Oh, I dunno, you don't win races by blowing up engines - you have to finish.
Most of what goes into race prepping an engine is beefing it up so it lasts the whole race at extreme power output. Reduce power to a more reasonable level and a race engines will last practically forever. The current crop of "Sport Touring" motorcycles are just that - de-tuned racers. Having one wear out or fail in service is almost unheard of. The same tricks used to increase reliability of a race engine can be used to increase reliability even further in normal use. DLC's increase reliability not power. Bill Daniels "Scott" wrote in message news ![]() Certified? Not in a "homebuilt" group! ![]() However, that said, I think you are right...reliability is a relatively unknown word in racing engine circles I suspect... I'm still waiting for the space shuttles to be reitred so I's can get one of their engines as surplus and bolt it on my Corben :O Scott Maxwell wrote: "Bill Daniels" bildan@comcast-dot-net wrote in message ... I've been following the development of Diamond-Like Coatings (DLC's) for a decade of so. These are vapor deposited coatings of carbon in diamond crystal form applied directly to engine parts. The motorcycle racers have exploited this technology for about an 8% increase in HP through reduction in internal friction. The stuff works on any internal surface where friction and wear is a problem. Lycoming cams and mushroom tappets seem like a natural aplication. The costs have come down to where a few hundred dollars of coating work is enough for an engine. However, I haven't heard of the technology being applied to aviation piston engines. I have always wondered why the aviation community hasn't utilized more of lessons learned from the racing communities. Granted, we have to deal with certified products and procedures in most cases, and reliability should always take a back seat to overall power output. But so much has been learned from all forms of racing that deals strictly with reliability and efficency, that is surprises me so little of it makes it to GA. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) |
![]() "Scott" wrote in message .. . Well, maybe reliability for one or two races might be thought about. I guess what I was alluding to was that I wouldn't think an engine built for racing would have a high TBO compared to our slow turning tractor engines (Lycoming, Continental, etc.). Scott That's true with many of the high performance techniques. Mult-angle valve jobs, high lift and overlap cams, and high compression are good examples. But many other techniques would do just the opposite. Precision balancing, matching rod and piston lengths and weights, equalzing combustion chambers, tuned exhaust systems and alike, will afford better performance and a much smoother running engine. Not to mention friction reducing coatings mentioned above. Dry sump oil systems and modifications to improve flow in the lubrication system would be applicable too. Most of these items are too expensive for a routine automotive overhaul, but begin to look much more affordable for something as important and often as expensive aviation overhaul. |
On Apr 21, 3:20 pm, "Maxwell" wrote:
"Scott" wrote in message .. . Well, maybe reliability for one or two races might be thought about. I guess what I was alluding to was that I wouldn't think an engine built for racing would have a high TBO compared to our slow turning tractor engines (Lycoming, Continental, etc.). Scott That's true with many of the high performance techniques. Mult-angle valve jobs, high lift and overlap cams, and high compression are good examples. But many other techniques would do just the opposite. Precision balancing, matching rod and piston lengths and weights, equalzing combustion chambers, tuned exhaust systems and alike, will afford better performance and a much smoother running engine. Not to mention friction reducing coatings mentioned above. Dry sump oil systems and modifications to improve flow in the lubrication system would be applicable too. Most of these items are too expensive for a routine automotive overhaul, but begin to look much more affordable for something as important and often as expensive aviation overhaul. Well thought out ideas. My experimental is running a detuned V-8 and proving that theory daily.. Ben www.haaspowerair.com |
Bill Daniels wrote:
