Question to Mxmanic
Old April 16th 07, 06:02 PM posted to rec.aviation.piloting,rec.aviation.student
Rip
Default Question to Mxmanic
Mxsmanic wrote:
rq3 writes:
The wake consists of more than just the downwash you
are fixated on. If you have ever seen a sky-writer at work, you would
know, even without setting foot in a real aircraft, that it is possible
to return to the same parcel of air and pass through the smoke you had
left previously.
I never questioned that.
On a calm day, no descending or climbing is required.
How do you know? What skywriting have you done?
About 200 hours aerobatics with smoke. What skywriting have YOU done?
Rip
  #152
Old April 16th 07, 06:06 PM posted to rec.aviation.piloting,rec.aviation.student
Rip
Mxsmanic wrote:
rq3 writes:
Still fixated on the idea that the downwash is the only component of
wake, huh, Anthony?
I've never been fixated on such a notion. All of the wake behind an aircraft
descends, including the downwash.
Please provide a reliable reference for that staement.
Rip
  #153
Old April 16th 07, 06:09 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Maxwell writes:
Trim Luke! Trim.
Add power.
  #154
Old April 16th 07, 06:55 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
Maxwell writes:
Trim Luke! Trim.
Add power.
That's right Luke, add the power of the trim!!!!! Now your are getting
it!!!!!!!!!!!!!!
  #155
Old April 16th 07, 07:03 PM posted to rec.aviation.piloting,rec.aviation.student
mike regish
What is the vertical component of the vector if you have the wake traveling
outward perpindicular to the wings? It will be 150' from the original path,
but at an angle to vertical.
mike
"Kev" wrote in message
On Apr 16, 9:41 am, Jose wrote:
I seem to recall recent magazine (web?) articles where the idea that
you can hit your own wake while actually holding altitude, should be
downplayed nowadays. You _have_ to descend a little bit to do so,
How tall is the wake?
Good point. Still, using the calculator at:
http://www.csgnetwork.com/aircraftturninfocalc.html
It's going to take about 30 seconds to fly a 360 steep turn at
100kts. My wake _should_ descend about 150' during that time (300
fpm). I can't imagine a C172 wake being tall enough to stay in my
way unless something else is ocurring (me descending, or the wake
staying up).
Would love to hear a decent explanation. Kev
  #156
Old April 16th 07, 07:04 PM posted to rec.aviation.piloting,rec.aviation.student
mike regish
And maintaining you altitude above the ground via altimeter...
mike
Then you must be descending through the rising column of air.
  #157
Old April 16th 07, 07:05 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Maxwell writes:
No, power instead of trim. You need more lift.
  #158
Mxsmanic
Rip writes:
No skywriting?
None.
  #159
Old April 16th 07, 07:06 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Rip writes:
Every reference I can find mentions it.
  #160
mike regish
We have. Rising air. It happens all the time over the plowed cornfields I
fly over. The plane doesn't also rise with the air because we are
maintaining out altitude above the ground.
mike
If you can explain how this rule can be
broken, I'm listening.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
