Hawaiian MOGAS, ethanol, the EAA and your local legislature
Old April 20th 07, 07:40 PM posted to rec.aviation.homebuilt
wright1902glider
Default Hawaiian MOGAS, ethanol, the EAA and your local legislature
I ran across this notice on the EAA website today regarding proposed
legislation in the state of Hawaii to exclude premium mogas from the
10% ethanol requirement. Please take a few minutes to read the Bill
itself. This may be very useful if you live in an area where only E10
is sold, and there is no way to modify your engines or fuel systems to
run ethanol. I don't personally have an aircraft that is affected by
E10, and I'm planning to upgrade the fuel system on my boat, lawn
mower, etc. But for those aircraft, boats, and chainsaws that can't be
modified or STC'd for ethanol, this does sound like a working
comprimise. It may pass in state legislatures without too much grief
from the radical environmentalists or farmers.
http://www.eaa.org/communications/ea...4_ethanol.html
Harry "Teddy Roosevelt was a tree-huggung conservative" Frey
Old April 22nd 07, 03:04 PM posted to rec.aviation.homebuilt
J.Kahn
What's required for an a/c to run on part ethanol?
John
Old April 22nd 07, 10:37 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"J.Kahn" wrote in message
John
Seals, gaskets, O-rings, and and any hoses in the existing system may or may
not hold up against ethanol - likely at least some will not. Corrosion of
the fuel tank may also be an issue. If you want to go with more than 10-20%
ethanol you will need to re-jet your fuel delivery system.
Geoff
Old April 23rd 07, 11:58 PM posted to rec.aviation.homebuilt
Al G[_1_]
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
news:3ZKdnTWzMOEfSLbbnZ2dnUVZ_i2dnZ2d@wideopenwest .com...
John
may not hold up against ethanol - likely at least some will not. Corrosion
of the fuel tank may also be an issue. If you want to go with more than
10-20% ethanol you will need to re-jet your fuel delivery system.
Geoff
There is also the problem of water in the fuel, and the overall loss of
horsepower. Your previous take-off distances will not apply.
Al G
MoGas users: Ethanol replacing MTBE John Piloting 167 May 5th 06 08:31 PM
MoGas users: Ethanol replacing MTBE Javier Piloting 6 May 4th 06 06:28 AM
Ethanol mogas john smith Owning 16 May 2nd 06 01:30 PM
Is EAA Working on an STC for Ethanol-laced MoGas? Jay Honeck Piloting 43 November 28th 05 03:39 AM
Local Amoco now blending ethanol Ben Smith Owning 5 April 1st 04 04:37 PM