Oh, I dunno, you don't win races by blowing up engines - you have to finish. Most of what goes into race prepping an engine is beefing it up so it lasts the whole race at extreme power output. Reduce power to a more reasonable level and a race engines will last practically forever. The current crop of "Sport Touring" motorcycles are just that - de-tuned racers. Having one wear out or fail in service is almost unheard of. The same tricks used to increase reliability of a race engine can be used to increase reliability even further in normal use. DLC's increase reliability not power. Bill Daniels Hey, Wot's a DLC???(please)Jerry "Scott" wrote in message news ![]() Certified? Not in a "homebuilt" group! ![]() However, that said, I think you are right...reliability is a relatively unknown word in racing engine circles I suspect... I'm still waiting for the space shuttles to be reitred so I's can get one of their engines as surplus and bolt it on my Corben :O Scott Maxwell wrote: "Bill Daniels" bildan@comcast-dot-net wrote in message ... I've been following the development of Diamond-Like Coatings (DLC's) for a decade of so. These are vapor deposited coatings of carbon in diamond crystal form applied directly to engine parts. The motorcycle racers have exploited this technology for about an 8% increase in HP through reduction in internal friction. The stuff works on any internal surface where friction and wear is a problem. Lycoming cams and mushroom tappets seem like a natural aplication. The costs have come down to where a few hundred dollars of coating work is enough for an engine. However, I haven't heard of the technology being applied to aviation piston engines. I have always wondered why the aviation community hasn't utilized more of lessons learned from the racing communities. Granted, we have to deal with certified products and procedures in most cases, and reliability should always take a back seat to overall power output. But so much has been learned from all forms of racing that deals strictly with reliability and efficency, that is surprises me so little of it makes it to GA. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) |
Bill Daniels wrote:
Oh, I dunno, you don't win races by blowing up engines - you have to finish. Most of what goes into race prepping an engine is beefing it up so it lasts the whole race at extreme power output. Reduce power to a more reasonable level and a race engines will last practically forever. The current crop of "Sport Touring" motorcycles are just that - de-tuned racers. Having one wear out or fail in service is almost unheard of. The same tricks used to increase reliability of a race engine can be used to increase reliability even further in normal use. DLC's increase reliability not power. ---OK I got it Diamond like Coatings--sorry 'bout dat..Jerry Bill Daniels "Scott" wrote in message news ![]() Certified? Not in a "homebuilt" group! ![]() However, that said, I think you are right...reliability is a relatively unknown word in racing engine circles I suspect... I'm still waiting for the space shuttles to be reitred so I's can get one of their engines as surplus and bolt it on my Corben :O Scott Maxwell wrote: "Bill Daniels" bildan@comcast-dot-net wrote in message ... I've been following the development of Diamond-Like Coatings (DLC's) for a decade of so. These are vapor deposited coatings of carbon in diamond crystal form applied directly to engine parts. The motorcycle racers have exploited this technology for about an 8% increase in HP through reduction in internal friction. The stuff works on any internal surface where friction and wear is a problem. Lycoming cams and mushroom tappets seem like a natural aplication. The costs have come down to where a few hundred dollars of coating work is enough for an engine. However, I haven't heard of the technology being applied to aviation piston engines. I have always wondered why the aviation community hasn't utilized more of lessons learned from the racing communities. Granted, we have to deal with certified products and procedures in most cases, and reliability should always take a back seat to overall power output. But so much has been learned from all forms of racing that deals strictly with reliability and efficency, that is surprises me so little of it makes it to GA. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) |
Read below in earlier post.
