downwash is a large mass of air moving slowly. Still, you
should
not be hitting your own wake in a 360-degree turn unless you are
descending to
catch it. Oddly enough, if you are descending, the wake moves more slowly
(because you are generating less lift).
Priceless bucko!!!!!
It sounds to me like you are experiencing some serious wake tubulence in the
airspace between your ears.
  #127
Old April 16th 07, 04:27 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
mike regish writes:
turbulence.
I agree.
cannot
be
Total bull****. You haven't a clue.
  #129
Old April 16th 07, 04:39 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
Then listen hard. The wake consists of more than just the downwash you
are fixated on. If you have ever seen a sky-writer at work, you would
know, even without setting foot in a real aircraft, that it is possible
to return to the same parcel of air and pass through the smoke you had
left previously.
On a calm day, no descending or climbing is required.
Your problem is your fixation on your assumptions, and then insisting
that physical reality must be wrong when your limited assumptions don't
square with that reality, a true sign of immaturity and a basic
inability to assimilate the information that your own senses provide.
Anthony, I'm actually beginning to feel sorry for you. I believe that
you have real, diagnosable mental issues.
Rip
  #130
Old April 16th 07, 04:51 PM posted to rec.aviation.piloting,rec.aviation.student
JB
On Apr 16, 10:45 am, Mxsmanic wrote:
Kev writes:
On a warm clear day (which is when I've hit my own
wake), I betcha that the wake is being held upward a tiny bit by the
heat from the ground.
Then you must be descending through the rising column of air.
You are such an idiot! Probably every GA pilot-in-training with a
C152/172 or something similar has experienced hitting their own wake
when performing their first steep turn with an instructor. I know I
did. I routinely show non-flying friends this phenomenon when I take
them flying.
But go ahead...keep arguing with experience that you don't have.
--Jeff
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
