Am trying to find some info to help accurize (a somewhat outdated)
Vietnam era flight sim - Janes Fighters Anthology. Can any of you military folks remember any numbers about the blast frag distances for various aircraft bombs - 500/750/2000/3000 lb? How about nape/CBUs/2.75 in FFARs? What would be the safe release heights for each or any of these before you can expect to be affected by your own ordnance? I don't have access to an F-105 or F-4 dash 34 manual, but I bet that would answer my questions. Thanks, Mike Druzolowski |
"Mike D" wrote...
Am trying to find some info to help accurize (a somewhat outdated) Vietnam era flight sim - Janes Fighters Anthology. Can any of you military folks remember any numbers about the blast frag distances for various aircraft bombs - 500/750/2000/3000 lb? How about nape/CBUs/2.75 in FFARs? What would be the safe release heights for each or any of these before you can expect to be affected by your own ordnance? I don't have access to an F-105 or F-4 dash 34 manual, but I bet that would answer my questions. Most of that information is in Confidential Tactical Manuals. It also varies widely with delivery parameters, fuzes, and other variables. |
You are really asking two different questions....
The Fragment Envelope for the weapon (how high, far, fast do fragments travel) .... And the safe release height for that weapon.... In level flight you can drop (a single MK-82 for example) from an altitude lower than the maximum height of the frag pattern (due to your forward velocity during the time of fall and the time for the fragments to travel outward). The slower you are the higher you need to drop and vice versa Then you need to throw in the fuze arming delay, diving deliveries, ripple deliveries, type of escape maneuver (level, climbing, turning, lateral, backup) etc.... So if you were going to check out your modeling, and simply looked at maximum height of the frag pattern to determine if you were a 'mort' or not, I'd think you'd be given a false view of what's really going on. FWIW Mark "Mike D" wrote in message om... Am trying to find some info to help accurize (a somewhat outdated) Vietnam era flight sim - Janes Fighters Anthology. Can any of you military folks remember any numbers about the blast frag distances for various aircraft bombs - 500/750/2000/3000 lb? How about nape/CBUs/2.75 in FFARs? What would be the safe release heights for each or any of these before you can expect to be affected by your own ordnance? I don't have access to an F-105 or F-4 dash 34 manual, but I bet that would answer my questions. Thanks, Mike Druzolowski |
Thanks for the responses. I guess what I'm looking for is the minimum
safe release altitude (estimate) where you could release in a dive then level out right over the target (I know, not recommended) and not heve to worry about being knocked out of the sky. (I just don't want to be able to drop a 3000 lb. M118 from 900 feet at 190 knots and fly away unscathed, because I suspect that this is way too low! The DuoSoft Toolkit allows creation and/or modification of ordnance used within the sim, but I don't have any real world info to base some of the characteristics on. Thanks again everyone. Mike D. |
Mike D wrote:
Am trying to find some info to help accurize (a somewhat outdated) Vietnam era flight sim - Janes Fighters Anthology. Can any of you military folks remember any numbers about the blast frag distances for various aircraft bombs - 500/750/2000/3000 lb? How about nape/CBUs/2.75 in FFARs? What would be the safe release heights for each or any of these before you can expect to be affected by your own ordnance? I don't have access to an F-105 or F-4 dash 34 manual, but I bet that would answer my questions. Safe release heights vary considerably due to speed, angle, clean or retard, maneuver, etc., and are much too long to list here. If you really want this stuff you need to invest in a -34. The following info is from the frag graphs, but realize that each of these shows a pure vertical time vs. height envelope, as well as a coupel of horizontal time vs. height vs. distance curves. I'm just giving you the height and max. horizontal distances. Max. frag. envelopes from the F-4C-34-1-1: Mk. 82: Top of frag envelope 2,520 feet vertical @ 9 seconds after detonation. Max. horizontal spread at ground level +- 3,100 feet 2 13 seconds plus. Mk. 83: Top 2,820 feet vertical @ 9 sec. after detonation. Max. horizontal spread @ ground level +- 3,400 feet @ 15 sec. plus Mk. 84: Top 2,820 feet vertical @ 9 sec. after detonation. Max. Horizontal spread @ ground level +-3,400 feet @ 15 sec. plus. M117 (Tritonal filling): Top 2,450 feet vertical @ 7 seconds after detonation. Max. horizontal spread @ ground level +-2,900 feet @ 13 sec. plus. Unfortunately, there's no frag envelope graph for the M118, just safe escape and safe tables (the other bombs also have these), which would take far too long to type in. HTH, Guy |
Dropping a slick from level flight below 1000 is dangerous because the
bomb can bounce back up. Known as "broaching"(if the weapon actually enters the ground below it, then "pops back up) or "ricocheting" (if the weapon simply hits the ground and bounces back up). We dropped inert Mk82s at 300 AGL 500K and the things were bouncing up level with us. (They were also bouncing off the Avon Park range so we had to stop that.) Walt, surely this was known about in the 60's and 70's no? I find it hard to believe this is a recently discovered phenomena. It's not a comfortale feeling to fly "in formation" with your own weapons. As a young co-pilot I watched one of our Mk-82 AIRs fly up in front of the wing, then off to the side. Obviously the AIR didn't function. BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
For BUFDRVR - bouncing bombs were known about in WW2 - skip-bombing.
Very effective against ships (Bismarck Sea). Was also used against tanks. (And big dams) We just didn't expect to see it at Avon Park that day in 1968. It was a low ceiling, under 1000 AGL, and we couldn't dive bomb. Our IP had big ones and gave us the choice of dropping or aborting to fly the mission again on a better day. We wanted to drop so he led us around the pattern. About the third time around the Range Officer called a halt as the bouncers were going off the south end of the tactical range and that was it for the day. We formed up and got another thirty minute of wing weather time going home. We did get an actual road cut - one of the bombs hit the thin-layer asphalt-on-sand road around the end of the tac range and cratered it nicely. (500# concrete filled M82 dropped at 450 KIAS) I suppose that would be a major incident these days. Back then it was just worth a chuckle or two. Sigh. Skip bombing went out of favor just before/during SEA - flak. We used to bet on range scores - hits 'on the fly' were all that counted in operational outfits, dropping blue bombs (BDU33) in level flight at 50' agl and 450 against a 10x20 cloth target. Going below the range tower's sight line - about 40') was a foul - no score. Walt BJ |
| Thread Tools | |
| Display Modes | |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 04:13 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 08:00 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 03:31 PM |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 08:17 AM |
