Question to Mxmanic
Old April 18th 07, 09:06 PM posted to rec.aviation.piloting,rec.aviation.student
Erik
Default Question to Mxmanic
Mxsmanic wrote:
Gary writes:
What part of "maintaining our altitude" sounds like "descending" to
you?
The part that is combined with rising air.
I'm new here and junk. I've read a boatload of these posts and I've
started to empathize with you. Why are these people calling you names?
Jeesh, they're just mean.
Except that I run into posts like this and go, "ah, I see."
Rising air and maintaining altitude does not decsending make. Bringing
your altitude closer to the ground makes a decsent. You can't maintain
altitude and decsend at the same time. I think that's one of the
questions in the written. Or it's in some FAR. They'll suspend your
cert for 5 years if you decsend whilst maintaining altitude.
Do yourself a big favor. Get out there and spend the $50-60 and get an
intro flight. Take some damn lessons. Hell, even get a CFI just to get
out there and do some of this. You'll see how vastly different it is
from MS's Flight sim.
  #292
Old April 18th 07, 09:13 PM posted to rec.aviation.piloting,rec.aviation.student
Erik
Mxsmanic wrote:
JB writes:
You are such an idiot! Probably every GA pilot-in-training with a
C152/172 or something similar has experienced hitting their own wake
when performing their first steep turn with an instructor.
Steep turns tend to be descending turns.
See, this is one of those posts. That's why you practice. A steep turn
is not supposed to be a descending turn.
I don't know why. It seems that the argument that you're not supposed
to hit your own wake seems to be pretty valid. You can also bring
evidence that supports the theory that the sky is not blue, but there it
is, blue as hell.
  #293
Old April 18th 07, 09:43 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
mike regish writes:
It is not acceleration. It is speed. GPS travels much faster than we do.
No. There are nearly half a dozen relativistic effects that must be
compensated for in the GPS. The nominal clock frequencies, for example, must
be adjusted by slightly less than one part in two billion in order to adjust
for the cumulative relativistic effects.
I doubt we have clocks accurate enough to measure the relativistic effects at
our speeds.
Sure you do ... in your GPS receivers. The adjustments for relativistic
effects are necessary to make the receivers reasonably accurate.
  #294
Old April 18th 07, 09:45 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
swag writes:
so didyou when you did your "test flight?"
In the sim? No, there was no bump.
You won't encounter a bump from wake turbulence unless you are
doing a steep turn ( like 45 degree bank angle which should
take 19 seconds to go 360)
Why would the steepness of a turn matter?
A 2-G turn is rather close to the load limits for many types of aircraft.
  #295
Old April 18th 07, 09:56 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
mike regish writes:
must
adjust
effects at
our speeds.
Wow! That's useful information!
  #296
Old April 18th 07, 09:59 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
swag writes:
What a dumb ****! Are you kidding???
If someone rolled your brain up in to a ball, and rolled it down a razor
blade -
it would look like a B-B rolling down a four lane highway.
  #297
Old April 18th 07, 11:29 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Nomen Nescio" wrote in message
-----BEGIN PGP SIGNED MESSAGE-----
Yea, that puts you about 35% of the way to airframe damage.
Pretty damned reckless to only leave yourself a 180% margin.
With that level of fear, I'm surprised that you ever leave your room.
Er......Um................................Nevermin d.
I wonder if he has ever analyzed how much stress his fat butt is putting on
the floor joices in his bedroom. If he fell out of his computer chair from
18" or so, he might not have a 180% margin.
  #298
Old April 19th 07, 12:36 AM posted to rec.aviation.piloting,rec.aviation.student
ManhattanMan
putting on the floor joices in his bedroom. If he fell out of his
computer chair from 18" or so, he might not have a 180% margin.
He'd just land on his ass and suffer a concussion........
  #299
Old April 19th 07, 01:19 AM posted to rec.aviation.piloting,rec.aviation.student
george
The clock on your aircraft runs slower as you accelerate, due to relativistic
effects. But then it also runs faster as you climb, again due to relativistic
effects. Do you take these effects into account in your on-board
calculations?
Only if I'm approaching light speed.
I also have to do a new weight & balance.
When you slow down you get heavy speed so the W&B shouldn't change
ROTFL
  #300
Old April 19th 07, 03:13 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Nomen Nescio writes:
And I only worry about compressibility if I'm approaching Mach 1, which
doesn't happen often in a Baron. QED.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
