On the hydraulic flaps, does the position of the silver pump handle
	have any bearing on whether or not the hydraulic pressure leaks out of the flap, once they are extended? (The POH doesn't say that it does.) There is some mechanism underneath the instrument panel that has some adjustment for the Positive Control. What does it do, exactly?  |
On 18 Apr 2007 08:10:13 -0700, Greg Esres  wrote:
	On the hydraulic flaps, does the position of the silver pump handle have any bearing on whether or not the hydraulic pressure leaks out of the flap, once they are extended? (The POH doesn't say that it does.) Yes. That's how you retract the flaps. There is some mechanism underneath the instrument panel that has some adjustment for the Positive Control. What does it do, exactly? I don't recall anything at all like that in either the '68C or the '65E models with which I have experience. --ron  |
	No, the retraction mechanism is a little flap-like lever *above* the silver handle. Lifting it up releases the hydraulic pressure. When it's down, the pressure should remain. The silver handle I'm talking about is the pumping handle. The flaps are coming up some times when I'm not looking and I haven't established a pattern yet. ;-) On Apr 18, 7:47 pm, Ron Rosenfeld wrote: On 18 Apr 2007 08:10:13 -0700, Greg Esres wrote: On the hydraulic flaps, does the position of the silver pump handle have any bearing on whether or not the hydraulic pressure leaks out of the flap, once they are extended? (The POH doesn't say that it does.) Yes. That's how you retract the flaps. There is some mechanism underneath the instrument panel that has some adjustment for the Positive Control. What does it do, exactly? I don't recall anything at all like that in either the '68C or the '65E models with which I have experience. --ron  |
Although I have relatively little experience in this aircraft, the silver metal pump handle pumps the flaps down when the flap "lever" is in the down position, and the pump handle position didn't matter. (I always unconsciously pulled it back to the top stop whenever I used it however.) The flap "lever" is beside or immediately above the pump handle - I don't remember for sure.
	I never saw anything labeled "Positive Control" on the bird I flew. -- Jim Carter Rogers, Arkansas "Greg Esres" wrote in message ups.com... On the hydraulic flaps, does the position of the silver pump handle have any bearing on whether or not the hydraulic pressure leaks out of the flap, once they are extended? (The POH doesn't say that it does.) There is some mechanism underneath the instrument panel that has some adjustment for the Positive Control. What does it do, exactly?  |
	pulled it back to the top stop whenever I used it however.) That's how I read the POH. However, the flaps seem to creep up sometimes. I never saw anything labeled "Positive Control" on the bird I flew. I thought they all had this? Probably no label....built-in wing leveler. Thanks  |
On 18 Apr 2007 20:27:36 -0700, Greg Esres
	wrote: the pump handle position didn't matter. (I always unconsciously pulled it back to the top stop whenever I used it however.) That's how I read the POH. However, the flaps seem to creep up sometimes. I never saw anything labeled "Positive Control" on the bird I flew. I thought they all had this? Probably no label....built-in wing leveler. brushed-aluminum pushbuttojn on left horn of yoke? extra knob on turn-and-sllip? Don  |
On 18 Apr 2007 19:16:58 -0700, Greg Esres  wrote:
	Yes. That's how you retract the flaps. No, the retraction mechanism is a little flap-like lever *above* the silver handle. Lifting it up releases the hydraulic pressure. When it's down, the pressure should remain. The silver handle I'm talking about is the pumping handle. Oh, I misread. It shouldn't make any difference, but I've always left it fully down (out of the way). On occasion, during pre-flight, it might be in an intermediate position, though. I'd suspect a leak in the hydraulic system. The flaps are coming up some times when I'm not looking and I haven't established a pattern yet. ;-) On Apr 18, 7:47 pm, Ron Rosenfeld wrote: On 18 Apr 2007 08:10:13 -0700, Greg Esres wrote: On the hydraulic flaps, does the position of the silver pump handle have any bearing on whether or not the hydraulic pressure leaks out of the flap, once they are extended? (The POH doesn't say that it does.) Yes. That's how you retract the flaps. There is some mechanism underneath the instrument panel that has some adjustment for the Positive Control. What does it do, exactly? I don't recall anything at all like that in either the '68C or the '65E models with which I have experience. --ron --ron  |
Ron Rosenfield wrote:
	I'd suspect a leak in the hydraulic system. That's kinda what I was thinking. Thank you.  |
Don Tuite wrote:
	brushed-aluminum pushbuttojn on left horn of yoke? Yes extra knob on turn-and-sllip? Hmmm, I don't think so. There is such a knob on the yoke itself that is aileron trim. I don't think the system uses the panel turn & slip; it has its own internal equivalent of a turn coordinator, according to the documentation I've seen.  |
On Apr 18, 8:27 pm, Greg Esres  wrote:
	the pump handle position didn't matter. (I always unconsciously pulled it back to the top stop whenever I used it however.) That's how I read the POH. However, the flaps seem to creep up sometimes. I never saw anything labeled "Positive Control" on the bird I flew. I thought they all had this? Probably no label....built-in wing leveler. Thanks I'd instruction in a lot of Mooneys but I've not seen any that didn't have at least the vac wing leveler autopilot. All the way back in the early days of the C they had the wing leveler, and later offered an upgrade to the electric Pathfinder system. The PC system had a check valve as I recall to prevent leaks in the PC system (which most planes have) from causing vac failures. Up until 1977 Mooneys were certified with full-time autopilots (maybe the only plane so certified). The autopilot was designed to be on all the time unless the pilot actively held down a button to disable it. Turns are made by selecting left/ right on the controller. However, the A/P is easily over powered. -Robert, CFII  |
| Thread Tools | |
| Display Modes | |
| FS: 1965 Mooney M20C | Ken Martin | Aviation Marketplace | 0 | August 20th 05 04:09 AM |
| Mooney Down | Teranews | Piloting | 0 | February 17th 05 05:19 PM |
| 64 M20C Turn/Slip replacement | BellSouth.net News | Owning | 3 | September 1st 04 04:07 PM |
| 64 M20c Avionics Cover Sealing? | BellSouth.net News | Owning | 2 | August 23rd 04 04:42 AM |
| Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 07:06 AM |