"Jerry Wass" wrote in message . net... Bill Daniels wrote: Oh, I dunno, you don't win races by blowing up engines - you have to finish. Most of what goes into race prepping an engine is beefing it up so it lasts the whole race at extreme power output. Reduce power to a more reasonable level and a race engines will last practically forever. The current crop of "Sport Touring" motorcycles are just that - de-tuned racers. Having one wear out or fail in service is almost unheard of. The same tricks used to increase reliability of a race engine can be used to increase reliability even further in normal use. DLC's increase reliability not power. Bill Daniels Hey, Wot's a DLC???(please)Jerry "Scott" wrote in message news ![]() Certified? Not in a "homebuilt" group! ![]() However, that said, I think you are right...reliability is a relatively unknown word in racing engine circles I suspect... I'm still waiting for the space shuttles to be reitred so I's can get one of their engines as surplus and bolt it on my Corben :O Scott Maxwell wrote: "Bill Daniels" bildan@comcast-dot-net wrote in message ... I've been following the development of Diamond-Like Coatings (DLC's) for a decade of so. These are vapor deposited coatings of carbon in diamond crystal form applied directly to engine parts. The motorcycle racers have exploited this technology for about an 8% increase in HP through reduction in internal friction. The stuff works on any internal surface where friction and wear is a problem. Lycoming cams and mushroom tappets seem like a natural aplication. The costs have come down to where a few hundred dollars of coating work is enough for an engine. However, I haven't heard of the technology being applied to aviation piston engines. I have always wondered why the aviation community hasn't utilized more of lessons learned from the racing communities. Granted, we have to deal with certified products and procedures in most cases, and reliability should always take a back seat to overall power output. But so much has been learned from all forms of racing that deals strictly with reliability and efficency, that is surprises me so little of it makes it to GA. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) |
![]() "Richard Riley" wrote in message ... On Sun, 22 Apr 2007 01:08:22 GMT, Jerry Wass wrote: Bill Daniels wrote: Oh, I dunno, you don't win races by blowing up engines - you have to finish. In th '50s my dad raced Forumula 3 cars (on methanol ditto fluid, but that's another story.) One race he won, he didn't take a victory lap, he just pulled into the winners circle. When my mom asked him why he said "6 lap race, 6 lap engine." I can remember a not to be named but once well known Formula 1 air race guy thinking out loud as follows ... "Cooling drag is about 40% of my total drag on the airplane. The average air race only lasts about 15 minutes. I think an O-200 will run at least 15 minutes without cooling before it siezes. What will happen if we eliminate the cooling completely?" Some of the things we consider for racing advantage are not altogether practical on an everyday non-racing machine! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) Pinckneyville rec.aviation flyin May 18,19, 20. FAQ at http://www.ousterhout.net/pjy-faq.html |
Highflyer wrote:
"Richard Riley" wrote in message ... On Sun, 22 Apr 2007 01:08:22 GMT, Jerry Wass wrote: Bill Daniels wrote: Oh, I dunno, you don't win races by blowing up engines - you have to finish. In th '50s my dad raced Forumula 3 cars (on methanol ditto fluid, but that's another story.) One race he won, he didn't take a victory lap, he just pulled into the winners circle. When my mom asked him why he said "6 lap race, 6 lap engine." I can remember a not to be named but once well known Formula 1 air race guy thinking out loud as follows ... "Cooling drag is about 40% of my total drag on the airplane. The average air race only lasts about 15 minutes. I think an O-200 will run at least 15 minutes without cooling before it siezes. What will happen if we eliminate the cooling completely?" Some of the things we consider for racing advantage are not altogether practical on an everyday non-racing machine! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) Pinckneyville rec.aviation flyin May 18,19, 20. FAQ at http://www.ousterhout.net/pjy-faq.html Sounds Like Tom Cassutt? |
A Few From Friday - 6428-W.jpg (1/1) | RustYŠ | Aviation Photos | 0 | February 3rd 07 11:43 PM |
A Few From Friday - 6427-W.jpg (1/1) | RustYŠ | Aviation Photos | 0 | February 3rd 07 11:43 PM |
A Few From Friday - 6417-W.jpg (1/1) | RustYŠ | Aviation Photos | 0 | February 3rd 07 11:42 PM |
A Few From Friday - 6412-W.jpg (1/1) | RustYŠ | Aviation Photos | 0 | February 3rd 07 11:42 PM |
A Few From Friday - 6403-W.jpg (1/1) | RustYŠ | Aviation Photos | 0 | February 3rd 07 11:42 PM |
